Date/Time: Sat, 11 Jan 2025 15:01:47 +0000
developing VA / TPO chart
View Count: 778
[2016-12-14 13:47:16] |
User514370 - Posts: 62 |
Hello, maybe I overlooked something - I´m sorry in this case. I´m trying to set up DEVELOPING VAH+VAH+POC+WVAP in TPO chart. The key feature is "developing". Is possible to have it in TPO? Thank you! |
[2016-12-14 18:30:24] |
Did you want to see the Value Area High, Low and Point of control and volume weighted average price to be based on volume or TPOs? But in any case, this is not going to work properly on a TPO Profile Chart. You need to use the appropriate study on a standard chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-14 18:31:09
[2016-12-14 19:12:34] |
Based on volume. So, there´s no chance to use developing study on a TPO? |
[2016-12-14 19:30:01] |
OK understood. You really do need to use a standard chart.
