Date/Time: Sat, 11 Jan 2025 14:50:44 +0000
Volume At Price Data from other Charts
View Count: 616
[2016-12-14 10:46:31] |
kas64h - Posts: 87 |
Within ACSIL is it possible to obtain VolumeAtPrice data from another chart, or alternatively obtain a SCStudyInterfaceRef reference from another chart from which presumably the VolumeAtPrice data could be derived? Many thanks. |
[2016-12-14 10:49:05] |
No, none of this is supported at this time. We plan to offer this, sometime next year but we have no set time frame and do not put any reliance on it coming anytime soon because it will not. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-14 10:49:19
[2016-12-14 11:04:25] |
ok, thank you for getting back to me.
