Date/Time: Wed, 16 Sep 2026 06:58:23 +0000
write a label in a Horizontal Line
View Count: 5097
| [2016-12-14 09:57:02] |
| User252419 - Posts: 236 |
Hello, Is it possible to have a label on the right in a horizontal Line? Thank you |
| [2016-12-14 19:25:01] |
Yes. This is done through the Horizontal Line Drawing Tool configuration. Refer to: http://www.sierrachart.com/index.php?page=doc/Tools.html#DrawingToolConfiguration http://www.sierrachart.com/index.php?page=doc/Tools.html#DTConfigHorizontalLine Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-12-19 15:30:49] |
I haven't found how to add a WORD label, I know I can see the price. But I want to have something written by me in the right of the horizontal line. Thank you, |
| [2016-12-20 00:55:31] |
Refer to: http://www.sierrachart.com/index.php?page=doc/Tools.html#ModifyText Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-02-21 22:35:20] |
| User459325 - Posts: 9 |
Hi Is it possible to add a label around the text for the horizontal line, as seen in the image. The label at the top of the image is from the SC Volume Profile tool but the other 2 labels are from other platforms. |
| [2017-02-22 00:54:52] |
This is not making sense to us. What do you mean by "add label around the text for the horizontal line". What kind of label? What do you mean by around? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-22 00:55:05
| [2017-02-22 02:08:47] |
Sorry I'm not quite sure what the correct term is for what I'm referring to - label or marker In the "Price Markers" image in the previous post, I have shown 3 horizontal lines with text attached. The first line has a price of 1303.50. What I am referring to as the label is the orange rectangle around or behind the 1303.50 text - whatever that is called. Same for the second line in the image, there is a red shaped marker behind the price of 2264.00 and same for the third line where there is a black rectangle (with a transparent fill color) around the 53.77 price I just want to know if you could add these markers/labels to the text attached to a horizontal line Date Time Of Last Edit: 2017-02-22 02:24:41
| [2017-02-22 03:27:18] |
Yes this can be done. You need to enable the Price label for the horizontal line. Refer to the documentation for this here: Chart Drawing Tools: Drawing Tool Configuration Chart Drawing Tools: Horizontal Line | Horizontal Line Non-Extended Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-05-14 05:52:40] |
| User745789 - Posts: 398 |
Anyway to get Horizontal Ray text label in the label column of a Chart DOM? In my case. I do not want to use the Line Study. |
| [2019-10-06 13:03:35] |
| ILIM KIRGIZ - Posts: 187 |
Is there a way to show a horizontal line tool's label at the value scale? Thanks. |
| [2019-10-10 12:16:09] |
So no answer means no way. Thanks. |
| [2019-10-10 12:54:58] |
No, it is not supported to be able to show the label for a drawn Horizontal Line in the Value Scale. You can, however, use the Horizontal Lines study and use the Value Labal capabilities which can draw in the Values Scale. Refer to the following: Chart Studies: Subgraphs Tab >> Name and Value Labels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
