Date/Time: Sat, 11 Jan 2025 15:03:05 +0000
Real Time Relative Volume
View Count: 687
[2016-12-14 05:24:13] |
User25116 - Posts: 27 |
I have package 3 I thought it would give me real time for the Relative Volume do I need to upgrade to package 5. The settings on the indicator dont seem right compared to other ones Ive seen for example instead of showing 10.00 it shows 100.00 and there isnt a negative side to it like -50.00 I just want to make sure I have the right one and if it is right how can I better have it reflect what is actually happening in the market for the ES |
[2016-12-14 05:39:52] |
If you are referring to the Relative Volume study, then you do not need service package 5 for that. Here is the documentation for it: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s356 If you think there is something not right, we need a much better explanation of why based on how it works according to the documentation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
