Date/Time: Sat, 11 Jan 2025 14:37:04 +0000
Price of one futures contract to trigger order entry in a different futures contract
View Count: 723
[2016-12-13 23:49:23]
User28706 - Posts: 23
Is it possible to be able to set up a situation if a stop or limit is hit in one futures contact then automatically a market order will be triggered in another contract. For example if the ES hits 2700 then Sierra will automatically create a market order to buy the NQ .
Date Time Of Last Edit: 2016-12-13 23:51:32
[2016-12-14 03:20:34]
Yes this can be done by using the Spreadsheet System for Trading study:
http://www.sierrachart.com/index.php?page=doc/SystemsAlerts.php
You will need to add this study to the NQ chart.
You will need to overlay the ES chart onto the NQ chart. This is explained here:
http://www.sierrachart.com/index.php?page=doc/Spreadsheets_ReferencingOtherChartsInFormulas.php
You can then use the spreadsheet formulas to trigger a buy or sell order based upon the ES price data being overlaid.
Date Time Of Last Edit: 2016-12-14 03:20:57
