Date/Time: Sat, 11 Jan 2025 14:44:59 +0000
Quoteboard showing zeros
View Count: 639
[2016-12-13 16:53:57] |
User1967 - Posts: 34 |
Hi - My quote board only displays zeros (please see the attached file). I have also raised a support ticket yesterday but no reply issued... Regards, GH Sabri |
QuoteBoard.png / V - Attached On 2016-12-13 16:53:29 UTC - Size: 143.18 KB - 222 views |
[2016-12-13 18:02:34] |
One of the symbols is a stock symbol and Rithmic does not provide stock data. You must use the Sierra Chart Exchange Data Feed for stocks/equity data: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php The other symbol is not the right format. You need to change it to ESZ6-CME. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
