Date/Time: Sat, 11 Jan 2025 14:41:10 +0000
adding indicator to sierra chart-CS format?
View Count: 1144
[2016-12-13 16:03:18]
User326163 - Posts: 18
i was given an indicator i want to use, but when i unzipped the file it was in CS file type versus the usual DLL. when i go to "add custom study" it is not there like usual with a DLL file.
can i open the file in this format?
thank you!
[2016-12-13 18:06:01]
No, C # files cannot be used. It needs to be a CPP file written specifically for Sierra Chart. Refer to:
http://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html
