Date/Time: Sat, 11 Jan 2025 14:38:20 +0000
spreadsheet and chart don't agree
View Count: 794
[2016-12-13 15:09:00] |
joer - Posts: 41 |
Any idea why the tpo value area lines drawn on my chart don't agree with the values showing in my spreadsheet study? Example: for poc, vah, val in spreadsheet values are 46.30 46.88 46.00 and on chart the lines are drawn at 46.50 47.20 45.60. I have Draw Developing Value area set to NO so the lines on the chart go straight across and the values in the spreadsheet are the same for the entire day.
[2016-12-13 18:44:53] |
We think we know what the problem is in your case although it is not entirely clear. If it is what we think, this happens with that particular study because the study Subgraph values change at bars earlier than the last bar being updated. We will implement a solution to this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-13 18:45:40
