Date/Time: Sat, 11 Jan 2025 14:59:51 +0000
Exporting Data Without Milliseconds
View Count: 620
[2016-12-13 00:48:54]
User760942 - Posts: 120
Hi SC,
When exporting data to CSV using the feature in the link below, is it possible to have the resulting CSV file not include milliseconds?
Edit Menu: Edit >> Export Bar and Study Data to Text File
For instance, instead of the timestamps in the CSV looking like this:
Date, Time, Open, High, Low, Last, Volume, NumberOfTrades, BidVolume, AskVolume
2016/6/16, 16:30:00, 2079.25, 2079.25, 2079.25, 2079.25, 31, 1, 0, 31
2016/6/16, 16:30:00.1, 2078.75, 2078.75, 2078.75, 2078.75, 1, 1, 1, 0
2016/6/16, 16:30:00.2, 2078.75, 2078.75, 2078.75, 2078.75, 2, 1, 2, 0
I would like them to look like this:
2016/6/16, 16:30:00, 2078.75, 2078.75, 2078.75, 2078.75, 1, 1, 1, 0
2016/6/16, 16:30:00, 2078.75, 2078.75, 2078.75, 2078.75, 2, 1, 2, 0
[2016-12-13 08:32:52]
No it is not. You would need to do additional processing through a Spreadsheet program to remove that.
