Date/Time: Sat, 11 Jan 2025 14:37:05 +0000
aaving a window setup
View Count: 631
[2016-12-12 23:33:33] |
User705641 - Posts: 38 |
Hi I have a chartbook open and I have created a window with multiple charts of different time frames -- how do I save the layout so that it reappears when I open the chart book again?
[2016-12-13 00:02:37] |
You just save the Chartbook. And then when you open the Chartbook it will have the same configuration. Here are detailed instructions for all Chartbook tasks: Chartbooks (Workspaces) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-13 05:13:20
