Date/Time: Sat, 11 Jan 2025 14:53:38 +0000
volume dots
View Count: 1624
[2016-12-12 21:13:42] |
acvbkk - Posts: 1 |
Is it at all possible to chart volume as dots, where the dots are sized in proportion to the volume traded at that price within the bar and relative to any other volume currently visible on the chart? I have attached an image of what I mean. Many Thanks Date Time Of Last Edit: 2016-12-12 21:21:50
tradedots_0.png / V - Attached On 2016-12-12 21:12:49 UTC - Size: 23.33 KB - 374 views |
[2016-12-12 22:54:30] |
The closest that is available is Numbers Bars: Numbers Bars Also our comment on the chart that you posted is that that really is not a clean and organized display of volume at price. The Numbers Bars study has a superior method to display this by using a horizontal volume bar which varies in width according to the amount of volume. And the new Large Volume Trade Indicator study which is still to be documented. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-12 22:55:45
