Date/Time: Tue, 13 Oct 2026 17:00:00 +0000
Data Rithmic
View Count: 1068
[2016-12-12 19:22:53]
User18210 - Posts: 6
Yes sierrachart now works correctly with data Rithmic.Thank you for your help.
Reading Internal Order ID file. | 2016-12-12 19:15:17
Reading Trade Orders file. | 2016-12-12 19:15:17
Reading Trade Positions file. | 2016-12-12 19:15:17
Software version: 1495 | 2016-12-12 19:15:17
Uses New Spreadsheets | 2016-12-12 19:15:17
Usage end date: 2017-07-11 | 2016-12-12 19:15:17
Enabled for: Advanced Features. | 2016-12-12 19:15:17
Enabled for: Sierra Chart Historical Data Service. | 2016-12-12 19:15:17
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-12-12 19:15:17
Current selected Data/Trading service: SC Data - All Services | 2016-12-12 19:15:17
Chart Update Interval: 500 | 2016-12-12 19:15:17
Time Zone: +00:00:00 (UTC+00) | 2016-12-12 19:15:17
2016-12-12 20:15:36 Local computer time | 2016-12-12 19:15:17
2016-12-12 19:15:36 Local computer time in UTC | 2016-12-12 19:15:17
2016-12-12 19:15:36 Local computer time in SC Time Zone | 2016-12-12 19:15:17
2016-12-12 19:15:35 Server time in UTC | 2016-12-12 19:15:17
Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-12-12 19:15:17
Program path: C:\SierraChart 3\ | 2016-12-12 19:15:17
Data Files path: C:\SierraChart 3\Data\ | 2016-12-12 19:15:17
OS Version Number: 6.1 | 2016-12-12 19:15:17
Locale Setting: C | 2016-12-12 19:15:17
Checking for new symbol settings for scdataallservices | 2016-12-12 19:15:17
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-12-12 19:15:17
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-12-12 19:15:17
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-12-12 19:15:17
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-12-12 19:15:17
Requesting symbol settings for scdataallservices. Overwrite = on. | 2016-12-12 19:15:40
SC Data - All Services | Connected to data server. | 2016-12-12 19:15:41
Symbol settings received. | 2016-12-12 19:15:44
Processed 5195 symbol settings. | 2016-12-12 19:15:44
It is recommended to reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed' | 2016-12-12 19:15:44
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-12-12 19:15:49
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-12-12 19:15:49
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-12-12 19:15:49
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-12-12 19:15:49
SC Data - All Services | Disconnected. | 2016-12-12 20:16:28
Checking for new symbol settings for rim | 2016-12-12 20:16:28
Current selected Data/Trading service: Rithmic Trading | 2016-12-12 20:16:28
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-12-12 20:16:28
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-12-12 20:16:28
HTTPS connection to www.sierrachart.com:443 (4) | Connected. | 2016-12-12 20:16:28
HTTPS connection to www.sierrachart.com:443 (4) | Starting TLS 1.2 connection. | 2016-12-12 20:16:28
HTTPS connection to www.sierrachart.com:443 (4) | SSL connection established. | 2016-12-12 20:16:28
Requesting symbol settings for rim. Overwrite = on. | 2016-12-12 20:16:28
Symbol settings received. | 2016-12-12 20:16:28
Processed 780 symbol settings. | 2016-12-12 20:16:28
Rithmic Trading | Port for executable: 51012 | 2016-12-12 20:16:30
Listening socket (616), port 51012 | Closed. | 2016-12-12 20:16:30
Rithmic Trading | Starting server: C:\SierraChart 3\Rim\DTCBridge.exe | 2016-12-12 20:16:30
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51012 | 2016-12-12 20:16:31
Socket (5) | Connected. | 2016-12-12 20:16:31
Rithmic Trading | Connected to server. | 2016-12-12 20:16:31
Rithmic Trading | Sending Encoding Request to server | 2016-12-12 20:16:31
Rithmic Trading | Setting DTC encoding to Binary VLS | 2016-12-12 20:16:31
Rithmic Trading | Sending logon request message. | 2016-12-12 20:16:31
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-12-12 20:16:31
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart 3\Rim\Rithmic.log | 2016-12-12 20:16:31
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-12-12 20:16:31
HTTPS connection to www.sierrachart.com:443 (4) | SSL connection closed by remote side. | 2016-12-12 20:16:33
HTTPS connection to www.sierrachart.com:443 (4) | Connection gracefully closed by remote side. | 2016-12-12 20:16:33
HTTPS connection to www.sierrachart.com:443 (4) | SSL object has been freed. SSL state is now disconnected. | 2016-12-12 20:16:33
HTTPS connection to www.sierrachart.com:443 (4) | Shutdown and closed. | 2016-12-12 20:16:33
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-12-12 20:16:34
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-12-12 20:16:34
Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2016-12-12 20:16:34
Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-12-12 20:16:35
Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2016-12-12 20:16:35
Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2016-12-12 20:16:36
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2016-12-12 20:16:36
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2016-12-12 20:16:36
Rithmic Trading | Received logon response. | 2016-12-12 20:16:36
Rithmic Trading | Server Name: SC DTC Bridge. | 2016-12-12 20:16:36
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-12-12 20:16:36
Rithmic Trading | Successfully connected. IB='PatelFutures', Firm='Dorman'. | 2016-12-12 20:16:36
Rithmic Trading | Trading is supported. | 2016-12-12 20:16:36
Rithmic Trading | Order cancel and replace is supported. | 2016-12-12 20:16:36
Rithmic Trading | OCO Orders supported. | 2016-12-12 20:16:36
Rithmic Trading | Connected to data and trading server. | 2016-12-12 20:16:36
TF FMH0017!-NYBOT 1 Min #1 | Reloading chart. | 2016-12-12 20:16:57
TF FMH0017!-NYBOT 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart 3\Data\TF FMH0017!-NYBOT.scid | 2016-12-12 20:16:57
Rithmic Trading | Starting real-time market data updates for: TF FMH0017!-NYBOT. ID: 1 | 2016-12-12 20:16:58
Rithmic Trading | Requesting security definition data for: TF FMH0017!-NYBOT. ID: 1 | 2016-12-12 20:16:58
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: TF FMH0017!-NYBOT | 2016-12-12 20:16:58
Intraday data recording state for symbol TF FMH0017!-NYBOT is set to download 'Pending'. | 2016-12-12 20:16:58
Market data subscription status is not known while delaying historical data download for symbol: TF FMH0017!-NYBOT | 2016-12-12 20:16:58
Delaying start of download for TF FMH0017!-NYBOT | 2016-12-12 20:16:58
Delaying start of download for TF FMH0017!-NYBOT | 2016-12-12 20:16:59
HD Request # 2 | Downloading Intraday chart data for TF FMH0017!-NYBOT to the file TF FMH0017!-NYBOT.scid. Service: ice.us | 2016-12-12 20:17:03
Compressing file: C:\SierraChart 3\Data\TF FMH0017!-NYBOT.scid. This may take a while. | 2016-12-12 20:17:03
HD Request # 2 | Download start date-time: 2016-06-09 21:17:03.000 | 2016-12-12 20:17:03
HD Request # 2 | Using server: ds6.sierracharts.com port 10149 | 2016-12-12 20:17:03
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-12-12 20:17:03
Socket (6) | Connected. | 2016-12-12 20:17:03
HD Request # 2 | Setting DTC encoding to Binary VLS | 2016-12-12 20:17:03
HD Request # 2 | Sending historical data logon request message. | 2016-12-12 20:17:03
HD Request # 2 | Requesting Intraday data. Start date-time: 2016-06-09 21:17:03. Record interval: 1. Symbol: RJH17 | 2016-12-12 20:17:03
HD Request # 2 | Decompressing data. | 2016-12-12 20:17:04
HD Request # 2 | Receiving Intraday data for TF FMH0017!-NYBOT starting at 2016-09-08 22:03:34 | 2016-12-12 20:17:04
HD Request # 2 | Timestamp of first Intraday data file record written: 2016-09-08 22:03:34 | 2016-12-12 20:17:04
Socket (6) | Shutdown and closed. | 2016-12-12 20:17:05
The network socket for historical data has been closed. | 2016-12-12 20:17:05
HD Request # 2 | Received 38249 records from 2016-09-08 22:03:34 to 2016-12-12 20:02:00 (95.0 days) and wrote 38249 records for TF FMH0017!-NYBOT | 2016-12-12 20:17:05
HD Request # 2 | Intraday download COMPLETE for TF FMH0017!-NYBOT. Completion time: 2s. Unique request ID: 1 | 2016-12-12 20:17:05
Removed historical data download ID 1 | 2016-12-12 20:17:05
Real-time Intraday chart data file updates started for TF FMH0017!-NYBOT | 2016-12-12 20:17:05
Intraday chart data file opened for TF FMH0017!-NYBOT | 2016-12-12 20:17:05
Rithmic Trading | Using primary service for historical data for TF FMH0017!-NYBOT | 2016-12-12 20:17:05
Intraday data recording state for symbol TF FMH0017!-NYBOT is set to download 'Pending'. | 2016-12-12 20:17:05
HD Request # 3 | Downloading Intraday chart data for TF FMH0017!-NYBOT to the file TF FMH0017!-NYBOT.scid. Service: rim | 2016-12-12 20:17:05
HD Request # 3 | Download start date-time: 2016-12-12 20:02:00.000 | 2016-12-12 20:17:05
HD Request # 3 | Sending historical data request. Start date-time: 2016-12-12 20:02:00. Record interval: 0. Symbol: TF FMH0017!-NYBOT | 2016-12-12 20:17:05
Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-12-12 20:17:05
HD Request # 3 | Receiving Intraday data for TF FMH0017!-NYBOT starting at 2016-12-12 20:02:00 | 2016-12-12 20:17:06
HD Request # 3 | Timestamp of first Intraday data file record written: 2016-12-12 20:02:05 | 2016-12-12 20:17:06
HD Request # 3 | Received 2257 records from 2016-12-12 20:02:00 to 2016-12-12 20:17:04 (15.1 minutes) and wrote 2256 records for TF FMH0017!-NYBOT | 2016-12-12 20:17:06
HD Request # 3 | Intraday download COMPLETE for TF FMH0017!-NYBOT. Completion time: 1s. Unique request ID: 2 | 2016-12-12 20:17:06
Removed historical data download ID 2 | 2016-12-12 20:17:06
Real-time Intraday chart data file updates started for TF FMH0017!-NYBOT | 2016-12-12 20:17:06
Intraday chart data file opened for TF FMH0017!-NYBOT | 2016-12-12 20:17:06
Opened cached Intraday file: C:\SierraChart 3\Data\TF FMH0017!-NYBOT.scid | 2016-12-12 20:17:17
[2016-12-12 20:48:17]
First, you need to respond in the thread/Support Request where the original request and responses were made. Not a new Support Request. This is incorrect and creates more burden upon us and is out of context for other users.
And there is no need to post the Message Log. And there really is no need to respond at all unless you have a further issue.
