Date/Time: Sat, 11 Jan 2025 14:56:55 +0000
VAP, BVAP, AVAP spreadsheet functions
View Count: 1994
[2016-12-12 18:00:32] |
Sawtooth - Posts: 4148 |
Would you be able to find the time to add VAP, BVAP, AVAP to be able to be used as Spreadsheet Functions? These are special functions currently only available for Alerts. Please and thanks in advance. |
[2016-12-12 18:14:12] |
This is not possible because those are designed to reference the chart bar data and the Spreadsheet functions do not have direct access to that. The closest that is available is this: Spreadsheet Study Inputs: Output Volume at Price Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-12 19:24:02] |
Then can you create new spreadsheet functions that output VAP, BVAP, AVAP values? For example: =BVAP(C3) would output the bid volume at the high of the current bar. |
[2016-12-12 22:22:18] |
There is no straightforward way to accomplish this because a Spreadsheet does not have direct access to the underlying chart values. We really would rather not get involved in this and even if we did, it would not be until later next year. At this point we recommend using ACSIL instead which has access to this data: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-12 22:23:20
