Date/Time: Sat, 11 Jan 2025 14:41:44 +0000
forex td ameritrade
View Count: 1087
[2016-12-12 16:55:54] |
User161321 - Posts: 15 |
I CANT TRADE FROM SIERRA DOM SAYS INVALID SYMBOL WHILE SENDING FOREX ORDER FEED FROM TD AMERITRADE Date Time Of Last Edit: 2016-12-12 16:59:16
[2016-12-12 23:00:49] |
Yes this is true. You cannot trade Forex or Futures through TD Ameritrade from Sierra Chart. Only stocks. This is explained here: https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
