Date/Time: Sat, 11 Jan 2025 14:43:19 +0000
opening intraday charts or historical charts cant open any charts past leg7 with rithmic
View Count: 731
[2016-12-12 15:18:01] |
User17036 - Posts: 8 |
Reading Internal Order ID file. | 2016-12-12 08:36:55 Reading Trade Orders file. | 2016-12-12 08:36:55 Reading Trade Positions file. | 2016-12-12 08:36:55 Software version: 1495 | 2016-12-12 08:36:55 Uses New Spreadsheets | 2016-12-12 08:36:55 Usage end date: 2017-01-01 | 2016-12-12 08:36:55 Enabled for: Advanced Features. | 2016-12-12 08:36:55 Enabled for: Advanced Features 2. | 2016-12-12 08:36:55 Enabled for: Sierra Chart Historical Data Service. | 2016-12-12 08:36:55 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-12-12 08:36:55 Current selected Data/Trading service: Rithmic Trading | 2016-12-12 08:36:55 Chart Update Interval: 500 | 2016-12-12 08:36:55 Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-12-12 08:36:55 2016-12-12 08:36:59 Local computer time | 2016-12-12 08:36:55 2016-12-12 14:36:59 Local computer time in UTC | 2016-12-12 08:36:55 2016-12-12 08:36:59 Local computer time in SC Time Zone | 2016-12-12 08:36:55 2016-12-12 14:36:57 Server time in UTC | 2016-12-12 08:36:55 Local computer UTC time and Server UTC time difference: 1 seconds. | 2016-12-12 08:36:55 Program path: C:\SierraChart\ | 2016-12-12 08:36:55 Data Files path: C:\SierraChart\Data\ | 2016-12-12 08:36:55 OS Version Number: 6.2 | 2016-12-12 08:36:55 Locale Setting: C | 2016-12-12 08:36:55 Checking for new symbol settings for rim | 2016-12-12 08:36:55 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-12-12 08:36:55 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-12-12 08:36:55 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-12-12 08:36:55 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-12-12 08:36:55 Symbol settings are up-to-date for rim | 2016-12-12 08:37:00 Rithmic Trading | Port for executable: 61590 | 2016-12-12 08:37:04 Listening socket (920), port 61590 | Closed. | 2016-12-12 08:37:04 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-12-12 08:37:04 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-12-12 08:37:05 HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-12-12 08:37:05 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-12-12 08:37:05 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-12-12 08:37:05 Rithmic Trading | Connecting to the server 127.0.0.1. Port 61590 | 2016-12-12 08:37:06 Socket (4) | Connected. | 2016-12-12 08:37:06 Rithmic Trading | Connected to server. | 2016-12-12 08:37:06 Rithmic Trading | Sending Encoding Request to server | 2016-12-12 08:37:06 Rithmic Trading | Setting DTC encoding to Binary VLS | 2016-12-12 08:37:06 Rithmic Trading | Sending logon request message. | 2016-12-12 08:37:06 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-12-12 08:37:06 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-12-12 08:37:06 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-12-12 08:37:06 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-12-12 08:37:06 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-12-12 08:37:06 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2016-12-12 08:37:06 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-12-12 08:37:06 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2016-12-12 08:37:06 Rithmic Trading | Message from server: subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2016-12-12 08:37:06 Rithmic Trading | Message from server: subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2016-12-12 08:37:06 Rithmic Trading | Message from server: subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2016-12-12 08:37:06 Rithmic Trading | Message from server: subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2016-12-12 08:37:06 Rithmic Trading | Message from server: subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2016-12-12 08:37:06 Rithmic Trading | Message from server: subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2016-12-12 08:37:06 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2016-12-12 08:37:06 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2016-12-12 08:37:06 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2016-12-12 08:37:06 Rithmic Trading | Received logon response. | 2016-12-12 08:37:07 Rithmic Trading | Server Name: SC DTC Bridge. | 2016-12-12 08:37:07 Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-12-12 08:37:07 Rithmic Trading | Successfully connected. IB='MarcusLaxgang'. | 2016-12-12 08:37:07 Rithmic Trading | Trading is supported. | 2016-12-12 08:37:07 Rithmic Trading | Order cancel and replace is supported. | 2016-12-12 08:37:07 Rithmic Trading | OCO Orders supported. | 2016-12-12 08:37:07 Rithmic Trading | Connected to data and trading server. | 2016-12-12 08:37:07 GFF7-CME Daily #1 | Reloading chart. | 2016-12-12 08:38:04 GFF7-CME 60 Min #2 | Reloading chart. | 2016-12-12 08:38:04 GFF7-CME 30 Min #3 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME Daily #1 | Reloading chart. | 2016-12-12 08:38:04 he:BF z6-g7-j7-CME 60 Min #2 | Reloading chart. | 2016-12-12 08:38:04 LEg7-CME 15 Min #3 | Reloading chart. | 2016-12-12 08:38:04 LEg7-CME 5 Min #4 | Reloading chart. | 2016-12-12 08:38:04 LEg7-CME 5 Min #5 | Reloading chart. | 2016-12-12 08:38:04 leg7-CME #7 | Reloading chart. | 2016-12-12 08:38:04 LEZ6-HEZ6-CME 30 Min #8 | Reloading chart. | 2016-12-12 08:38:04 hEg7-CME Daily #9 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME Daily #10 | Reloading chart. | 2016-12-12 08:38:04 gfx6-gff7-CME 10 Min #6 | Reloading chart. | 2016-12-12 08:38:04 Rithmic Trading | Starting real-time market data updates for: ESH7-CME. ID: 1 | 2016-12-12 08:38:04 Rithmic Trading | Requesting security definition data for: ESH7-CME. ID: 1 | 2016-12-12 08:38:04 Rithmic Trading | Starting real-time market data updates for: 6EZ6-CME. ID: 2 | 2016-12-12 08:38:04 Rithmic Trading | Requesting security definition data for: 6EZ6-CME. ID: 2 | 2016-12-12 08:38:04 Rithmic Trading | Starting real-time market data updates for: NQH7-CME. ID: 3 | 2016-12-12 08:38:04 Rithmic Trading | Requesting security definition data for: NQH7-CME. ID: 3 | 2016-12-12 08:38:04 Rithmic Trading | Starting real-time market data updates for: LEZ6-HEZ6-CME. ID: 4 | 2016-12-12 08:38:04 Rithmic Trading | Requesting security definition data for: LEZ6-HEZ6-CME. ID: 4 | 2016-12-12 08:38:04 Rithmic Trading | Starting real-time market data updates for: LEZ6-LEG7-CME. ID: 5 | 2016-12-12 08:38:04 Rithmic Trading | Requesting security definition data for: LEZ6-LEG7-CME. ID: 5 | 2016-12-12 08:38:04 Rithmic Trading | Starting real-time market data updates for: hEz6-heg7-CME. ID: 6 | 2016-12-12 08:38:04 Rithmic Trading | Requesting security definition data for: hEz6-heg7-CME. ID: 6 | 2016-12-12 08:38:04 Rithmic Trading | Starting real-time market data updates for: LEZ6-LEJ7-CME. ID: 7 | 2016-12-12 08:38:04 Rithmic Trading | Requesting security definition data for: LEZ6-LEJ7-CME. ID: 7 | 2016-12-12 08:38:04 Rithmic Trading | Starting real-time market data updates for: LEG7-LEJ7-CME. ID: 8 | 2016-12-12 08:38:04 Rithmic Trading | Requesting security definition data for: LEG7-LEJ7-CME. ID: 8 | 2016-12-12 08:38:04 heZ6-CME Daily #1 | Reloading chart. | 2016-12-12 08:38:04 HEG7-CME 60 Min #2 | Reloading chart. | 2016-12-12 08:38:04 HEG7-CME 30 Min #3 | Reloading chart. | 2016-12-12 08:38:04 HEG7-CME 10 Min #4 | Reloading chart. | 2016-12-12 08:38:04 heZ6-heg7-CME 10 Min #5 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME Daily #1 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME 60 Min #2 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME 30 Min #3 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME 10 Min #4 | Reloading chart. | 2016-12-12 08:38:04 leZ6-leg7-CME 10 Min #5 | Reloading chart. | 2016-12-12 08:38:04 leg7-lem7-CME 60 Min #6 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME 5 Min #7 | Reloading chart. | 2016-12-12 08:38:04 leg7-CME 10 Sec #8 | Reloading chart. | 2016-12-12 08:38:04 leZ6-leg7-CME 60 Min #9 | Reloading chart. | 2016-12-12 08:38:04 leg7-lej7-CME 60 Min #10 | Reloading chart. | 2016-12-12 08:38:04 lej7-lem7-CME 60 Min #11 | Reloading chart. | 2016-12-12 08:38:04 HEG7-CME 1 Sec #1 | Reloading chart. | 2016-12-12 08:38:04 LEj7-CME 1 Sec #2 | Reloading chart. | 2016-12-12 08:38:04 LEg7-CME 1 Sec #3 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME 1 Sec #4 | Reloading chart. | 2016-12-12 08:38:04 LEm7-CME 1 Sec #5 | Reloading chart. | 2016-12-12 08:38:04 LEq7-CME 1 Sec #6 | Reloading chart. | 2016-12-12 08:38:04 heg7-CME 1 Sec #7 | Reloading chart. | 2016-12-12 08:38:04 hej7-CME 1 Sec #8 | Reloading chart. | 2016-12-12 08:38:04 hem7-CME 1 Sec #9 | Reloading chart. | 2016-12-12 08:38:04 LEz6-leg7-CME 1 Sec #10 | Reloading chart. | 2016-12-12 08:38:04 hEz6-heg7-CME 1 Sec #11 | Reloading chart. | 2016-12-12 08:38:04 LEG7-lej7-CME 1 Sec #12 | Reloading chart. | 2016-12-12 08:38:04 HEz6-heg7-CME 25 Volume #2 | Reloading chart. | 2016-12-12 08:38:04 HE:BF z6-g7-j7-CME 60 Min #4 | Reloading chart. | 2016-12-12 08:38:04 LEg7-CME 25 Volume #6 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME 1 Sec #8 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME 1 Min #10 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME 25 Volume #3 | Reloading chart. | 2016-12-12 08:38:04 LEz6-leg7-CME 25 Volume #5 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME 0.250 Range #11 | Reloading chart. | 2016-12-12 08:38:04 HEG7-CME 25 Volume #7 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME 25 Volume #12 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME 60 Min #1 | Reloading chart. | 2016-12-12 08:38:04 LEz6-leg7-CME 1 Sec #9 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME 1 Sec #14 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME 30 Min #15 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME 5 Min #3 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME 5 Min #1 | Reloading chart. | 2016-12-12 08:38:04 LEZ6-leg7-CME 30 Min #2 | Reloading chart. | 2016-12-12 08:38:04 HEG7-CME 5 Min #4 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME 30 Min #5 | Reloading chart. | 2016-12-12 08:38:04 LEG7-CME 5 Min #6 | Reloading chart. | 2016-12-12 08:38:04 gff7-CME 5 Min #7 | Reloading chart. | 2016-12-12 08:38:04 LEZ6-leg7-CME 1 Min #8 | Reloading chart. | 2016-12-12 08:38:04 Rithmic Trading | Starting real-time market data updates for: GFF7-CME. ID: 9 | 2016-12-12 08:38:06 Rithmic Trading | Requesting security definition data for: GFF7-CME. ID: 9 | 2016-12-12 08:38:06 HD Request # 2 | Downloading Historical Daily chart data for GFF7-CME. Starting date: 2016-12-08. Service: rim | 2016-12-12 08:38:06 HD Request # 2 | Requesting historical Daily data for GFF17 starting at 2016-12-07 | 2016-12-12 08:38:06 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-12-12 08:38:06 HTTP connection to ds01.ddfplus.com:80 (5) | Connected. | 2016-12-12 08:38:06 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: GFF7-CME | 2016-12-12 08:38:06 Intraday data recording state for symbol GFF7-CME is set to download 'Pending'. | 2016-12-12 08:38:06 Market data subscription status is not known while delaying historical data download for symbol: GFF7-CME | 2016-12-12 08:38:06 Delaying start of download for GFF7-CME | 2016-12-12 08:38:06 Rithmic Trading | Starting real-time market data updates for: LEG7-CME. ID: 10 | 2016-12-12 08:38:06 Rithmic Trading | Requesting security definition data for: LEG7-CME. ID: 10 | 2016-12-12 08:38:06 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: LEg7-CME | 2016-12-12 08:38:06 Intraday data recording state for symbol LEg7-CME is set to download 'Pending'. | 2016-12-12 08:38:06 Market data subscription status is not known while delaying historical data download for symbol: GFF7-CME | 2016-12-12 08:38:06 Rithmic Trading | Starting real-time market data updates for: he:BF z6-g7-j7-CME. ID: 11 | 2016-12-12 08:38:06 Rithmic Trading | Requesting security definition data for: he:BF z6-g7-j7-CME. ID: 11 | 2016-12-12 08:38:06 Rithmic Trading | Using primary service for historical data for he:BF z6-g7-j7-CME | 2016-12-12 08:38:06 Intraday data recording state for symbol he:BF z6-g7-j7-CME is set to download 'Pending'. | 2016-12-12 08:38:06 Market data subscription status is not known while delaying historical data download for symbol: he:BF z6-g7-j7-CME | 2016-12-12 08:38:06 Delaying start of download for he:BF z6-g7-j7-CME | 2016-12-12 08:38:06 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\GFF7-CME.2016-12-12.depth | 2016-12-12 08:38:06 Rithmic Trading | Using primary service for historical data for LEZ6-HEZ6-CME | 2016-12-12 08:38:06 Intraday data recording state for symbol LEZ6-HEZ6-CME is set to download 'Pending'. | 2016-12-12 08:38:06 Market data subscription status is not known while delaying historical data download for symbol: he:BF z6-g7-j7-CME | 2016-12-12 08:38:06 Rithmic Trading | Starting real-time market data updates for: hEg7-CME. ID: 12 | 2016-12-12 08:38:06 Rithmic Trading | Requesting security definition data for: hEg7-CME. ID: 12 | 2016-12-12 08:38:06 Rithmic Trading | Starting real-time market data updates for: gfx6-gff7-CME. ID: 13 | 2016-12-12 08:38:06 Rithmic Trading | Requesting security definition data for: gfx6-gff7-CME. ID: 13 | 2016-12-12 08:38:06 Rithmic Trading | Using primary service for historical data for gfx6-gff7-CME | 2016-12-12 08:38:06 Intraday data recording state for symbol gfx6-gff7-CME is set to download 'Pending'. | 2016-12-12 08:38:06 Market data subscription status is not known while delaying historical data download for symbol: he:BF z6-g7-j7-CME | 2016-12-12 08:38:06 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: HEG7-CME | 2016-12-12 08:38:06 Intraday data recording state for symbol HEG7-CME is set to download 'Pending'. | 2016-12-12 08:38:06 Delaying start of download for GFF7-CME | 2016-12-12 08:38:06 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\LEG7-CME.2016-12-12.depth | 2016-12-12 08:38:06 Rithmic Trading | Starting real-time market data updates for: heZ6-CME. ID: 14 | 2016-12-12 08:38:06 Rithmic Trading | Requesting security definition data for: heZ6-CME. ID: 14 | 2016-12-12 08:38:06 Rithmic Trading | Using primary service for historical data for heZ6-heg7-CME | 2016-12-12 08:38:06 Intraday data recording state for symbol heZ6-heg7-CME is set to download 'Pending'. | 2016-12-12 08:38:06 Market data subscription status is not known while delaying historical data download for symbol: he:BF z6-g7-j7-CME | 2016-12-12 08:38:06 Rithmic Trading | Using primary service for historical data for leZ6-leg7-CME | 2016-12-12 08:38:06 Intraday data recording state for symbol leZ6-leg7-CME is set to download 'Pending'. | 2016-12-12 08:38:06 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available.. Result text: "no data". Related symbol: GFX6-GFF7-CME | 2016-12-12 08:38:06 Symbol Error - gfx6-gff7-CME is unknown, unavailable, or improperly formatted. | 2016-12-12 08:38:06 Market data subscription status is not known while delaying historical data download for symbol: he:BF z6-g7-j7-CME | 2016-12-12 08:38:06 Rithmic Trading | Starting real-time market data updates for: leg7-lem7-CME. ID: 15 | 2016-12-12 08:38:06 Rithmic Trading | Requesting security definition data for: leg7-lem7-CME. ID: 15 | 2016-12-12 08:38:06 Rithmic Trading | Using primary service for historical data for leg7-lem7-CME | 2016-12-12 08:38:06 Intraday data recording state for symbol leg7-lem7-CME is set to download 'Pending'. | 2016-12-12 08:38:06 Delaying start of download for he:BF z6-g7-j7-CME | 2016-12-12 08:38:06 Rithmic Trading | Using primary service for historical data for leg7-lej7-CME | 2016-12-12 08:38:06 Intraday data recording state for symbol leg7-lej7-CME is set to download 'Pending'. | 2016-12-12 08:38:06 HD Request # 3 | Downloading Intraday chart data for he:BF z6-g7-j7-CME to the file he~BF z6-g7-j7-CME.scid. Service: rim | 2016-12-12 08:38:06 HD Request # 3 | Download start date-time: 2016-12-12 08:34:10.000 | 2016-12-12 08:38:06 HD Request # 3 | Sending historical data request. Start date-time: 2016-12-12 08:34:10. Record interval: 0. Symbol: he:BF z6-g7-j7-CME | 2016-12-12 08:38:06 Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-12 08:38:06 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-12 08:38:06 Rithmic Trading | Starting real-time market data updates for: lej7-lem7-CME. ID: 16 | 2016-12-12 08:38:06 Rithmic Trading | Requesting security definition data for: lej7-lem7-CME. ID: 16 | 2016-12-12 08:38:06 Rithmic Trading | Using primary service for historical data for lej7-lem7-CME | 2016-12-12 08:38:06 Intraday data recording state for symbol lej7-lem7-CME is set to download 'Pending'. | 2016-12-12 08:38:06 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\hEg7-CME.2016-12-12.depth | 2016-12-12 08:38:06 Rithmic Trading | Starting real-time market data updates for: LEj7-CME. ID: 17 | 2016-12-12 08:38:06 Rithmic Trading | Requesting security definition data for: LEj7-CME. ID: 17 | 2016-12-12 08:38:06 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: LEj7-CME | 2016-12-12 08:38:06 Intraday data recording state for symbol LEj7-CME is set to download 'Pending'. | 2016-12-12 08:38:06 HD Request # 4 | Downloading Intraday chart data for GFF7-CME to the file GFF7-CME.scid. Service: cme | 2016-12-12 08:38:06 HD Request # 4 | Download start date-time: 2016-12-12 08:35:51.000 | 2016-12-12 08:38:06 HD Request # 4 | Using server: ds6.sierracharts.com port 10149 | 2016-12-12 08:38:06 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-12-12 08:38:06 Socket (6) | Connected. | 2016-12-12 08:38:06 Rithmic Trading | Starting real-time market data updates for: LEq7-CME. ID: 18 | 2016-12-12 08:38:06 Rithmic Trading | Requesting security definition data for: LEq7-CME. ID: 18 | 2016-12-12 08:38:06 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: LEq7-CME | 2016-12-12 08:38:06 HD Request # 4 | Setting DTC encoding to Binary VLS | 2016-12-12 08:38:06 HD Request # 4 | Sending historical data logon request message. | 2016-12-12 08:38:06 Intraday data recording state for symbol LEq7-CME is set to download 'Pending'. | 2016-12-12 08:38:06 HD Request # 3 | Error downloading historical Intraday data for he:BF z6-g7-j7-CME. Error downloading historical Minute data. Error: bad input | 2016-12-12 08:38:06 HD Request # 4 | Requesting Intraday data. Start date-time: 2016-12-12 08:35:51. Record interval: 0. Symbol: GFF17 | 2016-12-12 08:38:06 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for he:BF z6-g7-j7-CME | 2016-12-12 08:38:06 HD Request # 3 | Intraday download COMPLETE for he:BF z6-g7-j7-CME. Completion time: 0s. Unique request ID: 5 | 2016-12-12 08:38:06 Removed historical data download ID 5 | 2016-12-12 08:38:06 Real-time Intraday chart data file updates started for he:BF z6-g7-j7-CME | 2016-12-12 08:38:06 Intraday chart data file opened for he:BF z6-g7-j7-CME | 2016-12-12 08:38:06 Market data subscription status is not known while delaying historical data download for symbol: LEZ6-HEZ6-CME | 2016-12-12 08:38:06 Delaying start of download for LEZ6-HEZ6-CME | 2016-12-12 08:38:06 Rithmic Trading | Starting real-time market data updates for: LEm7-CME. ID: 19 | 2016-12-12 08:38:06 Rithmic Trading | Requesting security definition data for: LEm7-CME. ID: 19 | 2016-12-12 08:38:06 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: LEm7-CME | 2016-12-12 08:38:06 Intraday data recording state for symbol LEm7-CME is set to download 'Pending'. | 2016-12-12 08:38:06 Rithmic Trading | Starting real-time market data updates for: hem7-CME. ID: 20 | 2016-12-12 08:38:06 Rithmic Trading | Requesting security definition data for: hem7-CME. ID: 20 | 2016-12-12 08:38:06 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: hem7-CME | 2016-12-12 08:38:06 Intraday data recording state for symbol hem7-CME is set to download 'Pending'. | 2016-12-12 08:38:06 Rithmic Trading | Starting real-time market data updates for: hej7-CME. ID: 21 | 2016-12-12 08:38:06 Rithmic Trading | Requesting security definition data for: hej7-CME. ID: 21 | 2016-12-12 08:38:06 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: hej7-CME | 2016-12-12 08:38:06 Intraday data recording state for symbol hej7-CME is set to download 'Pending'. | 2016-12-12 08:38:06 Requesting market depth updates for: hEz6-heg7-CME if supported. | 2016-12-12 08:38:06 Requesting market depth updates for: LEG7-CME if supported. | 2016-12-12 08:38:06 Requesting market depth updates for: he:BF z6-g7-j7-CME if supported. | 2016-12-12 08:38:06 Requesting market depth updates for: LEZ6-LEG7-CME if supported. | 2016-12-12 08:38:06 Requesting market depth updates for: hEg7-CME if supported. | 2016-12-12 08:38:06 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\LEj7-CME.2016-12-12.depth | 2016-12-12 08:38:06 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\LEq7-CME.2016-12-12.depth | 2016-12-12 08:38:06 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\hEz6-heg7-CME.2016-12-12.depth | 2016-12-12 08:38:06 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\he~BF z6-g7-j7-CME.2016-12-12.depth | 2016-12-12 08:38:06 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\LEZ6-LEG7-CME.2016-12-12.depth | 2016-12-12 08:38:06 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\LEm7-CME.2016-12-12.depth | 2016-12-12 08:38:06 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\hem7-CME.2016-12-12.depth | 2016-12-12 08:38:06 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\hej7-CME.2016-12-12.depth | 2016-12-12 08:38:06 HD Request # 4 | Decompressing data. | 2016-12-12 08:38:06 Socket (6) | Shutdown and closed. | 2016-12-12 08:38:06 The network socket for historical data has been closed. | 2016-12-12 08:38:06 HD Request # 4 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GFF7-CME | 2016-12-12 08:38:06 HD Request # 4 | Intraday download COMPLETE for GFF7-CME. Completion time: 0s. Unique request ID: 2 | 2016-12-12 08:38:06 Removed historical data download ID 2 | 2016-12-12 08:38:06 Real-time Intraday chart data file updates started for GFF7-CME | 2016-12-12 08:38:06 Intraday chart data file opened for GFF7-CME | 2016-12-12 08:38:06 Rithmic Trading | Using primary service for historical data for GFF7-CME | 2016-12-12 08:38:06 Intraday data recording state for symbol GFF7-CME is set to download 'Pending'. | 2016-12-12 08:38:06 Market data subscription status is not known while delaying historical data download for symbol: LEZ6-HEZ6-CME | 2016-12-12 08:38:06 Delaying start of download for LEg7-CME | 2016-12-12 08:38:06 HD Request # 2 | Receiving historical Daily data for GFF7-CME starting at 2016-12-08 | 2016-12-12 08:38:06 HD Request # 2 | Writing historical Daily data to the file GFF7-CME.dly | 2016-12-12 08:38:06 HD Request # 2 | Received 3 records from 2016-12-08 00:00:00 to 2016-12-09 00:00:00 (2.0 days) and wrote 2 records for GFF7-CME | 2016-12-12 08:38:06 HD Request # 2 | Daily download COMPLETE for GFF7-CME. Completion time: 1s. Unique request ID: 1 | 2016-12-12 08:38:06 Removed historical data download ID 1 | 2016-12-12 08:38:06 HD Request # 5 | Downloading Historical Daily chart data for LEG7-CME. Starting date: 2016-12-08. Service: rim | 2016-12-12 08:38:06 HD Request # 5 | Requesting historical Daily data for LEG17 starting at 2016-12-07 | 2016-12-12 08:38:06 GFF7-CME Daily #1 | Reloading chart. | 2016-12-12 08:38:06 HD Request # 5 | Receiving historical Daily data for LEG7-CME starting at 2016-12-08 | 2016-12-12 08:38:06 HD Request # 5 | Writing historical Daily data to the file LEG7-CME.dly | 2016-12-12 08:38:06 HD Request # 5 | Received 3 records from 2016-12-08 00:00:00 to 2016-12-09 00:00:00 (2.0 days) and wrote 2 records for LEG7-CME | 2016-12-12 08:38:06 HD Request # 5 | Daily download COMPLETE for LEG7-CME. Completion time: 0s. Unique request ID: 3 | 2016-12-12 08:38:06 Removed historical data download ID 3 | 2016-12-12 08:38:06 HD Request # 6 | Downloading Historical Daily chart data for hEg7-CME. Starting date: 2016-12-08. Service: rim | 2016-12-12 08:38:06 HD Request # 6 | Requesting historical Daily data for HEG17 starting at 2016-12-07 | 2016-12-12 08:38:06 LEG7-CME Daily #10 | Reloading chart. | 2016-12-12 08:38:06 LEG7-CME Daily #1 | Reloading chart. | 2016-12-12 08:38:07 LEG7-CME Daily #1 | Reloading chart. | 2016-12-12 08:38:07 Market data subscription status is not known while delaying historical data download for symbol: LEZ6-HEZ6-CME | 2016-12-12 08:38:07 Requesting market depth updates for: ESH7-CME if supported. | 2016-12-12 08:38:07 Requesting market depth updates for: GFF7-CME if supported. | 2016-12-12 08:38:07 Requesting market depth updates for: hej7-CME if supported. | 2016-12-12 08:38:07 Requesting market depth updates for: hem7-CME if supported. | 2016-12-12 08:38:07 Requesting market depth updates for: heZ6-CME if supported. | 2016-12-12 08:38:07 Requesting market depth updates for: LEj7-CME if supported. | 2016-12-12 08:38:07 Requesting market depth updates for: LEm7-CME if supported. | 2016-12-12 08:38:07 Requesting market depth updates for: LEq7-CME if supported. | 2016-12-12 08:38:07 HD Request # 6 | Receiving historical Daily data for hEg7-CME starting at 2016-12-08 | 2016-12-12 08:38:07 HD Request # 6 | Writing historical Daily data to the file hEg7-CME.dly | 2016-12-12 08:38:07 HD Request # 6 | Received 3 records from 2016-12-08 00:00:00 to 2016-12-09 00:00:00 (2.0 days) and wrote 2 records for hEg7-CME | 2016-12-12 08:38:07 HD Request # 6 | Daily download COMPLETE for hEg7-CME. Completion time: 0s. Unique request ID: 7 | 2016-12-12 08:38:07 Removed historical data download ID 7 | 2016-12-12 08:38:07 HD Request # 7 | Downloading Historical Daily chart data for heZ6-CME. Starting date: 2016-12-08. Service: rim | 2016-12-12 08:38:07 HD Request # 7 | Requesting historical Daily data for HEZ16 starting at 2016-12-07 | 2016-12-12 08:38:07 hEg7-CME Daily #9 | Reloading chart. | 2016-12-12 08:38:07 Chart #9 has tagged chart #10 for full recalculation. Chartbook: GTL.cht | 2016-12-12 08:38:07 Chart #9 has tagged chart #10 for full recalculation. Chartbook: GTL.cht | 2016-12-12 08:38:07 Chart #9 has tagged chart #10 for full recalculation. Chartbook: GTL.cht | 2016-12-12 08:38:07 LEG7-CME Daily #10 | Performing a full recalculation because it has been tagged. Chartbook: GTL.cht | 2016-12-12 08:38:07 HD Request # 7 | Receiving historical Daily data for heZ6-CME starting at 2016-12-08 | 2016-12-12 08:38:08 HD Request # 7 | Writing historical Daily data to the file heZ6-CME.dly | 2016-12-12 08:38:08 HD Request # 7 | Received 3 records from 2016-12-08 00:00:00 to 2016-12-09 00:00:00 (2.0 days) and wrote 2 records for heZ6-CME | 2016-12-12 08:38:08 HD Request # 7 | Daily download COMPLETE for heZ6-CME. Completion time: 0s. Unique request ID: 10 | 2016-12-12 08:38:08 Removed historical data download ID 10 | 2016-12-12 08:38:08 Market data subscription status is not known while delaying historical data download for symbol: LEZ6-HEZ6-CME | 2016-12-12 08:38:08 heZ6-CME Daily #1 | Reloading chart. | 2016-12-12 08:38:08 Market data subscription status is not known while delaying historical data download for symbol: LEZ6-HEZ6-CME | 2016-12-12 08:38:09 Market data subscription status is not known while delaying historical data download for symbol: LEZ6-HEZ6-CME | 2016-12-12 08:38:10 Market data subscription status is not known while delaying historical data download for symbol: LEZ6-HEZ6-CME | 2016-12-12 08:38:11 HD Request # 8 | Downloading Intraday chart data for LEg7-CME to the file LEg7-CME.scid. Service: cme | 2016-12-12 08:38:11 HD Request # 8 | Download start date-time: 2016-12-12 08:36:39.000 | 2016-12-12 08:38:11 HD Request # 8 | Using server: ds1.sierracharts.com port 10149 | 2016-12-12 08:38:11 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-12-12 08:38:11 Socket (7) | Connected. | 2016-12-12 08:38:11 HD Request # 8 | Setting DTC encoding to Binary VLS | 2016-12-12 08:38:11 HD Request # 8 | Sending historical data logon request message. | 2016-12-12 08:38:11 HD Request # 8 | Requesting Intraday data. Start date-time: 2016-12-12 08:36:39. Record interval: 0. Symbol: LEG17 | 2016-12-12 08:38:11 HD Request # 8 | Decompressing data. | 2016-12-12 08:38:11 Socket (7) | Shutdown and closed. | 2016-12-12 08:38:11 The network socket for historical data has been closed. | 2016-12-12 08:38:11 HD Request # 8 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for LEg7-CME | 2016-12-12 08:38:11 HD Request # 8 | Intraday download COMPLETE for LEg7-CME. Completion time: 0s. Unique request ID: 4 | 2016-12-12 08:38:11 Removed historical data download ID 4 | 2016-12-12 08:38:11 Real-time Intraday chart data file updates started for LEG7-CME | 2016-12-12 08:38:11 Intraday chart data file opened for LEG7-CME | 2016-12-12 08:38:11 Rithmic Trading | Using primary service for historical data for LEg7-CME | 2016-12-12 08:38:11 Intraday data recording state for symbol LEg7-CME is set to download 'Pending'. | 2016-12-12 08:38:11 Market data subscription status is not known while delaying historical data download for symbol: LEZ6-HEZ6-CME | 2016-12-12 08:38:11 HD Request # 9 | Downloading Intraday chart data for HEG7-CME to the file HEG7-CME.scid. Service: cme | 2016-12-12 08:38:11 HD Request # 9 | Download start date-time: 2016-12-12 08:36:40.000 | 2016-12-12 08:38:11 HD Request # 9 | Using server: ds6.sierracharts.com port 10149 | 2016-12-12 08:38:11 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-12-12 08:38:11 Socket (8) | Connected. | 2016-12-12 08:38:11 HD Request # 9 | Setting DTC encoding to Binary VLS | 2016-12-12 08:38:11 HD Request # 9 | Sending historical data logon request message. | 2016-12-12 08:38:11 HD Request # 9 | Requesting Intraday data. Start date-time: 2016-12-12 08:36:40. Record interval: 0. Symbol: HEG17 | 2016-12-12 08:38:11 HD Request # 9 | Decompressing data. | 2016-12-12 08:38:11 Socket (8) | Shutdown and closed. | 2016-12-12 08:38:11 The network socket for historical data has been closed. | 2016-12-12 08:38:11 HD Request # 9 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for HEG7-CME | 2016-12-12 08:38:11 HD Request # 9 | Intraday download COMPLETE for HEG7-CME. Completion time: 0s. Unique request ID: 9 | 2016-12-12 08:38:11 Removed historical data download ID 9 | 2016-12-12 08:38:11 Real-time Intraday chart data file updates started for hEg7-CME | 2016-12-12 08:38:11 Intraday chart data file opened for hEg7-CME | 2016-12-12 08:38:11 Rithmic Trading | Using primary service for historical data for HEG7-CME | 2016-12-12 08:38:11 Intraday data recording state for symbol HEG7-CME is set to download 'Pending'. | 2016-12-12 08:38:11 Market data subscription status is not known while delaying historical data download for symbol: LEZ6-HEZ6-CME | 2016-12-12 08:38:11 HD Request # 10 | Downloading Intraday chart data for LEj7-CME to the file LEj7-CME.scid. Service: cme | 2016-12-12 08:38:11 HD Request # 10 | Download start date-time: 2016-12-12 08:36:39.000 | 2016-12-12 08:38:11 HD Request # 10 | Using server: ds1.sierracharts.com port 10149 | 2016-12-12 08:38:11 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-12-12 08:38:11 Socket (9) | Connected. | 2016-12-12 08:38:11 HD Request # 10 | Setting DTC encoding to Binary VLS | 2016-12-12 08:38:11 HD Request # 10 | Sending historical data logon request message. | 2016-12-12 08:38:11 HD Request # 10 | Requesting Intraday data. Start date-time: 2016-12-12 08:36:39. Record interval: 0. Symbol: LEJ17 | 2016-12-12 08:38:11 HD Request # 10 | Decompressing data. | 2016-12-12 08:38:12 Socket (9) | Shutdown and closed. | 2016-12-12 08:38:12 The network socket for historical data has been closed. | 2016-12-12 08:38:12 HD Request # 10 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for LEj7-CME | 2016-12-12 08:38:12 HD Request # 10 | Intraday download COMPLETE for LEj7-CME. Completion time: 0s. Unique request ID: 16 | 2016-12-12 08:38:12 Removed historical data download ID 16 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for LEj7-CME | 2016-12-12 08:38:12 Intraday chart data file opened for LEj7-CME | 2016-12-12 08:38:12 Rithmic Trading | Using primary service for historical data for LEj7-CME | 2016-12-12 08:38:12 Intraday data recording state for symbol LEj7-CME is set to download 'Pending'. | 2016-12-12 08:38:12 Market data subscription status is not known while delaying historical data download for symbol: LEZ6-HEZ6-CME | 2016-12-12 08:38:12 HD Request # 11 | Downloading Intraday chart data for LEq7-CME to the file LEq7-CME.scid. Service: cme | 2016-12-12 08:38:12 HD Request # 11 | Download start date-time: 2016-12-12 08:35:38.000 | 2016-12-12 08:38:12 HD Request # 11 | Using server: ds6.sierracharts.com port 10149 | 2016-12-12 08:38:12 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-12-12 08:38:12 Socket (10) | Connected. | 2016-12-12 08:38:12 HD Request # 11 | Setting DTC encoding to Binary VLS | 2016-12-12 08:38:12 HD Request # 11 | Sending historical data logon request message. | 2016-12-12 08:38:12 HD Request # 11 | Requesting Intraday data. Start date-time: 2016-12-12 08:35:38. Record interval: 0. Symbol: LEQ17 | 2016-12-12 08:38:12 HD Request # 11 | Decompressing data. | 2016-12-12 08:38:12 Socket (10) | Shutdown and closed. | 2016-12-12 08:38:12 The network socket for historical data has been closed. | 2016-12-12 08:38:12 HD Request # 11 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for LEq7-CME | 2016-12-12 08:38:12 HD Request # 11 | Intraday download COMPLETE for LEq7-CME. Completion time: 0s. Unique request ID: 17 | 2016-12-12 08:38:12 Removed historical data download ID 17 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for LEq7-CME | 2016-12-12 08:38:12 Intraday chart data file opened for LEq7-CME | 2016-12-12 08:38:12 Rithmic Trading | Using primary service for historical data for LEq7-CME | 2016-12-12 08:38:12 Intraday data recording state for symbol LEq7-CME is set to download 'Pending'. | 2016-12-12 08:38:12 Market data subscription status is not known while delaying historical data download for symbol: LEZ6-HEZ6-CME | 2016-12-12 08:38:12 HD Request # 12 | Downloading Intraday chart data for LEZ6-HEZ6-CME to the file LEZ6-HEZ6-CME.scid. Service: rim | 2016-12-12 08:38:12 HD Request # 12 | Download start date-time: 2016-12-05 10:56:32.000 | 2016-12-12 08:38:12 HD Request # 12 | Sending historical data request. Start date-time: 2016-12-05 10:56:32. Record interval: 0. Symbol: LEZ6-HEZ6-CME | 2016-12-12 08:38:12 HD Request # 13 | Downloading Intraday chart data for LEm7-CME to the file LEm7-CME.scid. Service: cme | 2016-12-12 08:38:12 HD Request # 13 | Download start date-time: 2016-12-12 08:36:39.000 | 2016-12-12 08:38:12 HD Request # 13 | Using server: ds1.sierracharts.com port 10149 | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-12 08:38:12 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-12-12 08:38:12 Socket (11) | Connected. | 2016-12-12 08:38:12 HD Request # 13 | Setting DTC encoding to Binary VLS | 2016-12-12 08:38:12 HD Request # 13 | Sending historical data logon request message. | 2016-12-12 08:38:12 HD Request # 13 | Requesting Intraday data. Start date-time: 2016-12-12 08:36:39. Record interval: 0. Symbol: LEM17 | 2016-12-12 08:38:12 HD Request # 12 | Error downloading historical Intraday data for LEZ6-HEZ6-CME. Error downloading historical Minute data. Error: bad input | 2016-12-12 08:38:12 HD Request # 12 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for LEZ6-HEZ6-CME | 2016-12-12 08:38:12 HD Request # 12 | Intraday download COMPLETE for LEZ6-HEZ6-CME. Completion time: 0s. Unique request ID: 6 | 2016-12-12 08:38:12 Removed historical data download ID 6 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for LEZ6-HEZ6-CME | 2016-12-12 08:38:12 Intraday chart data file opened for LEZ6-HEZ6-CME | 2016-12-12 08:38:12 HD Request # 14 | Downloading Intraday chart data for gfx6-gff7-CME to the file gfx6-gff7-CME.scid. Service: rim | 2016-12-12 08:38:12 HD Request # 14 | Download start date-time: 2016-11-17 11:59:54.000 | 2016-12-12 08:38:12 HD Request # 14 | Sending historical data request. Start date-time: 2016-11-17 11:59:54. Record interval: 0. Symbol: gfx6-gff7-CME | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-12 08:38:12 HD Request # 14 | Error downloading historical Intraday data for gfx6-gff7-CME. Error requesting historical Minute data. Error: API_NO_DATA | 2016-12-12 08:38:12 HD Request # 14 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for gfx6-gff7-CME | 2016-12-12 08:38:12 HD Request # 14 | Intraday download COMPLETE for gfx6-gff7-CME. Completion time: 0s. Unique request ID: 8 | 2016-12-12 08:38:12 Removed historical data download ID 8 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for gfx6-gff7-CME | 2016-12-12 08:38:12 Intraday chart data file opened for gfx6-gff7-CME | 2016-12-12 08:38:12 HD Request # 15 | Downloading Intraday chart data for heZ6-heg7-CME to the file heZ6-heg7-CME.scid. Service: rim | 2016-12-12 08:38:12 HD Request # 15 | Download start date-time: 2016-12-12 08:36:19.000 | 2016-12-12 08:38:12 HD Request # 15 | Sending historical data request. Start date-time: 2016-12-12 08:36:19. Record interval: 0. Symbol: heZ6-heg7-CME | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-12 08:38:12 HD Request # 15 | Error downloading historical Intraday data for heZ6-heg7-CME. Error downloading historical Minute data. Error: bad input | 2016-12-12 08:38:12 HD Request # 15 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for heZ6-heg7-CME | 2016-12-12 08:38:12 HD Request # 15 | Intraday download COMPLETE for heZ6-heg7-CME. Completion time: 0s. Unique request ID: 11 | 2016-12-12 08:38:12 Removed historical data download ID 11 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for hEz6-heg7-CME | 2016-12-12 08:38:12 Intraday chart data file opened for hEz6-heg7-CME | 2016-12-12 08:38:12 HD Request # 16 | Downloading Intraday chart data for leZ6-leg7-CME to the file leZ6-leg7-CME.scid. Service: rim | 2016-12-12 08:38:12 HD Request # 16 | Download start date-time: 2016-12-12 08:36:28.000 | 2016-12-12 08:38:12 HD Request # 16 | Sending historical data request. Start date-time: 2016-12-12 08:36:28. Record interval: 0. Symbol: leZ6-leg7-CME | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-12 08:38:12 HD Request # 16 | Error downloading historical Intraday data for leZ6-leg7-CME. Error downloading historical Minute data. Error: bad input | 2016-12-12 08:38:12 HD Request # 16 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for leZ6-leg7-CME | 2016-12-12 08:38:12 HD Request # 16 | Receiving Intraday data for leZ6-leg7-CME starting at 2016-12-12 08:38:07 | 2016-12-12 08:38:12 HD Request # 16 | Timestamp of first Intraday data file record written: 2016-12-12 08:38:07 | 2016-12-12 08:38:12 Added 2 Time and Sales records to Intraday data file for LEZ6-LEG7-CME after download. | 2016-12-12 08:38:12 HD Request # 16 | Intraday download COMPLETE for leZ6-leg7-CME. Completion time: 0s. Unique request ID: 12 | 2016-12-12 08:38:12 Removed historical data download ID 12 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for LEZ6-LEG7-CME | 2016-12-12 08:38:12 Intraday chart data file opened for LEZ6-LEG7-CME | 2016-12-12 08:38:12 HD Request # 17 | Downloading Intraday chart data for leg7-lem7-CME to the file leg7-lem7-CME.scid. Service: rim | 2016-12-12 08:38:12 HD Request # 17 | Download start date-time: 2016-12-12 08:36:28.000 | 2016-12-12 08:38:12 HD Request # 17 | Sending historical data request. Start date-time: 2016-12-12 08:36:28. Record interval: 0. Symbol: leg7-lem7-CME | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-12 08:38:12 HD Request # 17 | Error downloading historical Intraday data for leg7-lem7-CME. Error downloading historical Minute data. Error: bad input | 2016-12-12 08:38:12 HD Request # 17 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for leg7-lem7-CME | 2016-12-12 08:38:12 HD Request # 17 | Intraday download COMPLETE for leg7-lem7-CME. Completion time: 0s. Unique request ID: 13 | 2016-12-12 08:38:12 Removed historical data download ID 13 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for leg7-lem7-CME | 2016-12-12 08:38:12 Intraday chart data file opened for leg7-lem7-CME | 2016-12-12 08:38:12 HD Request # 18 | Downloading Intraday chart data for leg7-lej7-CME to the file leg7-lej7-CME.scid. Service: rim | 2016-12-12 08:38:12 HD Request # 18 | Download start date-time: 2016-12-12 08:36:39.000 | 2016-12-12 08:38:12 HD Request # 18 | Sending historical data request. Start date-time: 2016-12-12 08:36:39. Record interval: 0. Symbol: leg7-lej7-CME | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-12 08:38:12 HD Request # 18 | Error downloading historical Intraday data for leg7-lej7-CME. Error downloading historical Minute data. Error: bad input | 2016-12-12 08:38:12 HD Request # 18 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for leg7-lej7-CME | 2016-12-12 08:38:12 HD Request # 18 | Receiving Intraday data for leg7-lej7-CME starting at 2016-12-12 08:38:06 | 2016-12-12 08:38:12 HD Request # 18 | Timestamp of first Intraday data file record written: 2016-12-12 08:38:06 | 2016-12-12 08:38:12 Added 3 Time and Sales records to Intraday data file for LEG7-LEJ7-CME after download. | 2016-12-12 08:38:12 HD Request # 18 | Intraday download COMPLETE for leg7-lej7-CME. Completion time: 0s. Unique request ID: 14 | 2016-12-12 08:38:12 Removed historical data download ID 14 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for LEG7-LEJ7-CME | 2016-12-12 08:38:12 Intraday chart data file opened for LEG7-LEJ7-CME | 2016-12-12 08:38:12 HD Request # 19 | Downloading Intraday chart data for lej7-lem7-CME to the file lej7-lem7-CME.scid. Service: rim | 2016-12-12 08:38:12 HD Request # 19 | Download start date-time: 2016-12-12 08:36:39.000 | 2016-12-12 08:38:12 HD Request # 19 | Sending historical data request. Start date-time: 2016-12-12 08:36:39. Record interval: 0. Symbol: lej7-lem7-CME | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-12 08:38:12 HD Request # 19 | Error downloading historical Intraday data for lej7-lem7-CME. Error downloading historical Minute data. Error: bad input | 2016-12-12 08:38:12 HD Request # 19 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for lej7-lem7-CME | 2016-12-12 08:38:12 HD Request # 19 | Receiving Intraday data for lej7-lem7-CME starting at 2016-12-12 08:38:11 | 2016-12-12 08:38:12 HD Request # 19 | Timestamp of first Intraday data file record written: 2016-12-12 08:38:11 | 2016-12-12 08:38:12 Added 2 Time and Sales records to Intraday data file for lej7-lem7-CME after download. | 2016-12-12 08:38:12 HD Request # 19 | Intraday download COMPLETE for lej7-lem7-CME. Completion time: 0s. Unique request ID: 15 | 2016-12-12 08:38:12 Removed historical data download ID 15 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for lej7-lem7-CME | 2016-12-12 08:38:12 Intraday chart data file opened for lej7-lem7-CME | 2016-12-12 08:38:12 HD Request # 20 | Downloading Intraday chart data for GFF7-CME to the file GFF7-CME.scid. Service: rim | 2016-12-12 08:38:12 HD Request # 20 | Download start date-time: 2016-12-12 08:35:51.000 | 2016-12-12 08:38:12 HD Request # 20 | Sending historical data request. Start date-time: 2016-12-12 08:35:51. Record interval: 0. Symbol: GFF7-CME | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-12-12 08:38:12 HD Request # 20 | Receiving Intraday data for GFF7-CME starting at 2016-12-12 08:35:51 | 2016-12-12 08:38:12 HD Request # 20 | Timestamp of first Intraday data file record written: 2016-12-12 08:36:54 | 2016-12-12 08:38:12 HD Request # 20 | Received 118 records from 2016-12-12 08:35:51 to 2016-12-12 08:38:10 (2.3 minutes) and wrote 117 records for GFF7-CME | 2016-12-12 08:38:12 HD Request # 13 | Decompressing data. | 2016-12-12 08:38:12 HD Request # 20 | Intraday download COMPLETE for GFF7-CME. Completion time: 0s. Unique request ID: 21 | 2016-12-12 08:38:12 Socket (11) | Shutdown and closed. | 2016-12-12 08:38:12 The network socket for historical data has been closed. | 2016-12-12 08:38:12 Removed historical data download ID 21 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for GFF7-CME | 2016-12-12 08:38:12 Intraday chart data file opened for GFF7-CME | 2016-12-12 08:38:12 HD Request # 13 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for LEm7-CME | 2016-12-12 08:38:12 HD Request # 13 | Intraday download COMPLETE for LEm7-CME. Completion time: 0s. Unique request ID: 18 | 2016-12-12 08:38:12 Removed historical data download ID 18 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for LEm7-CME | 2016-12-12 08:38:12 Intraday chart data file opened for LEm7-CME | 2016-12-12 08:38:12 Rithmic Trading | Using primary service for historical data for LEm7-CME | 2016-12-12 08:38:12 Intraday data recording state for symbol LEm7-CME is set to download 'Pending'. | 2016-12-12 08:38:12 HD Request # 21 | Downloading Intraday chart data for LEg7-CME to the file LEg7-CME.scid. Service: rim | 2016-12-12 08:38:12 HD Request # 21 | Download start date-time: 2016-12-12 08:36:39.000 | 2016-12-12 08:38:12 HD Request # 21 | Sending historical data request. Start date-time: 2016-12-12 08:36:39. Record interval: 0. Symbol: LEg7-CME | 2016-12-12 08:38:12 HD Request # 22 | Downloading Intraday chart data for hem7-CME to the file hem7-CME.scid. Service: cme | 2016-12-12 08:38:12 HD Request # 22 | Download start date-time: 2016-12-12 08:36:35.000 | 2016-12-12 08:38:12 HD Request # 22 | Using server: ds6.sierracharts.com port 10149 | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-12-12 08:38:12 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-12-12 08:38:12 Socket (12) | Connected. | 2016-12-12 08:38:12 HD Request # 22 | Setting DTC encoding to Binary VLS | 2016-12-12 08:38:12 HD Request # 22 | Sending historical data logon request message. | 2016-12-12 08:38:12 HD Request # 22 | Requesting Intraday data. Start date-time: 2016-12-12 08:36:35. Record interval: 0. Symbol: HEM17 | 2016-12-12 08:38:12 HD Request # 22 | Decompressing data. | 2016-12-12 08:38:12 Socket (12) | Shutdown and closed. | 2016-12-12 08:38:12 The network socket for historical data has been closed. | 2016-12-12 08:38:12 HD Request # 22 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for hem7-CME | 2016-12-12 08:38:12 HD Request # 22 | Intraday download COMPLETE for hem7-CME. Completion time: 0s. Unique request ID: 19 | 2016-12-12 08:38:12 Removed historical data download ID 19 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for hem7-CME | 2016-12-12 08:38:12 Intraday chart data file opened for hem7-CME | 2016-12-12 08:38:12 Rithmic Trading | Using primary service for historical data for hem7-CME | 2016-12-12 08:38:12 Intraday data recording state for symbol hem7-CME is set to download 'Pending'. | 2016-12-12 08:38:12 HD Request # 23 | Downloading Intraday chart data for hej7-CME to the file hej7-CME.scid. Service: cme | 2016-12-12 08:38:12 HD Request # 23 | Download start date-time: 2016-12-12 08:36:35.000 | 2016-12-12 08:38:12 HD Request # 23 | Using server: ds1.sierracharts.com port 10149 | 2016-12-12 08:38:12 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-12-12 08:38:12 Socket (13) | Connected. | 2016-12-12 08:38:12 HD Request # 23 | Setting DTC encoding to Binary VLS | 2016-12-12 08:38:12 HD Request # 23 | Sending historical data logon request message. | 2016-12-12 08:38:12 HD Request # 23 | Requesting Intraday data. Start date-time: 2016-12-12 08:36:35. Record interval: 0. Symbol: HEJ17 | 2016-12-12 08:38:12 HD Request # 21 | Receiving Intraday data for LEg7-CME starting at 2016-12-12 08:36:39 | 2016-12-12 08:38:12 HD Request # 21 | Timestamp of first Intraday data file record written: 2016-12-12 08:36:45 | 2016-12-12 08:38:12 HD Request # 21 | Received 593 records from 2016-12-12 08:36:39 to 2016-12-12 08:38:11 (92.0 seconds) and wrote 586 records for LEg7-CME | 2016-12-12 08:38:12 HD Request # 21 | Intraday download COMPLETE for LEg7-CME. Completion time: 0s. Unique request ID: 22 | 2016-12-12 08:38:12 Removed historical data download ID 22 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for LEG7-CME | 2016-12-12 08:38:12 Intraday chart data file opened for LEG7-CME | 2016-12-12 08:38:12 HD Request # 24 | Downloading Intraday chart data for HEG7-CME to the file HEG7-CME.scid. Service: rim | 2016-12-12 08:38:12 HD Request # 24 | Download start date-time: 2016-12-12 08:36:40.000 | 2016-12-12 08:38:12 HD Request # 24 | Sending historical data request. Start date-time: 2016-12-12 08:36:40. Record interval: 0. Symbol: HEG7-CME | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-12-12 08:38:12 HD Request # 24 | Receiving Intraday data for HEG7-CME starting at 2016-12-12 08:36:40 | 2016-12-12 08:38:12 HD Request # 24 | Timestamp of first Intraday data file record written: 2016-12-12 08:36:52 | 2016-12-12 08:38:12 HD Request # 24 | Received 83 records from 2016-12-12 08:36:40 to 2016-12-12 08:38:08 (88.0 seconds) and wrote 82 records for HEG7-CME | 2016-12-12 08:38:12 HD Request # 24 | Intraday download COMPLETE for HEG7-CME. Completion time: 0s. Unique request ID: 23 | 2016-12-12 08:38:12 Removed historical data download ID 23 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for hEg7-CME | 2016-12-12 08:38:12 Intraday chart data file opened for hEg7-CME | 2016-12-12 08:38:12 HD Request # 25 | Downloading Intraday chart data for LEj7-CME to the file LEj7-CME.scid. Service: rim | 2016-12-12 08:38:12 HD Request # 25 | Download start date-time: 2016-12-12 08:36:39.000 | 2016-12-12 08:38:12 HD Request # 25 | Sending historical data request. Start date-time: 2016-12-12 08:36:39. Record interval: 0. Symbol: LEj7-CME | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-12-12 08:38:12 HD Request # 25 | Receiving Intraday data for LEj7-CME starting at 2016-12-12 08:36:39 | 2016-12-12 08:38:12 HD Request # 25 | Timestamp of first Intraday data file record written: 2016-12-12 08:37:07 | 2016-12-12 08:38:12 HD Request # 25 | Received 169 records from 2016-12-12 08:36:39 to 2016-12-12 08:38:09 (90.0 seconds) and wrote 165 records for LEj7-CME | 2016-12-12 08:38:12 HD Request # 25 | Intraday download COMPLETE for LEj7-CME. Completion time: 0s. Unique request ID: 24 | 2016-12-12 08:38:12 Removed historical data download ID 24 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for LEj7-CME | 2016-12-12 08:38:12 Intraday chart data file opened for LEj7-CME | 2016-12-12 08:38:12 HD Request # 26 | Downloading Intraday chart data for LEq7-CME to the file LEq7-CME.scid. Service: rim | 2016-12-12 08:38:12 HD Request # 26 | Download start date-time: 2016-12-12 08:35:38.000 | 2016-12-12 08:38:12 HD Request # 26 | Sending historical data request. Start date-time: 2016-12-12 08:35:38. Record interval: 0. Symbol: LEq7-CME | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-12-12 08:38:12 HD Request # 23 | Decompressing data. | 2016-12-12 08:38:12 Socket (13) | Shutdown and closed. | 2016-12-12 08:38:12 The network socket for historical data has been closed. | 2016-12-12 08:38:12 HD Request # 23 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for hej7-CME | 2016-12-12 08:38:12 HD Request # 23 | Intraday download COMPLETE for hej7-CME. Completion time: 0s. Unique request ID: 20 | 2016-12-12 08:38:12 Removed historical data download ID 20 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for hej7-CME | 2016-12-12 08:38:12 Intraday chart data file opened for hej7-CME | 2016-12-12 08:38:12 Rithmic Trading | Using primary service for historical data for hej7-CME | 2016-12-12 08:38:12 Intraday data recording state for symbol hej7-CME is set to download 'Pending'. | 2016-12-12 08:38:12 HD Request # 26 | Receiving Intraday data for LEq7-CME starting at 2016-12-12 08:35:38 | 2016-12-12 08:38:12 HD Request # 26 | Timestamp of first Intraday data file record written: 2016-12-12 08:36:55 | 2016-12-12 08:38:12 HD Request # 26 | Received 35 records from 2016-12-12 08:35:38 to 2016-12-12 08:37:49 (2.2 minutes) and wrote 33 records for LEq7-CME | 2016-12-12 08:38:12 HD Request # 26 | Intraday download COMPLETE for LEq7-CME. Completion time: 0s. Unique request ID: 25 | 2016-12-12 08:38:12 Removed historical data download ID 25 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for LEq7-CME | 2016-12-12 08:38:12 Intraday chart data file opened for LEq7-CME | 2016-12-12 08:38:12 HD Request # 27 | Downloading Intraday chart data for LEm7-CME to the file LEm7-CME.scid. Service: rim | 2016-12-12 08:38:12 HD Request # 27 | Download start date-time: 2016-12-12 08:36:39.000 | 2016-12-12 08:38:12 HD Request # 27 | Sending historical data request. Start date-time: 2016-12-12 08:36:39. Record interval: 0. Symbol: LEm7-CME | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-12-12 08:38:12 HD Request # 27 | Receiving Intraday data for LEm7-CME starting at 2016-12-12 08:36:39 | 2016-12-12 08:38:12 HD Request # 27 | Timestamp of first Intraday data file record written: 2016-12-12 08:36:55 | 2016-12-12 08:38:12 HD Request # 27 | Received 126 records from 2016-12-12 08:36:39 to 2016-12-12 08:38:03 (84.0 seconds) and wrote 124 records for LEm7-CME | 2016-12-12 08:38:12 HD Request # 27 | Intraday download COMPLETE for LEm7-CME. Completion time: 0s. Unique request ID: 26 | 2016-12-12 08:38:12 Removed historical data download ID 26 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for LEm7-CME | 2016-12-12 08:38:12 Intraday chart data file opened for LEm7-CME | 2016-12-12 08:38:12 HD Request # 28 | Downloading Intraday chart data for hem7-CME to the file hem7-CME.scid. Service: rim | 2016-12-12 08:38:12 HD Request # 28 | Download start date-time: 2016-12-12 08:36:35.000 | 2016-12-12 08:38:12 HD Request # 28 | Sending historical data request. Start date-time: 2016-12-12 08:36:35. Record interval: 0. Symbol: hem7-CME | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-12-12 08:38:12 HD Request # 28 | Receiving Intraday data for hem7-CME starting at 2016-12-12 08:36:35 | 2016-12-12 08:38:12 HD Request # 28 | Timestamp of first Intraday data file record written: 2016-12-12 08:36:45 | 2016-12-12 08:38:12 HD Request # 28 | Received 12 records from 2016-12-12 08:36:35 to 2016-12-12 08:38:07 (92.0 seconds) and wrote 11 records for hem7-CME | 2016-12-12 08:38:12 HD Request # 28 | Intraday download COMPLETE for hem7-CME. Completion time: 0s. Unique request ID: 27 | 2016-12-12 08:38:12 Removed historical data download ID 27 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for hem7-CME | 2016-12-12 08:38:12 Intraday chart data file opened for hem7-CME | 2016-12-12 08:38:12 HD Request # 29 | Downloading Intraday chart data for hej7-CME to the file hej7-CME.scid. Service: rim | 2016-12-12 08:38:12 HD Request # 29 | Download start date-time: 2016-12-12 08:36:35.000 | 2016-12-12 08:38:12 HD Request # 29 | Sending historical data request. Start date-time: 2016-12-12 08:36:35. Record interval: 0. Symbol: hej7-CME | 2016-12-12 08:38:12 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-12-12 08:38:12 HD Request # 29 | Receiving Intraday data for hej7-CME starting at 2016-12-12 08:36:35 | 2016-12-12 08:38:12 HD Request # 29 | Timestamp of first Intraday data file record written: 2016-12-12 08:36:45 | 2016-12-12 08:38:12 HD Request # 29 | Received 14 records from 2016-12-12 08:36:35 to 2016-12-12 08:38:05 (90.0 seconds) and wrote 13 records for hej7-CME | 2016-12-12 08:38:12 HD Request # 29 | Intraday download COMPLETE for hej7-CME. Completion time: 0s. Unique request ID: 28 | 2016-12-12 08:38:12 Removed historical data download ID 28 | 2016-12-12 08:38:12 Real-time Intraday chart data file updates started for hej7-CME | 2016-12-12 08:38:12 Intraday chart data file opened for hej7-CME | 2016-12-12 08:38:12 Opened cached Intraday file: C:\SierraChart\Data\hEz6-heg7-CME.scid | 2016-12-12 08:38:19 Opened cached Intraday file: C:\SierraChart\Data\LEG7-LEJ7-CME.scid | 2016-12-12 08:38:19 Opened cached Intraday file: C:\SierraChart\Data\LEG7-CME.scid | 2016-12-12 08:38:19 Opened cached Intraday file: C:\SierraChart\Data\hEg7-CME.scid | 2016-12-12 08:38:19 Opened cached Intraday file: C:\SierraChart\Data\lej7-lem7-CME.scid | 2016-12-12 08:38:19 Opened cached Intraday file: C:\SierraChart\Data\LEj7-CME.scid | 2016-12-12 08:38:19 Opened cached Intraday file: C:\SierraChart\Data\LEm7-CME.scid | 2016-12-12 08:38:19 Opened cached Intraday file: C:\SierraChart\Data\hem7-CME.scid | 2016-12-12 08:38:19 Opened cached Intraday file: C:\SierraChart\Data\GFF7-CME.scid | 2016-12-12 08:38:29 Opened cached Intraday file: C:\SierraChart\Data\leg7-lem7-CME.scid | 2016-12-12 08:38:29 Opened cached Intraday file: C:\SierraChart\Data\LEq7-CME.scid | 2016-12-12 08:38:29 Opened cached Intraday file: C:\SierraChart\Data\LEZ6-LEG7-CME.scid | 2016-12-12 08:38:39 Opened cached Intraday file: C:\SierraChart\Data\hej7-CME.scid | 2016-12-12 08:38:49 HTTP connection to ds01.ddfplus.com:80 (5) | Closed. No error. | 2016-12-12 08:39:13 HTTP connection to ds01.ddfplus.com:80 (5) | Shutdown and closed. | 2016-12-12 08:39:13 LEg7-lej7-CME 1 Sec #9 | Reloading chart. | 2016-12-12 09:03:37 Requesting market depth updates for: LEG7-LEJ7-CME if supported. | 2016-12-12 09:03:38 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\LEG7-LEJ7-CME.2016-12-12.depth | 2016-12-12 09:03:38 lej7-lem7-CME Daily #11 | Reloading chart. | 2016-12-12 09:07:45 lej7-lem7-CME Daily #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\lej7-lem7-CME.dly | 2016-12-12 09:07:45 HD Request # 30 | Downloading Historical Daily chart data for lej7-lem7-CME. Starting date: 1966-12-13. Service: rim | 2016-12-12 09:07:46 HD Request # 30 | Requesting historical Daily data for lej7-lem7-CME starting at 1966-12-12 | 2016-12-12 09:07:46 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-12-12 09:07:46 HTTP connection to ds01.ddfplus.com:80 (29) | Connected. | 2016-12-12 09:07:46 HD Request # 30 | Error downloading historical Daily data for lej7-lem7-CME. Error executing query: Invalid symbol | 2016-12-12 09:07:47 HD Request # 30 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for lej7-lem7-CME | 2016-12-12 09:07:47 HD Request # 30 | Daily download COMPLETE for lej7-lem7-CME. Completion time: 0s. Unique request ID: 29 | 2016-12-12 09:07:47 Removed historical data download ID 29 | 2016-12-12 09:07:47 lej7-lem7-CME Daily #11 | Reloading chart. | 2016-12-12 09:07:47 lej7-lem7-CME Daily #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\lej7-lem7-CME.dly | 2016-12-12 09:07:47 lej7-lem7-CME 1 Min #11 | Reloading chart. | 2016-12-12 09:07:47 lej7-lem7-CME 5 Min #11 | Reloading chart. | 2016-12-12 09:07:49 lej7-lem7-CME 10 Min #11 | Reloading chart. | 2016-12-12 09:07:51 lej7-lem7-CME 30 Min #11 | Reloading chart. | 2016-12-12 09:07:51 lej7-lem7-CME 60 Min #11 | Reloading chart. | 2016-12-12 09:07:52 HTTP connection to ds01.ddfplus.com:80 (29) | Closed. No error. | 2016-12-12 09:08:52 HTTP connection to ds01.ddfplus.com:80 (29) | Shutdown and closed. | 2016-12-12 09:08:52 Rithmic Trading | Message from server: Received unknown message type from local socket. Type = 504 | 2016-12-12 09:11:15 lej7-lem7-CME 1 Day #11 | Reloading chart. | 2016-12-12 09:12:49 Rithmic Trading | Using primary service for historical data for lej7-lem7-CME | 2016-12-12 09:13:21 Intraday data recording state for symbol lej7-lem7-CME is set to download 'Pending'. | 2016-12-12 09:13:21 HD Request # 31 | Downloading Intraday chart data for lej7-lem7-CME to the file lej7-lem7-CME.scid. Service: rim | 2016-12-12 09:13:21 HD Request # 31 | Download start date-time: 2016-10-31 18:59:59.000 | 2016-12-12 09:13:21 HD Request # 31 | Disabling Intraday chart updating for symbol during historical data download. | 2016-12-12 09:13:21 HD Request # 31 | Sending historical data request. Start date-time: 2016-10-31 18:59:59. Record interval: 0. Symbol: lej7-lem7-CME | 2016-12-12 09:13:21 Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-12 09:13:21 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-12 09:13:21 HD Request # 31 | Error downloading historical Intraday data for lej7-lem7-CME. Error downloading historical Minute data. Error: bad input | 2016-12-12 09:13:21 HD Request # 31 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for lej7-lem7-CME | 2016-12-12 09:13:21 HD Request # 31 | Intraday download COMPLETE for lej7-lem7-CME. Completion time: 0s. Unique request ID: 30 | 2016-12-12 09:13:21 Removed historical data download ID 30 | 2016-12-12 09:13:21 Real-time Intraday chart data file updates started for lej7-lem7-CME | 2016-12-12 09:13:21 Intraday chart data file opened for lej7-lem7-CME | 2016-12-12 09:13:21 HD Request # 31 | Enabling Intraday chart updating for symbol. | 2016-12-12 09:13:21 Opened cached Intraday file: C:\SierraChart\Data\lej7-lem7-CME.scid | 2016-12-12 09:13:39 lem7-leq7-CME 1 Day #11 | Reloading chart. | 2016-12-12 09:14:43 lem7-leq7-CME 1 Day #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\lem7-leq7-CME.scid | 2016-12-12 09:14:43 Rithmic Trading | Starting real-time market data updates for: lem7-leq7-CME. ID: 22 | 2016-12-12 09:14:43 Rithmic Trading | Requesting security definition data for: lem7-leq7-CME. ID: 22 | 2016-12-12 09:14:43 Rithmic Trading | Using primary service for historical data for lem7-leq7-CME | 2016-12-12 09:14:43 Intraday data recording state for symbol lem7-leq7-CME is set to download 'Pending'. | 2016-12-12 09:14:43 Market data subscription status is not known while delaying historical data download for symbol: lem7-leq7-CME | 2016-12-12 09:14:43 Delaying start of download for lem7-leq7-CME | 2016-12-12 09:14:43 Delaying start of download for lem7-leq7-CME | 2016-12-12 09:14:44 HD Request # 32 | Downloading Intraday chart data for lem7-leq7-CME to the file lem7-leq7-CME.scid. Service: rim | 2016-12-12 09:14:48 Compressing file: C:\SierraChart\Data\lem7-leq7-CME.scid. This may take a while. | 2016-12-12 09:14:48 HD Request # 32 | Download start date-time: 2016-06-09 10:14:48.000 | 2016-12-12 09:14:48 HD Request # 32 | Sending historical data request. Start date-time: 2016-06-09 10:14:48. Record interval: 0. Symbol: lem7-leq7-CME | 2016-12-12 09:14:48 Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-12 09:14:48 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-12 09:14:48 HD Request # 32 | Error downloading historical Intraday data for lem7-leq7-CME. Error downloading historical Minute data. Error: bad input | 2016-12-12 09:14:48 HD Request # 32 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for lem7-leq7-CME | 2016-12-12 09:14:48 HD Request # 32 | Intraday download COMPLETE for lem7-leq7-CME. Completion time: 0s. Unique request ID: 31 | 2016-12-12 09:14:48 Removed historical data download ID 31 | 2016-12-12 09:14:48 Real-time Intraday chart data file updates started for lem7-leq7-CME | 2016-12-12 09:14:48 Intraday chart data file opened for lem7-leq7-CME | 2016-12-12 09:14:48 |
[2016-12-12 15:54:15] |
This is the relevant message: HD Request # 32 | Error downloading historical Intraday data for lem7-leq7-CME. Error downloading historical Minute data. Error: bad input This problem has been resolved. Update Sierra Chart to the latest prerelease following these instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate After the update re-download the data in the chart with Edit >>Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-12 17:06:34] |
User17036 - Posts: 8 |
thank you i have done that still isnt coming up. thanks |
[2016-12-12 17:17:01] |
Tell us one of the specific symbols you are having a problem with. For spreads you can only receive Intraday data. Not Historical Daily data. Restart Sierra Chart and provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-12 17:26:53] |
Reading Internal Order ID file. | 2016-12-12 11:23:21 Reading Trade Orders file. | 2016-12-12 11:23:21 Reading Trade Positions file. | 2016-12-12 11:23:21 Software version: 1495 | 2016-12-12 11:23:21 Uses New Spreadsheets | 2016-12-12 11:23:21 Usage end date: 2017-01-01 | 2016-12-12 11:23:21 Enabled for: Advanced Features. | 2016-12-12 11:23:21 Enabled for: Advanced Features 2. | 2016-12-12 11:23:21 Enabled for: Sierra Chart Historical Data Service. | 2016-12-12 11:23:21 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-12-12 11:23:21 Current selected Data/Trading service: Rithmic Trading | 2016-12-12 11:23:21 Chart Update Interval: 500 | 2016-12-12 11:23:21 Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-12-12 11:23:21 2016-12-12 11:23:25 Local computer time | 2016-12-12 11:23:21 2016-12-12 17:23:25 Local computer time in UTC | 2016-12-12 11:23:21 2016-12-12 11:23:25 Local computer time in SC Time Zone | 2016-12-12 11:23:21 2016-12-12 17:23:24 Server time in UTC | 2016-12-12 11:23:21 Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-12-12 11:23:21 Program path: C:\SierraChart\ | 2016-12-12 11:23:21 Data Files path: C:\SierraChart\Data\ | 2016-12-12 11:23:21 OS Version Number: 6.2 | 2016-12-12 11:23:21 Locale Setting: C | 2016-12-12 11:23:21 Checking for new symbol settings for rim | 2016-12-12 11:23:21 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-12-12 11:23:21 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-12-12 11:23:21 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-12-12 11:23:21 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-12-12 11:23:21 Symbol settings are up-to-date for rim | 2016-12-12 11:23:26 Rithmic Trading | Port for executable: 64568 | 2016-12-12 11:23:30 Listening socket (960), port 64568 | Closed. | 2016-12-12 11:23:30 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-12-12 11:23:30 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-12-12 11:23:31 HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-12-12 11:23:31 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-12-12 11:23:31 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-12-12 11:23:31 Rithmic Trading | Connecting to the server 127.0.0.1. Port 64568 | 2016-12-12 11:23:32 Socket (4) | Connected. | 2016-12-12 11:23:32 Rithmic Trading | Connected to server. | 2016-12-12 11:23:32 Rithmic Trading | Sending Encoding Request to server | 2016-12-12 11:23:32 Rithmic Trading | Setting DTC encoding to Binary VLS | 2016-12-12 11:23:33 Rithmic Trading | Sending logon request message. | 2016-12-12 11:23:33 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-12-12 11:23:33 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-12-12 11:23:33 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-12-12 11:23:33 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-12-12 11:23:33 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-12-12 11:23:33 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2016-12-12 11:23:33 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-12-12 11:23:33 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2016-12-12 11:23:33 Rithmic Trading | Message from server: subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2016-12-12 11:23:33 Rithmic Trading | Message from server: subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2016-12-12 11:23:33 Rithmic Trading | Message from server: subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2016-12-12 11:23:33 Rithmic Trading | Message from server: subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2016-12-12 11:23:33 Rithmic Trading | Message from server: subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2016-12-12 11:23:33 Rithmic Trading | Message from server: subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2016-12-12 11:23:33 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2016-12-12 11:23:33 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2016-12-12 11:23:33 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2016-12-12 11:23:33 Rithmic Trading | Received logon response. | 2016-12-12 11:23:33 Rithmic Trading | Server Name: SC DTC Bridge. | 2016-12-12 11:23:33 Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-12-12 11:23:33 Rithmic Trading | Successfully connected. IB='MarcusLaxgang'. | 2016-12-12 11:23:33 Rithmic Trading | Trading is supported. | 2016-12-12 11:23:33 Rithmic Trading | Order cancel and replace is supported. | 2016-12-12 11:23:33 Rithmic Trading | OCO Orders supported. | 2016-12-12 11:23:33 Rithmic Trading | Connected to data and trading server. | 2016-12-12 11:23:33 lem7-leq7-CME 1 Min #1 | Reloading chart. | 2016-12-12 11:23:47 Rithmic Trading | Starting real-time market data updates for: lem7-leq7-CME. ID: 1 | 2016-12-12 11:23:47 Rithmic Trading | Requesting security definition data for: lem7-leq7-CME. ID: 1 | 2016-12-12 11:23:47 Rithmic Trading | Using primary service for historical data for lem7-leq7-CME | 2016-12-12 11:23:47 Intraday data recording state for symbol lem7-leq7-CME is set to download 'Pending'. | 2016-12-12 11:23:47 Market data subscription status is not known while delaying historical data download for symbol: lem7-leq7-CME | 2016-12-12 11:23:47 Delaying start of download for lem7-leq7-CME | 2016-12-12 11:23:47 Delaying start of download for lem7-leq7-CME | 2016-12-12 11:23:48 lem7-leq7-CME 10 Min #1 | Reloading chart. | 2016-12-12 11:23:51 HD Request # 2 | Downloading Intraday chart data for lem7-leq7-CME to the file lem7-leq7-CME.scid. Service: rim | 2016-12-12 11:23:52 HD Request # 2 | Download start date-time: 2016-12-12 11:22:49.000 | 2016-12-12 11:23:52 HD Request # 2 | Sending historical data request. Start date-time: 2016-12-12 11:22:49. Record interval: 0. Symbol: lem7-leq7-CME | 2016-12-12 11:23:52 Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-12 11:23:52 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-12 11:23:52 HD Request # 2 | Error downloading historical Intraday data for lem7-leq7-CME. Error downloading historical Minute data. Error: bad input | 2016-12-12 11:23:52 HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for lem7-leq7-CME | 2016-12-12 11:23:52 HD Request # 2 | Intraday download COMPLETE for lem7-leq7-CME. Completion time: 0s. Unique request ID: 1 | 2016-12-12 11:23:52 Removed historical data download ID 1 | 2016-12-12 11:23:52 Real-time Intraday chart data file updates started for lem7-leq7-CME | 2016-12-12 11:23:52 Intraday chart data file opened for lem7-leq7-CME | 2016-12-12 11:23:52 lem7-leq7-CME 10 Min #1 | Reloading chart. | 2016-12-12 11:24:18 lem7-leq7-CME 30 Min #1 | Reloading chart. | 2016-12-12 11:24:20 lem7-leq7-CME 5 Min #1 | Reloading chart. | 2016-12-12 11:24:21 Opened cached Intraday file: C:\SierraChart\Data\lem7-leq7-CME.scid | 2016-12-12 11:24:36 lem7-leq7-CME Daily #1 | Reloading chart. | 2016-12-12 11:24:38 lem7-leq7-CME Daily #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\lem7-leq7-CME.dly | 2016-12-12 11:24:38 HD Request # 3 | Downloading Historical Daily chart data for lem7-leq7-CME. Starting date: 1966-12-13. Service: rim | 2016-12-12 11:24:38 HD Request # 3 | Requesting historical Daily data for lem7-leq7-CME starting at 1966-12-12 | 2016-12-12 11:24:38 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-12-12 11:24:38 HTTP connection to ds01.ddfplus.com:80 (5) | Connected. | 2016-12-12 11:24:38 HD Request # 3 | Error downloading historical Daily data for lem7-leq7-CME. Error executing query: Invalid symbol | 2016-12-12 11:24:39 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for lem7-leq7-CME | 2016-12-12 11:24:39 HD Request # 3 | Daily download COMPLETE for lem7-leq7-CME. Completion time: 0s. Unique request ID: 2 | 2016-12-12 11:24:39 Removed historical data download ID 2 | 2016-12-12 11:24:39 lem7-leq7-CME Daily #1 | Reloading chart. | 2016-12-12 11:24:39 lem7-leq7-CME Daily #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\lem7-leq7-CME.dly | 2016-12-12 11:24:39 HD Request # 4 | Downloading Historical Daily chart data for lem7-leq7-CME. Starting date: 1966-12-13. Service: rim | 2016-12-12 11:25:06 HD Request # 4 | Requesting historical Daily data for lem7-leq7-CME starting at 1966-12-12 | 2016-12-12 11:25:06 HD Request # 4 | Error downloading historical Daily data for lem7-leq7-CME. Error executing query: Invalid symbol | 2016-12-12 11:25:06 HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for lem7-leq7-CME | 2016-12-12 11:25:06 HD Request # 4 | Daily download COMPLETE for lem7-leq7-CME. Completion time: 0s. Unique request ID: 3 | 2016-12-12 11:25:06 Removed historical data download ID 3 | 2016-12-12 11:25:06 lem7-leq7-CME Daily #1 | Reloading chart. | 2016-12-12 11:25:07 lem7-leq7-CME Daily #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\lem7-leq7-CME.dly | 2016-12-12 11:25:07 |
[2016-12-12 17:48:30] |
We realize now what the problem is. The newest Rithmic bridge program was not released. We are releasing it now. Update with Help >> Download Prerelease. After the update re-download the data in the chart and you will receive the data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
