Date/Time: Sat, 11 Jan 2025 15:03:29 +0000
Volume chart modified by roll over
View Count: 846
[2016-12-12 14:41:11]
User832792 - Posts: 17
Hi.
Could you tell me why my chart is showing the daily opening marking vertical lines 7 days ahead, and how could I possibly get rid of it?
This has happened after I rolled to March17 contract on the ES. Also, the scrolling back feature doesn't go back further than two days?
I'm using the same settings as on the December16 contract without any issue. My data feed is Continuum by CQG.
Date Time Of Last Edit: 2016-12-12 14:45:14
image2016-12-12_0934.png / V - Attached On 2016-12-12 14:40:48 UTC - Size: 106.36 KB - 231 views
[2016-12-12 18:10:24]
Not sure what is drawing those vertical lines but probably you have Chart >> Vertical Grid enabled. So uncheck that.
For more historical data, refer to:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data
[2016-12-12 20:02:47]
Thanks, I understand. Truly, they are the daily vertical grid of the open. They were enabled before but weren't drawn so far ahead. What about the inability to scroll back in the contacts data?
Date Time Of Last Edit: 2016-12-12 20:03:34
[2016-12-12 20:50:45]
We have already answered your question.
Once again here is the response and this provides very detailed information about this kind of request:
The documentation explains that you will want to use the Continuous Futures Contract option.
Date Time Of Last Edit: 2016-12-12 20:51:19
