Date/Time: Sat, 11 Jan 2025 14:53:44 +0000
Change DOM price column width?
View Count: 1257
[2016-12-12 09:08:52] |
User305145 - Posts: 38 |
Hi, I wish to reduce the width of the price column in the DOM - make it take less space. Aside from chaning the font size, is there any way to change the price display, e.g. 6J: 0.0086255 into 6255? /Martin |
[2016-12-12 20:18:42] |
You cannot reduce the width and you cannot change the format unless you are willing to change the Multipliers: Chart Settings: Real-Time Price Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) But we recommend against it unless you understand what you are doing because we are not going to provide any help if there is a problem created by adjusting the multipliers. However, the documentation explains the subject completely. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-13 10:35:33] |
OK I'm using the VAP study to see the session profile - any adjustments I'd have to do here to get it to work? /Martin |
[2016-12-13 10:38:08] |
We do not understand the question. We have little idea what you are asking about. And there is no study named VAP. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-13 10:38:48
[2016-12-14 10:56:53] |
The study highlighted in red does not show up when I adjust the multipliers as per the documentation you linked to - how can I fix this? /Martin |
sc_letter printing in dom - Copy.jpg / V - Attached On 2016-12-14 10:56:40 UTC - Size: 89.55 KB - 290 views |
[2016-12-14 11:03:21] |
We are declining support for this. This is what we said previously: But we recommend against it unless you understand what you are doing because we are not going to provide any help if there is a problem created by adjusting the multipliers. However, the documentation explains the subject completely.
