Date/Time: Sat, 01 Mar 2025 14:33:29 +0000
Subtract price from Vwap?
View Count: 1358
[2016-12-11 22:05:53] |
jackbravo - Posts: 69 |
Hi, I'm trying to figure out a way to subtract LAST price from vwap. I tried using the Bar Difference study, but was only able to subtract one of the vwap bands from vwap. It would be a nice feature to be able to take the difference or ratio of price to any of the studies on the list. Does this exist? Thank you. |
[2016-12-12 00:35:21] |
Neo - Posts: 198 |
Yes, -Create a simple 1-period moving average over price -Use "Study Subgraphs Difference", select the SMA as input study 1, and VWAP band/VWAP as input study 2. A ratio could be calculated in a similar fashion using "Study Subgraphs Ratio" |
[2016-12-12 00:38:57] |
You need to use this study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s227 This is not needed: -Create a simple 1-period moving average over price
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-12 00:40:34
[2021-10-08 15:59:50] |
Sargon Petros - Posts: 57 |
Hello What study would this be? The link just takes me to the list of studies. Thank you |
[2021-10-08 16:58:02] |
John - SC Support - Posts: 38292 |
You need the Study Subgraphs Subtract/Difference as noted further up. The link is here: Study Subgraphs Subtract/Difference For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
