Date/Time: Sat, 11 Jan 2025 14:57:19 +0000
Can I close the program and when I back to open find everything exactly like I left it?
View Count: 755
[2016-12-11 17:18:12] |
Midnight - Posts: 6 |
I mean, I am working on a stock, for example at date January 2011, and I doing the same in another chartbook too in a date July 2014 on a future. When I close the program I lose the scroll position and the manually scale of everything and I have to put again every symbol on the date I was working. Is possible save all "as is" when I close the program, the scroll, scale...everything? |
[2016-12-11 20:02:28] |
No. The scroll position is not saved. Charts will always scroll to the very end when they are opened as part of a Chartbook. What we recommend you do is not close Sierra Chart in order for everything to be exactly identical. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
