Date/Time: Sat, 11 Jan 2025 15:03:28 +0000
Adding the ichimoku cloud study collection to My demo account
View Count: 1033
[2016-12-10 21:22:51] |
Zappy077 - Posts: 1 |
Got the Demo, Downloaded Ichimoku.StdyCollct and place file into data folder. I also checked to make sure the data file folder is actually C:\Program Files\Data\ in the General settings under global settings. Now I can't find it. Did I miss something? It is not in the analysis folder or any where I could think of. Is this not included in the demo account. Thanks, Ryan
[2016-12-10 21:50:10] |
We will not provide support when you have Sierra Chart installed in the Program Files folder. This might be the source of the problem. It must be installed in the standard location. What exactly do you mean by this?: Now I can't find it.
Do you mean it is not listed on the Analysis menu? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-10 21:50:27
