Date/Time: Sat, 11 Jan 2025 14:58:15 +0000
Custom tools using DTC
View Count: 1342
[2016-12-10 15:59:29] |
User710890 - Posts: 23 |
Hi, I was wondering if I have an instance of SierraChart/DTC server running, if I could write a custom tool/app that could hook up to this and send/receive data or orders. I'm assuming yes but wasn't sure if there was anything I overlooked. Thank you. |
[2016-12-10 16:22:10] |
Additionally, I mean making use of the DTC protocol, of course.
[2016-12-10 17:05:28] |
A DTC Client connected to the Sierra Chart DTC Server can receive data and send orders. Refer to: Table of Contents | (External Interfaces) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
