Date/Time: Tue, 15 Sep 2026 08:11:34 +0000
Check session start /end times
View Count: 2242
| [2013-08-03 13:42:59] |
| vectorTrader - Posts: 86 |
I would like to know if there is to check the session start/end times in a spreadsheet study. |
| [2013-08-03 16:49:42] |
| Sawtooth - Posts: 4352 |
The session times are outputted to J75 and J76 only on the Spreadsheet System for Trading study. It does not appear on the other two spreadsheet studies.
| [2013-08-04 22:40:37] |
Support, would you please consider also outputting the chart session times to the Spreadsheet Study and the Spreadsheet/System Alert studies?
| [2013-08-05 10:13:07] |
Yes. We will do this.
| [2013-08-05 10:20:21] |
| ganz - Posts: 1048 |
Hello SC Support. Is there a timeline to add non-CLR "Spreadsheet study" ? Thank you. |
| [2013-08-05 12:13:24] |
SC Support FYI: The latest revision v1004 non-CLR just crashes on Linux/Wine. with best regards |
| [2013-08-05 17:51:58] |
Non-CLR Spreadsheet studies should start to become available within the next 30 days. The crash problem should now be resolved in 1005. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
