Date/Time: Sat, 11 Jan 2025 15:02:44 +0000
Focus doesn't go back to Sierra Chart after Goto Datetime
View Count: 902
[2016-12-10 05:22:10] |
charlie - Posts: 8 |
When I have another app (ie. File Explorer) in the background with Sierra Chart in focus and "Goto Datetime" with keyboard shortcut Ctrl-Alt-G then press "Enter" on the keyboard, the focus goes to the File Explorer app instead of Sierra Chart. I'm not sure if there is a setting for this, but I've tried with two different computers and I can't figure it out. How do I set the focus always go back to Sierra Chart after the "Goto Datetime"? Thanks, charlie |
[2016-12-10 06:50:53] |
We have seen this behavior ourselves. We are not sure why it happens. It is some operating system level behavior, but we should be able to implement a solution for it and we will try to do that.
[2016-12-12 04:00:09] |
I tried looking up for any Windows behavior I could change for this, but didn't get anywhere yet. Thank you for your response and help. charlie |
