Date/Time: Sat, 11 Jan 2025 14:47:38 +0000
Problem with rithmic data
View Count: 770
[2016-12-09 21:14:04]
User18210 - Posts: 6
Problem is not resolved sierrachart still writes download failed.I proceeded Exactly the according to your instructions.Sierrachart 1480 and earlier does not have these problems.
Reading Internal Order ID file. | 2016-12-09 21:36:49
Reading Trade Orders file. | 2016-12-09 21:36:49
Reading Trade Positions file. | 2016-12-09 21:36:49
Software version: 1495 | 2016-12-09 21:36:49
Uses New Spreadsheets | 2016-12-09 21:36:49
Usage end date: 2017-07-11 | 2016-12-09 21:36:49
Enabled for: Advanced Features. | 2016-12-09 21:36:49
Enabled for: Sierra Chart Historical Data Service. | 2016-12-09 21:36:49
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-12-09 21:36:49
Current selected Data/Trading service: Rithmic Trading | 2016-12-09 21:36:49
Chart Update Interval: 500 | 2016-12-09 21:36:49
Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2016-12-09 21:36:49
2016-12-09 21:36:52 Local computer time | 2016-12-09 21:36:49
2016-12-09 20:36:52 Local computer time in UTC | 2016-12-09 21:36:49
2016-12-09 21:36:52 Local computer time in SC Time Zone | 2016-12-09 21:36:49
2016-12-09 20:36:50 Server time in UTC | 2016-12-09 21:36:49
Local computer UTC time and Server UTC time difference: 1 seconds. | 2016-12-09 21:36:49
Program path: C:\SierraChart\ | 2016-12-09 21:36:49
Data Files path: C:\SierraChart\Data\ | 2016-12-09 21:36:49
OS Version Number: 6.1 | 2016-12-09 21:36:49
Locale Setting: C | 2016-12-09 21:36:49
Checking for new symbol settings for rim | 2016-12-09 21:36:49
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-12-09 21:36:49
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-12-09 21:36:49
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-12-09 21:36:49
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-12-09 21:36:49
Symbol settings are up-to-date for rim | 2016-12-09 21:36:49
Rithmic Trading | Port for executable: 49698 | 2016-12-09 21:36:57
Listening socket (628), port 49698 | Closed. | 2016-12-09 21:36:57
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-12-09 21:36:57
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-12-09 21:36:57
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-12-09 21:36:57
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-12-09 21:36:57
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-12-09 21:36:57
Rithmic Trading | Connecting to the server 127.0.0.1. Port 49698 | 2016-12-09 21:36:59
Socket (4) | Connected. | 2016-12-09 21:36:59
Rithmic Trading | Connected to server. | 2016-12-09 21:36:59
Rithmic Trading | Sending Encoding Request to server | 2016-12-09 21:36:59
Rithmic Trading | Setting DTC encoding to Binary VLS | 2016-12-09 21:36:59
Rithmic Trading | Sending logon request message. | 2016-12-09 21:36:59
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-12-09 21:36:59
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-12-09 21:36:59
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-12-09 21:36:59
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-12-09 21:37:01
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-12-09 21:37:01
Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2016-12-09 21:37:02
Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-12-09 21:37:02
Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2016-12-09 21:37:03
Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2016-12-09 21:37:03
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2016-12-09 21:37:03
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2016-12-09 21:37:04
Rithmic Trading | Received logon response. | 2016-12-09 21:37:04
Rithmic Trading | Server Name: SC DTC Bridge. | 2016-12-09 21:37:04
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-12-09 21:37:04
Rithmic Trading | Successfully connected. IB='PatelFutures'. | 2016-12-09 21:37:04
Rithmic Trading | Trading is supported. | 2016-12-09 21:37:04
Rithmic Trading | Order cancel and replace is supported. | 2016-12-09 21:37:04
Rithmic Trading | OCO Orders supported. | 2016-12-09 21:37:04
Rithmic Trading | Connected to data and trading server. | 2016-12-09 21:37:04
TF FMZ0016!-NYBOT 1 Min #1 | Reloading chart. | 2016-12-09 21:37:23
Rithmic Trading | Starting real-time market data updates for: TF FMZ0016!-NYBOT. ID: 1 | 2016-12-09 21:37:23
Rithmic Trading | Requesting security definition data for: TF FMZ0016!-NYBOT. ID: 1 | 2016-12-09 21:37:23
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:37:23
Intraday data recording state for symbol TF FMZ0016!-NYBOT is set to download 'Pending'. | 2016-12-09 21:37:23
Market data subscription status is not known while delaying historical data download for symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:37:23
Delaying start of download for TF FMZ0016!-NYBOT | 2016-12-09 21:37:23
Delaying start of download for TF FMZ0016!-NYBOT | 2016-12-09 21:37:24
HD Request # 2 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: ice.us | 2016-12-09 21:37:29
HD Request # 2 | Download start date-time: 2016-12-09 21:36:33.000 | 2016-12-09 21:37:29
HD Request # 2 | Using server: ds6.sierracharts.com port 10149 | 2016-12-09 21:37:29
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-12-09 21:37:29
Socket (5) | Connected. | 2016-12-09 21:37:29
HD Request # 2 | Setting DTC encoding to Binary VLS | 2016-12-09 21:37:29
HD Request # 2 | Sending historical data logon request message. | 2016-12-09 21:37:29
HD Request # 2 | Requesting Intraday data. Start date-time: 2016-12-09 21:36:33. Record interval: 1. Symbol: RJZ16 | 2016-12-09 21:37:29
HD Request # 2 | Decompressing data. | 2016-12-09 21:37:30
Socket (5) | Shutdown and closed. | 2016-12-09 21:37:30
The network socket for historical data has been closed. | 2016-12-09 21:37:30
HD Request # 2 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMZ0016!-NYBOT | 2016-12-09 21:37:30
HD Request # 2 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 0s. Unique request ID: 1 | 2016-12-09 21:37:30
Removed historical data download ID 1 | 2016-12-09 21:37:30
Real-time Intraday chart data file updates started for TF FMZ0016!-NYBOT | 2016-12-09 21:37:30
Intraday chart data file opened for TF FMZ0016!-NYBOT | 2016-12-09 21:37:30
Rithmic Trading | Using primary service for historical data for TF FMZ0016!-NYBOT | 2016-12-09 21:37:30
Intraday data recording state for symbol TF FMZ0016!-NYBOT is set to download 'Pending'. | 2016-12-09 21:37:30
HD Request # 3 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: rim | 2016-12-09 21:37:30
HD Request # 3 | Download start date-time: 2016-12-09 21:36:33.000 | 2016-12-09 21:37:30
HD Request # 3 | Sending historical data request. Start date-time: 2016-12-09 21:36:33. Record interval: 0. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:37:30
Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-09 21:37:30
Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-09 21:37:30
HD Request # 3 | Error downloading historical Intraday data for TF FMZ0016!-NYBOT. Error downloading historical Minute data. Error: bad input | 2016-12-09 21:37:30
HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMZ0016!-NYBOT | 2016-12-09 21:37:30
HD Request # 3 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 0s. Unique request ID: 2 | 2016-12-09 21:37:30
Removed historical data download ID 2 | 2016-12-09 21:37:30
Opened cached Intraday file: C:\SierraChart\Data\TF FMZ0016!-NYBOT.scid | 2016-12-09 21:37:43
TF FMH0017!-NYBOT 1 Min #2 | Reloading chart. | 2016-12-09 21:44:23
TF FMH0017!-NYBOT 1 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TF FMH0017!-NYBOT.scid | 2016-12-09 21:44:23
Rithmic Trading | Starting real-time market data updates for: TF FMH0017!-NYBOT. ID: 2 | 2016-12-09 21:44:25
Rithmic Trading | Requesting security definition data for: TF FMH0017!-NYBOT. ID: 2 | 2016-12-09 21:44:25
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: TF FMH0017!-NYBOT | 2016-12-09 21:44:25
Intraday data recording state for symbol TF FMH0017!-NYBOT is set to download 'Pending'. | 2016-12-09 21:44:25
Market data subscription status is not known while delaying historical data download for symbol: TF FMH0017!-NYBOT | 2016-12-09 21:44:25
Delaying start of download for TF FMH0017!-NYBOT | 2016-12-09 21:44:25
Delaying start of download for TF FMH0017!-NYBOT | 2016-12-09 21:44:26
HD Request # 4 | Downloading Intraday chart data for TF FMH0017!-NYBOT to the file TF FMH0017!-NYBOT.scid. Service: ice.us | 2016-12-09 21:44:30
Compressing file: C:\SierraChart\Data\TF FMH0017!-NYBOT.scid. This may take a while. | 2016-12-09 21:44:30
HD Request # 4 | Download start date-time: 2016-06-06 22:44:29.000 | 2016-12-09 21:44:30
HD Request # 4 | Using server: ds1.sierracharts.com port 10149 | 2016-12-09 21:44:30
Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-12-09 21:44:30
Socket (9) | Connected. | 2016-12-09 21:44:30
HD Request # 4 | Setting DTC encoding to Binary VLS | 2016-12-09 21:44:30
HD Request # 4 | Sending historical data logon request message. | 2016-12-09 21:44:30
HD Request # 4 | Requesting Intraday data. Start date-time: 2016-06-06 22:44:29. Record interval: 1. Symbol: RJH17 | 2016-12-09 21:44:30
HD Request # 4 | Decompressing data. | 2016-12-09 21:44:30
HD Request # 4 | Receiving Intraday data for TF FMH0017!-NYBOT starting at 2016-09-08 22:03:34 | 2016-12-09 21:44:31
HD Request # 4 | Timestamp of first Intraday data file record written: 2016-09-08 22:03:34 | 2016-12-09 21:44:31
Socket (9) | Shutdown and closed. | 2016-12-09 21:44:34
The network socket for historical data has been closed. | 2016-12-09 21:44:34
HD Request # 4 | Received 24246 records from 2016-09-08 22:03:34 to 2016-12-09 21:29:27 (92.0 days) and wrote 24246 records for TF FMH0017!-NYBOT | 2016-12-09 21:44:34
HD Request # 4 | Intraday download COMPLETE for TF FMH0017!-NYBOT. Completion time: 4s. Unique request ID: 3 | 2016-12-09 21:44:34
Removed historical data download ID 3 | 2016-12-09 21:44:34
Real-time Intraday chart data file updates started for TF FMH0017!-NYBOT | 2016-12-09 21:44:34
Intraday chart data file opened for TF FMH0017!-NYBOT | 2016-12-09 21:44:34
Rithmic Trading | Using primary service for historical data for TF FMH0017!-NYBOT | 2016-12-09 21:44:34
Intraday data recording state for symbol TF FMH0017!-NYBOT is set to download 'Pending'. | 2016-12-09 21:44:34
HD Request # 5 | Downloading Intraday chart data for TF FMH0017!-NYBOT to the file TF FMH0017!-NYBOT.scid. Service: rim | 2016-12-09 21:44:34
HD Request # 5 | Download start date-time: 2016-12-09 21:29:27.000 | 2016-12-09 21:44:34
HD Request # 5 | Sending historical data request. Start date-time: 2016-12-09 21:29:27. Record interval: 0. Symbol: TF FMH0017!-NYBOT | 2016-12-09 21:44:34
Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-09 21:44:34
Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-09 21:44:34
HD Request # 5 | Error downloading historical Intraday data for TF FMH0017!-NYBOT. Error downloading historical Minute data. Error: bad input | 2016-12-09 21:44:34
HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMH0017!-NYBOT | 2016-12-09 21:44:34
HD Request # 5 | Receiving Intraday data for TF FMH0017!-NYBOT starting at 2016-12-09 21:44:26 | 2016-12-09 21:44:34
HD Request # 5 | Timestamp of first Intraday data file record written: 2016-12-09 21:44:26 | 2016-12-09 21:44:34
Added 8 Time and Sales records to Intraday data file for TF FMH0017!-NYBOT after download. | 2016-12-09 21:44:34
HD Request # 5 | Intraday download COMPLETE for TF FMH0017!-NYBOT. Completion time: 0s. Unique request ID: 4 | 2016-12-09 21:44:34
Removed historical data download ID 4 | 2016-12-09 21:44:34
Opened cached Intraday file: C:\SierraChart\Data\TF FMH0017!-NYBOT.scid | 2016-12-09 21:44:36
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-12-09 21:48:28
HTTP connection to www.sierrachart.com:80 (12) | Connected. | 2016-12-09 21:48:28
Received Date-time from server. Delay adjusted UTC Date-time: 2016-12-09 20:48:26.971. Round-trip delay: 00:00:00.058 | 2016-12-09 21:48:28
Computer time to server time difference: 00:00:00.707 | 2016-12-09 21:48:28
Successfully set the system Date-time to: 2016-12-09 20:48:26.971 UTC. | 2016-12-09 21:48:28
HTTP connection to www.sierrachart.com:80 (12) | Closed. No error. | 2016-12-09 21:48:33
HTTP connection to www.sierrachart.com:80 (12) | Shutdown and closed. | 2016-12-09 21:48:33
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:52:50
Intraday data recording state for symbol TF FMZ0016!-NYBOT is set to download 'Pending'. | 2016-12-09 21:52:50
HD Request # 6 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: ice.us | 2016-12-09 21:52:50
HD Request # 6 | Download start date-time: 2016-12-09 21:17:59.000 | 2016-12-09 21:52:50
HD Request # 6 | Disabling Intraday chart updating for symbol during historical data download. | 2016-12-09 21:52:50
HD Request # 6 | Using server: ds6.sierracharts.com port 10149 | 2016-12-09 21:52:50
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-12-09 21:52:50
Socket (15) | Connected. | 2016-12-09 21:52:51
HD Request # 6 | Setting DTC encoding to Binary VLS | 2016-12-09 21:52:51
HD Request # 6 | Sending historical data logon request message. | 2016-12-09 21:52:51
HD Request # 6 | Requesting Intraday data. Start date-time: 2016-12-09 21:17:59. Record interval: 1. Symbol: RJZ16 | 2016-12-09 21:52:51
HD Request # 6 | Decompressing data. | 2016-12-09 21:52:51
HD Request # 6 | Receiving Intraday data for TF FMZ0016!-NYBOT starting at 2016-12-09 21:18:01 | 2016-12-09 21:52:51
HD Request # 6 | Truncating file to starting date-time of 2016-12-09 21:18:01 | 2016-12-09 21:52:51
HD Request # 6 | Timestamp of first Intraday data file record written: 2016-12-09 21:18:01 | 2016-12-09 21:52:51
Socket (15) | Shutdown and closed. | 2016-12-09 21:52:51
The network socket for historical data has been closed. | 2016-12-09 21:52:51
HD Request # 6 | Received 316 records from 2016-12-09 21:18:01 to 2016-12-09 21:37:43 (19.7 minutes) and wrote 316 records for TF FMZ0016!-NYBOT | 2016-12-09 21:52:51
HD Request # 6 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 1s. Unique request ID: 5 | 2016-12-09 21:52:51
Removed historical data download ID 5 | 2016-12-09 21:52:51
Real-time Intraday chart data file updates started for TF FMZ0016!-NYBOT | 2016-12-09 21:52:51
Intraday chart data file opened for TF FMZ0016!-NYBOT | 2016-12-09 21:52:51
HD Request # 6 | Enabling Intraday chart updating for symbol. | 2016-12-09 21:52:51
HD Request # 6 | Reloading Intraday charts for TF FMZ0016!-NYBOT | 2016-12-09 21:52:51
Reloading all charts with filename: TF FMZ0016!-NYBOT.scid | 2016-12-09 21:52:51
Rithmic Trading | Using primary service for historical data for TF FMZ0016!-NYBOT | 2016-12-09 21:52:51
Intraday data recording state for symbol TF FMZ0016!-NYBOT is set to download 'Pending'. | 2016-12-09 21:52:51
HD Request # 7 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: rim | 2016-12-09 21:52:51
HD Request # 7 | Download start date-time: 2016-12-09 21:37:43.000 | 2016-12-09 21:52:51
HD Request # 7 | Sending historical data request. Start date-time: 2016-12-09 21:37:43. Record interval: 0. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:52:51
Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-09 21:52:51
Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-09 21:52:51
HD Request # 7 | Error downloading historical Intraday data for TF FMZ0016!-NYBOT. Error downloading historical Minute data. Error: bad input | 2016-12-09 21:52:51
HD Request # 7 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMZ0016!-NYBOT | 2016-12-09 21:52:51
HD Request # 7 | Receiving Intraday data for TF FMZ0016!-NYBOT starting at 2016-12-09 21:50:02 | 2016-12-09 21:52:51
HD Request # 7 | Timestamp of first Intraday data file record written: 2016-12-09 21:50:02 | 2016-12-09 21:52:51
Added 231 Time and Sales records to Intraday data file for TF FMZ0016!-NYBOT after download. | 2016-12-09 21:52:51
HD Request # 7 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 0s. Unique request ID: 6 | 2016-12-09 21:52:51
Removed historical data download ID 6 | 2016-12-09 21:52:51
TF FMZ0016!-NYBOT 1 Min #1 | Reloading chart. | 2016-12-09 21:52:52
Opened cached Intraday file: C:\SierraChart\Data\TF FMZ0016!-NYBOT.scid | 2016-12-09 21:52:57
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:53:02
Intraday data recording state for symbol TF FMZ0016!-NYBOT is set to download 'Pending'. | 2016-12-09 21:53:02
HD Request # 8 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: ice.us | 2016-12-09 21:53:02
HD Request # 8 | Download start date-time: 2016-12-09 21:33:59.000 | 2016-12-09 21:53:02
HD Request # 8 | Disabling Intraday chart updating for symbol during historical data download. | 2016-12-09 21:53:02
HD Request # 8 | Using server: ds1.sierracharts.com port 10149 | 2016-12-09 21:53:02
Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-12-09 21:53:02
Socket (17) | Connected. | 2016-12-09 21:53:02
HD Request # 8 | Setting DTC encoding to Binary VLS | 2016-12-09 21:53:02
HD Request # 8 | Sending historical data logon request message. | 2016-12-09 21:53:02
HD Request # 8 | Requesting Intraday data. Start date-time: 2016-12-09 21:33:59. Record interval: 1. Symbol: RJZ16 | 2016-12-09 21:53:02
HD Request # 8 | Decompressing data. | 2016-12-09 21:53:03
HD Request # 8 | Receiving Intraday data for TF FMZ0016!-NYBOT starting at 2016-12-09 21:34:00 | 2016-12-09 21:53:03
HD Request # 8 | Truncating file to starting date-time of 2016-12-09 21:34:00 | 2016-12-09 21:53:03
HD Request # 8 | Timestamp of first Intraday data file record written: 2016-12-09 21:34:00 | 2016-12-09 21:53:03
Socket (17) | Shutdown and closed. | 2016-12-09 21:53:03
The network socket for historical data has been closed. | 2016-12-09 21:53:03
HD Request # 8 | Received 59 records from 2016-12-09 21:34:00 to 2016-12-09 21:38:01 (4.0 minutes) and wrote 59 records for TF FMZ0016!-NYBOT | 2016-12-09 21:53:03
HD Request # 8 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 0s. Unique request ID: 7 | 2016-12-09 21:53:03
Removed historical data download ID 7 | 2016-12-09 21:53:03
Real-time Intraday chart data file updates started for TF FMZ0016!-NYBOT | 2016-12-09 21:53:03
Intraday chart data file opened for TF FMZ0016!-NYBOT | 2016-12-09 21:53:03
HD Request # 8 | Enabling Intraday chart updating for symbol. | 2016-12-09 21:53:03
HD Request # 8 | Reloading Intraday charts for TF FMZ0016!-NYBOT | 2016-12-09 21:53:03
Reloading all charts with filename: TF FMZ0016!-NYBOT.scid | 2016-12-09 21:53:03
Rithmic Trading | Using primary service for historical data for TF FMZ0016!-NYBOT | 2016-12-09 21:53:03
Intraday data recording state for symbol TF FMZ0016!-NYBOT is set to download 'Pending'. | 2016-12-09 21:53:03
HD Request # 9 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: rim | 2016-12-09 21:53:03
HD Request # 9 | Download start date-time: 2016-12-09 21:38:01.000 | 2016-12-09 21:53:03
HD Request # 9 | Sending historical data request. Start date-time: 2016-12-09 21:38:01. Record interval: 0. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:53:03
Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-09 21:53:03
Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-09 21:53:03
HD Request # 9 | Error downloading historical Intraday data for TF FMZ0016!-NYBOT. Error downloading historical Minute data. Error: bad input | 2016-12-09 21:53:03
HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMZ0016!-NYBOT | 2016-12-09 21:53:03
HD Request # 9 | Receiving Intraday data for TF FMZ0016!-NYBOT starting at 2016-12-09 21:50:14 | 2016-12-09 21:53:03
HD Request # 9 | Timestamp of first Intraday data file record written: 2016-12-09 21:50:14 | 2016-12-09 21:53:03
Added 231 Time and Sales records to Intraday data file for TF FMZ0016!-NYBOT after download. | 2016-12-09 21:53:03
HD Request # 9 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 1s. Unique request ID: 8 | 2016-12-09 21:53:03
Removed historical data download ID 8 | 2016-12-09 21:53:03
TF FMZ0016!-NYBOT 1 Min #1 | Reloading chart. | 2016-12-09 21:53:03
Opened cached Intraday file: C:\SierraChart\Data\TF FMZ0016!-NYBOT.scid | 2016-12-09 21:53:06
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:53:13
Intraday data recording state for symbol TF FMZ0016!-NYBOT is set to download 'Pending'. | 2016-12-09 21:53:13
HD Request # 10 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: ice.us | 2016-12-09 21:53:13
HD Request # 10 | Download start date-time: 2016-12-09 21:35:59.000 | 2016-12-09 21:53:13
HD Request # 10 | Disabling Intraday chart updating for symbol during historical data download. | 2016-12-09 21:53:13
HD Request # 10 | Using server: ds6.sierracharts.com port 10149 | 2016-12-09 21:53:13
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-12-09 21:53:13
Socket (18) | Connected. | 2016-12-09 21:53:14
HD Request # 10 | Setting DTC encoding to Binary VLS | 2016-12-09 21:53:14
HD Request # 10 | Sending historical data logon request message. | 2016-12-09 21:53:14
HD Request # 10 | Requesting Intraday data. Start date-time: 2016-12-09 21:35:59. Record interval: 1. Symbol: RJZ16 | 2016-12-09 21:53:14
HD Request # 10 | Decompressing data. | 2016-12-09 21:53:14
HD Request # 10 | Receiving Intraday data for TF FMZ0016!-NYBOT starting at 2016-12-09 21:36:02 | 2016-12-09 21:53:14
HD Request # 10 | Truncating file to starting date-time of 2016-12-09 21:36:02 | 2016-12-09 21:53:14
HD Request # 10 | Timestamp of first Intraday data file record written: 2016-12-09 21:36:02 | 2016-12-09 21:53:14
Socket (18) | Shutdown and closed. | 2016-12-09 21:53:14
The network socket for historical data has been closed. | 2016-12-09 21:53:14
HD Request # 10 | Received 33 records from 2016-12-09 21:36:02 to 2016-12-09 21:38:12 (2.2 minutes) and wrote 33 records for TF FMZ0016!-NYBOT | 2016-12-09 21:53:14
HD Request # 10 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 1s. Unique request ID: 9 | 2016-12-09 21:53:14
Removed historical data download ID 9 | 2016-12-09 21:53:14
Real-time Intraday chart data file updates started for TF FMZ0016!-NYBOT | 2016-12-09 21:53:14
Intraday chart data file opened for TF FMZ0016!-NYBOT | 2016-12-09 21:53:14
HD Request # 10 | Enabling Intraday chart updating for symbol. | 2016-12-09 21:53:14
HD Request # 10 | Reloading Intraday charts for TF FMZ0016!-NYBOT | 2016-12-09 21:53:14
Reloading all charts with filename: TF FMZ0016!-NYBOT.scid | 2016-12-09 21:53:14
Rithmic Trading | Using primary service for historical data for TF FMZ0016!-NYBOT | 2016-12-09 21:53:14
Intraday data recording state for symbol TF FMZ0016!-NYBOT is set to download 'Pending'. | 2016-12-09 21:53:14
HD Request # 11 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: rim | 2016-12-09 21:53:14
HD Request # 11 | Download start date-time: 2016-12-09 21:38:12.000 | 2016-12-09 21:53:14
HD Request # 11 | Sending historical data request. Start date-time: 2016-12-09 21:38:12. Record interval: 0. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:53:14
Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-09 21:53:14
Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-09 21:53:14
HD Request # 11 | Error downloading historical Intraday data for TF FMZ0016!-NYBOT. Error downloading historical Minute data. Error: bad input | 2016-12-09 21:53:14
HD Request # 11 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMZ0016!-NYBOT | 2016-12-09 21:53:14
HD Request # 11 | Receiving Intraday data for TF FMZ0016!-NYBOT starting at 2016-12-09 21:50:27 | 2016-12-09 21:53:14
HD Request # 11 | Timestamp of first Intraday data file record written: 2016-12-09 21:50:27 | 2016-12-09 21:53:14
Added 229 Time and Sales records to Intraday data file for TF FMZ0016!-NYBOT after download. | 2016-12-09 21:53:14
HD Request # 11 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 0s. Unique request ID: 10 | 2016-12-09 21:53:14
Removed historical data download ID 10 | 2016-12-09 21:53:14
TF FMZ0016!-NYBOT 1 Min #1 | Reloading chart. | 2016-12-09 21:53:14
Opened cached Intraday file: C:\SierraChart\Data\TF FMZ0016!-NYBOT.scid | 2016-12-09 21:53:16
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:53:57
Intraday data recording state for symbol TF FMZ0016!-NYBOT is set to download 'Pending'. | 2016-12-09 21:53:57
HD Request # 12 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: ice.us | 2016-12-09 21:53:57
HD Request # 12 | Download start date-time: 2016-12-09 21:55:00.000 | 2016-12-09 21:53:57
HD Request # 12 | Using server: ds1.sierracharts.com port 10149 | 2016-12-09 21:53:57
Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-12-09 21:53:57
Socket (19) | Connected. | 2016-12-09 21:53:57
HD Request # 12 | Setting DTC encoding to Binary VLS | 2016-12-09 21:53:57
HD Request # 12 | Sending historical data logon request message. | 2016-12-09 21:53:57
HD Request # 12 | Requesting Intraday data. Start date-time: 2016-12-09 21:55:00. Record interval: 1. Symbol: RJZ16 | 2016-12-09 21:53:57
HD Request # 12 | Decompressing data. | 2016-12-09 21:53:57
HD Request # 12 | Receiving Intraday data for TF FMZ0016!-NYBOT starting at 2016-12-08 21:53:53 | 2016-12-09 21:53:57
Socket (19) | Shutdown and closed. | 2016-12-09 21:53:58
The network socket for historical data has been closed. | 2016-12-09 21:53:58
HD Request # 12 | Received 10347 records from 2016-12-08 21:53:53 to 2016-12-09 21:38:47 (23.7 hours) and wrote 0 records for TF FMZ0016!-NYBOT | 2016-12-09 21:53:58
HD Request # 12 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 2s. Unique request ID: 11 | 2016-12-09 21:53:58
Removed historical data download ID 11 | 2016-12-09 21:53:58
Real-time Intraday chart data file updates started for TF FMZ0016!-NYBOT | 2016-12-09 21:53:58
Intraday chart data file opened for TF FMZ0016!-NYBOT | 2016-12-09 21:53:58
Rithmic Trading | Using primary service for historical data for TF FMZ0016!-NYBOT | 2016-12-09 21:53:58
Intraday data recording state for symbol TF FMZ0016!-NYBOT is set to download 'Pending'. | 2016-12-09 21:53:58
HD Request # 13 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: rim | 2016-12-09 21:53:58
HD Request # 13 | Download start date-time: 2016-12-09 21:53:53.000 | 2016-12-09 21:53:58
HD Request # 13 | Sending historical data request. Start date-time: 2016-12-09 21:53:53. Record interval: 0. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:53:58
Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-09 21:53:58
Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-09 21:53:58
HD Request # 13 | Error downloading historical Intraday data for TF FMZ0016!-NYBOT. Error downloading historical Minute data. Error: bad input | 2016-12-09 21:53:59
HD Request # 13 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMZ0016!-NYBOT | 2016-12-09 21:53:59
HD Request # 13 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 0s. Unique request ID: 12 | 2016-12-09 21:53:59
Removed historical data download ID 12 | 2016-12-09 21:53:59
Real-time Intraday chart data file updates started for TF FMZ0016!-NYBOT | 2016-12-09 21:53:59
Intraday chart data file opened for TF FMZ0016!-NYBOT | 2016-12-09 21:53:59
Opened cached Intraday file: C:\SierraChart\Data\TF FMZ0016!-NYBOT.scid | 2016-12-09 21:54:05
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:54:05
Intraday data recording state for symbol TF FMZ0016!-NYBOT is set to download 'Pending'. | 2016-12-09 21:54:05
HD Request # 14 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: ice.us | 2016-12-09 21:54:05
HD Request # 14 | Download start date-time: 2016-12-09 21:35:59.000 | 2016-12-09 21:54:05
HD Request # 14 | Disabling Intraday chart updating for symbol during historical data download. | 2016-12-09 21:54:05
HD Request # 14 | Using server: ds6.sierracharts.com port 10149 | 2016-12-09 21:54:05
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-12-09 21:54:05
Socket (20) | Connected. | 2016-12-09 21:54:05
HD Request # 14 | Setting DTC encoding to Binary VLS | 2016-12-09 21:54:05
HD Request # 14 | Sending historical data logon request message. | 2016-12-09 21:54:05
HD Request # 14 | Requesting Intraday data. Start date-time: 2016-12-09 21:35:59. Record interval: 1. Symbol: RJZ16 | 2016-12-09 21:54:06
HD Request # 14 | Decompressing data. | 2016-12-09 21:54:06
HD Request # 14 | Receiving Intraday data for TF FMZ0016!-NYBOT starting at 2016-12-09 21:36:02 | 2016-12-09 21:54:06
HD Request # 14 | Truncating file to starting date-time of 2016-12-09 21:36:02 | 2016-12-09 21:54:06
HD Request # 14 | Timestamp of first Intraday data file record written: 2016-12-09 21:36:02 | 2016-12-09 21:54:06
Socket (20) | Shutdown and closed. | 2016-12-09 21:54:06
The network socket for historical data has been closed. | 2016-12-09 21:54:06
HD Request # 14 | Received 45 records from 2016-12-09 21:36:02 to 2016-12-09 21:39:03 (3.0 minutes) and wrote 45 records for TF FMZ0016!-NYBOT | 2016-12-09 21:54:06
HD Request # 14 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 0s. Unique request ID: 13 | 2016-12-09 21:54:06
Removed historical data download ID 13 | 2016-12-09 21:54:06
Real-time Intraday chart data file updates started for TF FMZ0016!-NYBOT | 2016-12-09 21:54:06
Intraday chart data file opened for TF FMZ0016!-NYBOT | 2016-12-09 21:54:06
HD Request # 14 | Enabling Intraday chart updating for symbol. | 2016-12-09 21:54:06
HD Request # 14 | Reloading Intraday charts for TF FMZ0016!-NYBOT | 2016-12-09 21:54:06
Reloading all charts with filename: TF FMZ0016!-NYBOT.scid | 2016-12-09 21:54:06
Rithmic Trading | Using primary service for historical data for TF FMZ0016!-NYBOT | 2016-12-09 21:54:06
Intraday data recording state for symbol TF FMZ0016!-NYBOT is set to download 'Pending'. | 2016-12-09 21:54:06
HD Request # 15 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: rim | 2016-12-09 21:54:06
HD Request # 15 | Download start date-time: 2016-12-09 21:39:03.000 | 2016-12-09 21:54:06
HD Request # 15 | Sending historical data request. Start date-time: 2016-12-09 21:39:03. Record interval: 0. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:54:06
Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-09 21:54:06
Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-09 21:54:06
HD Request # 15 | Error downloading historical Intraday data for TF FMZ0016!-NYBOT. Error downloading historical Minute data. Error: bad input | 2016-12-09 21:54:06
HD Request # 15 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMZ0016!-NYBOT | 2016-12-09 21:54:06
HD Request # 15 | Receiving Intraday data for TF FMZ0016!-NYBOT starting at 2016-12-09 21:51:00 | 2016-12-09 21:54:06
HD Request # 15 | Timestamp of first Intraday data file record written: 2016-12-09 21:51:00 | 2016-12-09 21:54:06
Added 276 Time and Sales records to Intraday data file for TF FMZ0016!-NYBOT after download. | 2016-12-09 21:54:06
HD Request # 15 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 1s. Unique request ID: 14 | 2016-12-09 21:54:06
Removed historical data download ID 14 | 2016-12-09 21:54:06
TF FMZ0016!-NYBOT 1 Min #1 | Reloading chart. | 2016-12-09 21:54:06
Opened cached Intraday file: C:\SierraChart\Data\TF FMZ0016!-NYBOT.scid | 2016-12-09 21:54:16
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:54:52
Intraday data recording state for symbol TF FMZ0016!-NYBOT is set to download 'Pending'. | 2016-12-09 21:54:52
Reloading all charts with filename: TF FMZ0016!-NYBOT.scid | 2016-12-09 21:54:52
HD Request # 16 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: ice.us | 2016-12-09 21:54:52
HD Request # 16 | Download start date-time: 2016-06-06 22:54:51.000 | 2016-12-09 21:54:52
HD Request # 16 | Using server: ds1.sierracharts.com port 10149 | 2016-12-09 21:54:52
Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-12-09 21:54:52
Socket (21) | Connected. | 2016-12-09 21:54:52
HD Request # 16 | Setting DTC encoding to Binary VLS | 2016-12-09 21:54:52
HD Request # 16 | Sending historical data logon request message. | 2016-12-09 21:54:52
TF FMZ0016!-NYBOT 1 Min #1 | Reloading chart. | 2016-12-09 21:54:52
TF FMZ0016!-NYBOT 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TF FMZ0016!-NYBOT.scid | 2016-12-09 21:54:52
HD Request # 16 | Requesting Intraday data. Start date-time: 2016-06-06 22:54:51. Record interval: 1. Symbol: RJZ16 | 2016-12-09 21:54:52
HD Request # 16 | Decompressing data. | 2016-12-09 21:54:52
HD Request # 16 | Receiving Intraday data for TF FMZ0016!-NYBOT starting at 2016-06-07 16:07:31 | 2016-12-09 21:54:52
HD Request # 16 | Timestamp of first Intraday data file record written: 2016-06-07 16:07:31 | 2016-12-09 21:54:52
Socket (21) | Shutdown and closed. | 2016-12-09 21:55:12
The network socket for historical data has been closed. | 2016-12-09 21:55:12
HD Request # 16 | Received 976750 records from 2016-06-07 16:07:31 to 2016-12-09 21:39:50 (185.3 days) and wrote 976750 records for TF FMZ0016!-NYBOT | 2016-12-09 21:55:12
HD Request # 16 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 20s. Unique request ID: 15 | 2016-12-09 21:55:12
Removed historical data download ID 15 | 2016-12-09 21:55:12
Real-time Intraday chart data file updates started for TF FMZ0016!-NYBOT | 2016-12-09 21:55:12
Intraday chart data file opened for TF FMZ0016!-NYBOT | 2016-12-09 21:55:12
Rithmic Trading | Using primary service for historical data for TF FMZ0016!-NYBOT | 2016-12-09 21:55:12
Intraday data recording state for symbol TF FMZ0016!-NYBOT is set to download 'Pending'. | 2016-12-09 21:55:12
HD Request # 17 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: rim | 2016-12-09 21:55:12
HD Request # 17 | Download start date-time: 2016-12-09 21:39:50.000 | 2016-12-09 21:55:12
HD Request # 17 | Sending historical data request. Start date-time: 2016-12-09 21:39:50. Record interval: 0. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:55:12
Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-09 21:55:12
Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-09 21:55:12
HD Request # 17 | Error downloading historical Intraday data for TF FMZ0016!-NYBOT. Error downloading historical Minute data. Error: bad input | 2016-12-09 21:55:12
HD Request # 17 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMZ0016!-NYBOT | 2016-12-09 21:55:12
HD Request # 17 | Receiving Intraday data for TF FMZ0016!-NYBOT starting at 2016-12-09 21:52:03 | 2016-12-09 21:55:12
HD Request # 17 | Timestamp of first Intraday data file record written: 2016-12-09 21:52:03 | 2016-12-09 21:55:12
Added 245 Time and Sales records to Intraday data file for TF FMZ0016!-NYBOT after download. | 2016-12-09 21:55:12
HD Request # 17 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 1s. Unique request ID: 16 | 2016-12-09 21:55:12
Removed historical data download ID 16 | 2016-12-09 21:55:12
Opened cached Intraday file: C:\SierraChart\Data\TF FMZ0016!-NYBOT.scid | 2016-12-09 21:55:17
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:55:30
Intraday data recording state for symbol TF FMZ0016!-NYBOT is set to download 'Pending'. | 2016-12-09 21:55:30
HD Request # 18 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: ice.us | 2016-12-09 21:55:30
HD Request # 18 | Download start date-time: 2016-12-09 21:37:59.000 | 2016-12-09 21:55:30
HD Request # 18 | Disabling Intraday chart updating for symbol during historical data download. | 2016-12-09 21:55:30
HD Request # 18 | Using server: ds6.sierracharts.com port 10149 | 2016-12-09 21:55:30
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-12-09 21:55:30
Socket (23) | Connected. | 2016-12-09 21:55:30
HD Request # 18 | Setting DTC encoding to Binary VLS | 2016-12-09 21:55:30
HD Request # 18 | Sending historical data logon request message. | 2016-12-09 21:55:30
HD Request # 18 | Requesting Intraday data. Start date-time: 2016-12-09 21:37:59. Record interval: 1. Symbol: RJZ16 | 2016-12-09 21:55:30
HD Request # 18 | Decompressing data. | 2016-12-09 21:55:30
HD Request # 18 | Receiving Intraday data for TF FMZ0016!-NYBOT starting at 2016-12-09 21:38:01 | 2016-12-09 21:55:30
HD Request # 18 | Truncating file to starting date-time of 2016-12-09 21:38:01 | 2016-12-09 21:55:30
HD Request # 18 | Timestamp of first Intraday data file record written: 2016-12-09 21:38:01 | 2016-12-09 21:55:30
Socket (23) | Shutdown and closed. | 2016-12-09 21:55:30
The network socket for historical data has been closed. | 2016-12-09 21:55:30
HD Request # 18 | Received 40 records from 2016-12-09 21:38:01 to 2016-12-09 21:40:27 (2.4 minutes) and wrote 40 records for TF FMZ0016!-NYBOT | 2016-12-09 21:55:30
HD Request # 18 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 0s. Unique request ID: 17 | 2016-12-09 21:55:30
Removed historical data download ID 17 | 2016-12-09 21:55:30
Real-time Intraday chart data file updates started for TF FMZ0016!-NYBOT | 2016-12-09 21:55:30
Intraday chart data file opened for TF FMZ0016!-NYBOT | 2016-12-09 21:55:30
HD Request # 18 | Enabling Intraday chart updating for symbol. | 2016-12-09 21:55:30
HD Request # 18 | Reloading Intraday charts for TF FMZ0016!-NYBOT | 2016-12-09 21:55:30
Reloading all charts with filename: TF FMZ0016!-NYBOT.scid | 2016-12-09 21:55:30
Rithmic Trading | Using primary service for historical data for TF FMZ0016!-NYBOT | 2016-12-09 21:55:30
HD Request # 19 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: rim | 2016-12-09 21:55:30
HD Request # 19 | Download start date-time: 2016-12-09 21:40:27.000 | 2016-12-09 21:55:30
HD Request # 19 | Sending historical data request. Start date-time: 2016-12-09 21:40:27. Record interval: 0. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:55:30
Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-09 21:55:30
Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-09 21:55:30
TF FMZ0016!-NYBOT 1 Min #1 | Reloading chart. | 2016-12-09 21:55:30
HD Request # 19 | Error downloading historical Intraday data for TF FMZ0016!-NYBOT. Error downloading historical Minute data. Error: bad input | 2016-12-09 21:55:31
HD Request # 19 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMZ0016!-NYBOT | 2016-12-09 21:55:31
HD Request # 19 | Receiving Intraday data for TF FMZ0016!-NYBOT starting at 2016-12-09 21:52:26 | 2016-12-09 21:55:31
HD Request # 19 | Timestamp of first Intraday data file record written: 2016-12-09 21:52:26 | 2016-12-09 21:55:31
Added 249 Time and Sales records to Intraday data file for TF FMZ0016!-NYBOT after download. | 2016-12-09 21:55:31
HD Request # 19 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 0s. Unique request ID: 18 | 2016-12-09 21:55:31
Removed historical data download ID 18 | 2016-12-09 21:55:31
Real-time Intraday chart data file updates started for TF FMZ0016!-NYBOT | 2016-12-09 21:55:31
Intraday chart data file opened for TF FMZ0016!-NYBOT | 2016-12-09 21:55:31
Opened cached Intraday file: C:\SierraChart\Data\TF FMZ0016!-NYBOT.scid | 2016-12-09 21:55:37
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: TF FMH0017!-NYBOT | 2016-12-09 21:56:57
Intraday data recording state for symbol TF FMH0017!-NYBOT is set to download 'Pending'. | 2016-12-09 21:56:57
Reloading all charts with filename: TF FMH0017!-NYBOT.scid | 2016-12-09 21:56:57
HD Request # 20 | Downloading Intraday chart data for TF FMH0017!-NYBOT to the file TF FMH0017!-NYBOT.scid. Service: ice.us | 2016-12-09 21:56:57
HD Request # 20 | Download start date-time: 2016-12-09 16:39:03.000 | 2016-12-09 21:56:57
HD Request # 20 | Using server: ds1.sierracharts.com port 10149 | 2016-12-09 21:56:57
Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-12-09 21:56:57
Socket (25) | Connected. | 2016-12-09 21:56:57
HD Request # 20 | Setting DTC encoding to Binary VLS | 2016-12-09 21:56:57
HD Request # 20 | Sending historical data logon request message. | 2016-12-09 21:56:57
TF FMH0017!-NYBOT 1 Min #2 | Reloading chart. | 2016-12-09 21:56:57
HD Request # 20 | Requesting Intraday data. Start date-time: 2016-12-09 16:39:03. Record interval: 1. Symbol: RJH17 | 2016-12-09 21:56:57
HD Request # 20 | Decompressing data. | 2016-12-09 21:56:57
HD Request # 20 | Receiving Intraday data for TF FMH0017!-NYBOT starting at 2016-12-09 16:39:03 | 2016-12-09 21:56:57
HD Request # 20 | Timestamp of first Intraday data file record written: 2016-12-09 16:39:03 | 2016-12-09 21:56:57
Socket (25) | Shutdown and closed. | 2016-12-09 21:56:58
The network socket for historical data has been closed. | 2016-12-09 21:56:58
HD Request # 20 | Received 6655 records from 2016-12-09 16:39:03 to 2016-12-09 21:41:48 (5.0 hours) and wrote 6655 records for TF FMH0017!-NYBOT | 2016-12-09 21:56:58
HD Request # 20 | Intraday download COMPLETE for TF FMH0017!-NYBOT. Completion time: 2s. Unique request ID: 19 | 2016-12-09 21:56:58
Removed historical data download ID 19 | 2016-12-09 21:56:58
Real-time Intraday chart data file updates started for TF FMH0017!-NYBOT | 2016-12-09 21:56:58
Intraday chart data file opened for TF FMH0017!-NYBOT | 2016-12-09 21:56:58
Rithmic Trading | Using primary service for historical data for TF FMH0017!-NYBOT | 2016-12-09 21:56:58
Intraday data recording state for symbol TF FMH0017!-NYBOT is set to download 'Pending'. | 2016-12-09 21:56:58
HD Request # 21 | Downloading Intraday chart data for TF FMH0017!-NYBOT to the file TF FMH0017!-NYBOT.scid. Service: rim | 2016-12-09 21:56:58
HD Request # 21 | Download start date-time: 2016-12-09 21:41:48.000 | 2016-12-09 21:56:58
HD Request # 21 | Sending historical data request. Start date-time: 2016-12-09 21:41:48. Record interval: 0. Symbol: TF FMH0017!-NYBOT | 2016-12-09 21:56:58
Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-09 21:56:58
Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-09 21:56:58
HD Request # 21 | Error downloading historical Intraday data for TF FMH0017!-NYBOT. Error downloading historical Minute data. Error: bad input | 2016-12-09 21:56:58
HD Request # 21 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMH0017!-NYBOT | 2016-12-09 21:56:58
HD Request # 21 | Receiving Intraday data for TF FMH0017!-NYBOT starting at 2016-12-09 21:55:40 | 2016-12-09 21:56:58
HD Request # 21 | Timestamp of first Intraday data file record written: 2016-12-09 21:55:40 | 2016-12-09 21:56:58
Added 727 Time and Sales records to Intraday data file for TF FMH0017!-NYBOT after download. | 2016-12-09 21:56:58
HD Request # 21 | Intraday download COMPLETE for TF FMH0017!-NYBOT. Completion time: 0s. Unique request ID: 20 | 2016-12-09 21:56:58
Removed historical data download ID 20 | 2016-12-09 21:56:58
Opened cached Intraday file: C:\SierraChart\Data\TF FMH0017!-NYBOT.scid | 2016-12-09 21:57:07
Reloading all charts with filename: TF FMH0017!-NYBOT.scid | 2016-12-09 21:57:25
TF FMH0017!-NYBOT 1 Min #2 | Reloading chart. | 2016-12-09 21:57:25
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: TF FMH0017!-NYBOT | 2016-12-09 21:57:36
Intraday data recording state for symbol TF FMH0017!-NYBOT is set to download 'Pending'. | 2016-12-09 21:57:36
Reloading all charts with filename: TF FMH0017!-NYBOT.scid | 2016-12-09 21:57:36
HD Request # 22 | Downloading Intraday chart data for TF FMH0017!-NYBOT to the file TF FMH0017!-NYBOT.scid. Service: ice.us | 2016-12-09 21:57:36
HD Request # 22 | Download start date-time: 2016-12-09 21:38:17.000 | 2016-12-09 21:57:36
HD Request # 22 | Using server: ds6.sierracharts.com port 10149 | 2016-12-09 21:57:36
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-12-09 21:57:36
Socket (26) | Connected. | 2016-12-09 21:57:36
HD Request # 22 | Setting DTC encoding to Binary VLS | 2016-12-09 21:57:36
HD Request # 22 | Sending historical data logon request message. | 2016-12-09 21:57:36
TF FMH0017!-NYBOT 1 Min #2 | Reloading chart. | 2016-12-09 21:57:36
HD Request # 22 | Requesting Intraday data. Start date-time: 2016-12-09 21:38:17. Record interval: 1. Symbol: RJH17 | 2016-12-09 21:57:36
HD Request # 22 | Decompressing data. | 2016-12-09 21:57:37
HD Request # 22 | Receiving Intraday data for TF FMH0017!-NYBOT starting at 2016-12-09 21:38:17 | 2016-12-09 21:57:37
HD Request # 22 | Timestamp of first Intraday data file record written: 2016-12-09 21:38:17 | 2016-12-09 21:57:37
Socket (26) | Shutdown and closed. | 2016-12-09 21:57:37
The network socket for historical data has been closed. | 2016-12-09 21:57:37
HD Request # 22 | Received 100 records from 2016-12-09 21:38:17 to 2016-12-09 21:42:34 (4.3 minutes) and wrote 100 records for TF FMH0017!-NYBOT | 2016-12-09 21:57:37
HD Request # 22 | Intraday download COMPLETE for TF FMH0017!-NYBOT. Completion time: 0s. Unique request ID: 21 | 2016-12-09 21:57:37
Removed historical data download ID 21 | 2016-12-09 21:57:37
Real-time Intraday chart data file updates started for TF FMH0017!-NYBOT | 2016-12-09 21:57:37
Intraday chart data file opened for TF FMH0017!-NYBOT | 2016-12-09 21:57:37
Rithmic Trading | Using primary service for historical data for TF FMH0017!-NYBOT | 2016-12-09 21:57:37
Intraday data recording state for symbol TF FMH0017!-NYBOT is set to download 'Pending'. | 2016-12-09 21:57:37
HD Request # 23 | Downloading Intraday chart data for TF FMH0017!-NYBOT to the file TF FMH0017!-NYBOT.scid. Service: rim | 2016-12-09 21:57:37
HD Request # 23 | Download start date-time: 2016-12-09 21:42:34.000 | 2016-12-09 21:57:37
HD Request # 23 | Sending historical data request. Start date-time: 2016-12-09 21:42:34. Record interval: 0. Symbol: TF FMH0017!-NYBOT | 2016-12-09 21:57:37
Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-09 21:57:37
Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-09 21:57:37
HD Request # 23 | Error downloading historical Intraday data for TF FMH0017!-NYBOT. Error downloading historical Minute data. Error: bad input | 2016-12-09 21:57:37
HD Request # 23 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMH0017!-NYBOT | 2016-12-09 21:57:37
HD Request # 23 | Receiving Intraday data for TF FMH0017!-NYBOT starting at 2016-12-09 21:56:11 | 2016-12-09 21:57:37
HD Request # 23 | Timestamp of first Intraday data file record written: 2016-12-09 21:56:11 | 2016-12-09 21:57:37
Added 729 Time and Sales records to Intraday data file for TF FMH0017!-NYBOT after download. | 2016-12-09 21:57:37
HD Request # 23 | Intraday download COMPLETE for TF FMH0017!-NYBOT. Completion time: 0s. Unique request ID: 22 | 2016-12-09 21:57:37
Removed historical data download ID 22 | 2016-12-09 21:57:37
Opened cached Intraday file: C:\SierraChart\Data\TF FMH0017!-NYBOT.scid | 2016-12-09 21:57:47
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:58:29
Intraday data recording state for symbol TF FMZ0016!-NYBOT is set to download 'Pending'. | 2016-12-09 21:58:29
Reloading all charts with filename: TF FMZ0016!-NYBOT.scid | 2016-12-09 21:58:29
HD Request # 24 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: ice.us | 2016-12-09 21:58:29
HD Request # 24 | Download start date-time: 2016-12-08 18:34:27.000 | 2016-12-09 21:58:29
HD Request # 24 | Using server: ds1.sierracharts.com port 10149 | 2016-12-09 21:58:29
Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-12-09 21:58:29
Socket (27) | Connected. | 2016-12-09 21:58:29
TF FMZ0016!-NYBOT 1 Min #1 | Reloading chart. | 2016-12-09 21:58:29
HD Request # 24 | Setting DTC encoding to Binary VLS | 2016-12-09 21:58:29
HD Request # 24 | Sending historical data logon request message. | 2016-12-09 21:58:29
HD Request # 24 | Requesting Intraday data. Start date-time: 2016-12-08 18:34:27. Record interval: 1. Symbol: RJZ16 | 2016-12-09 21:58:29
HD Request # 24 | Decompressing data. | 2016-12-09 21:58:29
HD Request # 24 | Receiving Intraday data for TF FMZ0016!-NYBOT starting at 2016-12-08 18:34:27 | 2016-12-09 21:58:29
HD Request # 24 | Timestamp of first Intraday data file record written: 2016-12-08 18:34:27 | 2016-12-09 21:58:29
Socket (27) | Shutdown and closed. | 2016-12-09 21:58:30
The network socket for historical data has been closed. | 2016-12-09 21:58:30
HD Request # 24 | Received 16569 records from 2016-12-08 18:34:27 to 2016-12-09 21:43:27 (27.2 hours) and wrote 16569 records for TF FMZ0016!-NYBOT | 2016-12-09 21:58:30
HD Request # 24 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 0s. Unique request ID: 23 | 2016-12-09 21:58:30
Removed historical data download ID 23 | 2016-12-09 21:58:30
Real-time Intraday chart data file updates started for TF FMZ0016!-NYBOT | 2016-12-09 21:58:30
Intraday chart data file opened for TF FMZ0016!-NYBOT | 2016-12-09 21:58:30
Rithmic Trading | Using primary service for historical data for TF FMZ0016!-NYBOT | 2016-12-09 21:58:30
Intraday data recording state for symbol TF FMZ0016!-NYBOT is set to download 'Pending'. | 2016-12-09 21:58:30
HD Request # 25 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: rim | 2016-12-09 21:58:30
HD Request # 25 | Download start date-time: 2016-12-09 21:43:27.000 | 2016-12-09 21:58:30
HD Request # 25 | Sending historical data request. Start date-time: 2016-12-09 21:43:27. Record interval: 0. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:58:30
Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-09 21:58:30
Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-09 21:58:30
HD Request # 25 | Error downloading historical Intraday data for TF FMZ0016!-NYBOT. Error downloading historical Minute data. Error: bad input | 2016-12-09 21:58:31
HD Request # 25 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMZ0016!-NYBOT | 2016-12-09 21:58:31
HD Request # 25 | Receiving Intraday data for TF FMZ0016!-NYBOT starting at 2016-12-09 21:55:45 | 2016-12-09 21:58:31
HD Request # 25 | Timestamp of first Intraday data file record written: 2016-12-09 21:55:45 | 2016-12-09 21:58:31
Added 571 Time and Sales records to Intraday data file for TF FMZ0016!-NYBOT after download. | 2016-12-09 21:58:31
HD Request # 25 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 0s. Unique request ID: 24 | 2016-12-09 21:58:31
Removed historical data download ID 24 | 2016-12-09 21:58:31
Real-time Intraday chart data file updates started for TF FMZ0016!-NYBOT | 2016-12-09 21:58:31
Intraday chart data file opened for TF FMZ0016!-NYBOT | 2016-12-09 21:58:31
Opened cached Intraday file: C:\SierraChart\Data\TF FMZ0016!-NYBOT.scid | 2016-12-09 21:58:36
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:59:58
Intraday data recording state for symbol TF FMZ0016!-NYBOT is set to download 'Pending'. | 2016-12-09 21:59:58
Reloading all charts with filename: TF FMZ0016!-NYBOT.scid | 2016-12-09 21:59:58
HD Request # 26 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: ice.us | 2016-12-09 21:59:58
HD Request # 26 | Download start date-time: 2016-12-09 21:32:42.000 | 2016-12-09 21:59:58
HD Request # 26 | Using server: ds6.sierracharts.com port 10149 | 2016-12-09 21:59:58
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-12-09 21:59:58
TF FMZ0016!-NYBOT 1 Min #1 | Reloading chart. | 2016-12-09 21:59:58
Socket (29) | Connected. | 2016-12-09 21:59:58
HD Request # 26 | Setting DTC encoding to Binary VLS | 2016-12-09 21:59:59
HD Request # 26 | Sending historical data logon request message. | 2016-12-09 21:59:59
HD Request # 26 | Requesting Intraday data. Start date-time: 2016-12-09 21:32:42. Record interval: 1. Symbol: RJZ16 | 2016-12-09 21:59:59
HD Request # 26 | Decompressing data. | 2016-12-09 21:59:59
HD Request # 26 | Receiving Intraday data for TF FMZ0016!-NYBOT starting at 2016-12-09 21:32:42 | 2016-12-09 21:59:59
HD Request # 26 | Timestamp of first Intraday data file record written: 2016-12-09 21:32:42 | 2016-12-09 21:59:59
Socket (29) | Shutdown and closed. | 2016-12-09 21:59:59
The network socket for historical data has been closed. | 2016-12-09 21:59:59
HD Request # 26 | Received 222 records from 2016-12-09 21:32:42 to 2016-12-09 21:44:55 (12.2 minutes) and wrote 222 records for TF FMZ0016!-NYBOT | 2016-12-09 21:59:59
HD Request # 26 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 0s. Unique request ID: 25 | 2016-12-09 21:59:59
Removed historical data download ID 25 | 2016-12-09 21:59:59
Real-time Intraday chart data file updates started for TF FMZ0016!-NYBOT | 2016-12-09 21:59:59
Intraday chart data file opened for TF FMZ0016!-NYBOT | 2016-12-09 21:59:59
Rithmic Trading | Using primary service for historical data for TF FMZ0016!-NYBOT | 2016-12-09 21:59:59
Intraday data recording state for symbol TF FMZ0016!-NYBOT is set to download 'Pending'. | 2016-12-09 21:59:59
HD Request # 27 | Downloading Intraday chart data for TF FMZ0016!-NYBOT to the file TF FMZ0016!-NYBOT.scid. Service: rim | 2016-12-09 21:59:59
HD Request # 27 | Download start date-time: 2016-12-09 21:44:55.000 | 2016-12-09 21:59:59
HD Request # 27 | Sending historical data request. Start date-time: 2016-12-09 21:44:55. Record interval: 0. Symbol: TF FMZ0016!-NYBOT | 2016-12-09 21:59:59
Rithmic Trading | Message from server: Setting record interval to 1 Minute for spreads and options. | 2016-12-09 21:59:59
Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-12-09 21:59:59
HD Request # 27 | Error downloading historical Intraday data for TF FMZ0016!-NYBOT. Error downloading historical Minute data. Error: bad input | 2016-12-09 21:59:59
HD Request # 27 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMZ0016!-NYBOT | 2016-12-09 21:59:59
HD Request # 27 | Receiving Intraday data for TF FMZ0016!-NYBOT starting at 2016-12-09 21:59:20 | 2016-12-09 21:59:59
HD Request # 27 | Timestamp of first Intraday data file record written: 2016-12-09 21:59:20 | 2016-12-09 21:59:59
Added 864 Time and Sales records to Intraday data file for TF FMZ0016!-NYBOT after download. | 2016-12-09 21:59:59
HD Request # 27 | Intraday download COMPLETE for TF FMZ0016!-NYBOT. Completion time: 0s. Unique request ID: 26 | 2016-12-09 21:59:59
Removed historical data download ID 26 | 2016-12-09 21:59:59
Opened cached Intraday file: C:\SierraChart\Data\TF FMZ0016!-NYBOT.scid | 2016-12-09 22:00:07
[2016-12-09 22:16:24]
It is clear that you still do not have the latest revision of 1495.
Update with Help >> Download Prerelease and make sure you go through the full installation process.
Here are instructions:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
[2016-12-12 18:01:35]
At the time we posted the prior message, the newest Rithmic bridge program was not released. It has now been released.
Update again with Help >> Download Prerelease and the problem will be resolved.
Re-download the data in the affected charts with Edit >> Delete All Data and Download.
