Date/Time: Sat, 11 Jan 2025 15:03:40 +0000
large volume trade indicator ?
View Count: 1079
[2016-12-09 16:50:15] |
zippyzip - Posts: 293 |
can a point be added instead of a block ? with mabye some fading to compare to size of order ? so bigger the order the darker the color , but still placed in background behind that price , this block placement is hard to use thanks |
[2016-12-09 18:27:01] |
We are still working on the study. But we are not likely to get to further work on it for a week or two. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
