Date/Time: Sat, 11 Jan 2025 14:53:44 +0000
Older versions SierraChart
View Count: 1424
[2016-12-09 15:48:59]
User18210 - Posts: 6
Can I download older versions sierrachart example, versions 1461 and later.Thank you for answer.
[2016-12-09 16:25:36]
Sierra Chart - Max - Posts: 5778
Refer to the Software Rollback Procedure here:
https://www.sierrachart.com/index.php?page=doc/download.php#Rollback
Sierra Chart Support
[2016-12-09 18:33:33]
What is the reason to go back to an older version? The problem you had with Rithmic was resolved.
Update Sierra Chart to the latest release following these instructions:
http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
To make sure the update actually occurs use Help >> Download Prerelease.
[2016-12-12 17:54:34]
We realize now what the problem is. The newest Rithmic bridge program was not released. We are releasing it now.
Update with Help >> Download Prerelease to solve the problem you had with historical Intraday data for spread contracts.
Date Time Of Last Edit: 2016-12-12 17:54:46
