Date/Time: Sun, 13 Sep 2026 23:16:22 +0000
Recommended ACSIL for retrieving type of the last trade executed?
View Count: 3123
[2013-08-03 06:44:42]
User45685 - Posts: 36
I was wondering what Sierrachart recommends using for determining what the last trade type(Buy or Sell) was? Is there a recommended function or method for this?
Date Time Of Last Edit: 2013-08-03 06:45:06
[2013-08-04 07:02:35]
It Appears I was looking for sc.scGetTradeListEntry,will try writing code for it.
[2013-08-04 12:02:22]
Yes, but it will be helpful if we add a new function to tell you how many entries are in the Trades list so you can get the last one. We will work on that for the next release.
[2013-08-05 05:37:44]
This function is going to be added in the next release:
sc.GetTradeListSize(). It will return the number of trades in the trade list . This will be useful to get the very last entry from sc.scGetTradeListEntry
[2013-08-05 17:01:33]
Thanks!
1) On a different note, what happened to the "sc.GetTradeList" function which is being referenced in this thread sc.GetTradeList crashes SC ?
2) Is there anymore documentation on the s_ACSTrade structure ?
[2013-08-05 17:25:37]
1. This has been replaced with sc.GetTradeListEntry
2. Here is the documentation:
https://www.sierrachart.com/index.php?l=doc/doc_ACSILTrading.html#scGetTradeListEntry
