Date/Time: Sat, 11 Jan 2025 12:04:48 +0000
Extended trial
View Count: 794
[2016-12-09 12:40:36] |
User622975 - Posts: 1 |
I have trial for Sierra Charts with Tradefutures4Less and got it yesterday extended by my broker with Another 14 Days. But when I try to login, I get a message: your trial has ended. How to get it working again? |
[2016-12-09 16:24:20] |
Sierra Chart - Max - Posts: 5778 |
Your account has been activated and/or reset. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support |
