Date/Time: Sat, 11 Jan 2025 11:44:33 +0000
options/CQG
View Count: 1168
[2016-12-09 00:24:53] |
User157806 - Posts: 71 |
Hello sierra charts/CQG with AMP futures how can we add option quotes for Futures? For example E-Mini S&P options.
[2016-12-09 01:25:34] |
Option symbols are supported with CQG. Here is the symbol format: https://www.sierrachart.com/index.php?page=doc/CQGTrading.php#OptionsSymbolFormat Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
