Date/Time: Sat, 11 Jan 2025 14:44:56 +0000
my data stops after 10 min in ES only.In other products works ok
View Count: 759
[2016-12-08 18:39:50] |
User252419 - Posts: 235 |
my data stops after 10 min in ES only. I don't see anything. In other products works ok. I deleted and downloaded data again but keeps not working. Thank you |
[2016-12-08 20:17:50] |
Restart Sierra Chart. And at the time you notice a problem, post a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-12 14:25:44] |
My data stopped working in ZC now.The same in other products early on. Reading Internal Order ID file. | 2016-12-06 23:36:20 Reading Trade Orders file. | 2016-12-06 23:36:20 Reading Trade Positions file. | 2016-12-06 23:36:20 Software version: 1481 | 2016-12-06 23:36:20 Uses New Spreadsheets | 2016-12-06 23:36:20 Usage end date: 2016-12-18 | 2016-12-06 23:36:20 Enabled for: Advanced Features. | 2016-12-06 23:36:20 Enabled for: Advanced Features 2. | 2016-12-06 23:36:20 Enabled for: Sierra Chart Historical Data Service. | 2016-12-06 23:36:20 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-12-06 23:36:20 Current selected Data/Trading service: GAIN Capital/OEC | 2016-12-06 23:36:20 Chart Update Interval: 500 | 2016-12-06 23:36:20 Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2016-12-06 23:36:20 2016-12-06 23:36:26 Local computer time | 2016-12-06 23:36:20 2016-12-06 22:36:26 Local computer time in UTC | 2016-12-06 23:36:20 2016-12-06 23:36:26 Local computer time in SC Time Zone | 2016-12-06 23:36:20 2016-12-06 22:36:22 Server time in UTC | 2016-12-06 23:36:20 Local computer UTC time and Server UTC time difference: 1 seconds. | 2016-12-06 23:36:20 Program path: C:\SierraChart\ | 2016-12-06 23:36:20 Data Files path: C:\SierraChart\Data\ | 2016-12-06 23:36:20 OS Version Number: 6.2 | 2016-12-06 23:36:20 Locale Setting: C | 2016-12-06 23:36:20 Created the DTC Protocol server. | 2016-12-06 23:36:20 DTC Protocol Server listening on port 11099. | 2016-12-06 23:36:20 Created the DTC Protocol historical data server. | 2016-12-06 23:36:20 HD Server Manager | Listening on port 11098 | 2016-12-06 23:36:20 Checking for new symbol settings for oec | 2016-12-06 23:36:20 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-12-06 23:36:20 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-12-06 23:36:20 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-12-06 23:36:20 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-12-06 23:36:20 Symbol settings are up-to-date for oec | 2016-12-06 23:36:20 Files to Open on Start up | Opening file: ES.cht | 2016-12-06 23:36:29 ESZ6 1 Min #3 | Reloading chart. | 2016-12-06 23:36:29 ESZ6 300 Trades #4 | Reloading chart. | 2016-12-06 23:36:29 ESZ6 3 Sec #6 | Reloading chart. | 2016-12-06 23:36:29 ESZ6 30 Sec #14 | Reloading chart. | 2016-12-06 23:36:29 ESZ6 #1 | Reloading chart. | 2016-12-06 23:36:29 Files to Open on Start up | Opening file: ZC.cht | 2016-12-06 23:36:29 ZCH7 1 Min #3 | Reloading chart. | 2016-12-06 23:36:29 ZCH7 300 Trades #4 | Reloading chart. | 2016-12-06 23:36:29 ZCH7 3 Sec #6 | Reloading chart. | 2016-12-06 23:36:29 ZCH7 30 Sec #14 | Reloading chart. | 2016-12-06 23:36:29 ZCH7 #1 | Reloading chart. | 2016-12-06 23:36:29 Files to Open on Start up | Opening file: GCL.cht | 2016-12-06 23:36:29 GCLF7 1 Min #3 | Reloading chart. | 2016-12-06 23:36:29 GCLF7 300 Trades #4 | Reloading chart. | 2016-12-06 23:36:29 GCLF7 3 Sec #6 | Reloading chart. | 2016-12-06 23:36:29 GCLF7 30 Sec #14 | Reloading chart. | 2016-12-06 23:36:29 GCLF7 #1 | Reloading chart. | 2016-12-06 23:36:29 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-12-06 23:36:29 HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-12-06 23:36:29 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-12-06 23:36:29 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-12-06 23:36:29 Intraday data recording state for symbol ESZ6 is set to download 'Pending'. | 2016-12-06 23:36:34 HD Request # 2 | Downloading Intraday chart data for ESZ6 to the file ESZ6.scid. Service: oec | 2016-12-06 23:36:34 HD Request # 2 | Download start date-time: 2016-12-06 22:59:59.000 | 2016-12-06 23:36:34 HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2016-12-06 23:36:34 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-06 23:36:34 Intraday data recording state for symbol ZCH7 is set to download 'Pending'. | 2016-12-06 23:36:34 Intraday data recording state for symbol GCLF7 is set to download 'Pending'. | 2016-12-06 23:36:34 Socket (4) | Connected. | 2016-12-06 23:36:34 HD Request # 2 | Setting DTC encoding to Binary VLS | 2016-12-06 23:36:34 HD Request # 2 | Sending historical data logon request message. | 2016-12-06 23:36:34 HD Request # 2 | Requesting Intraday data. Start date-time: 2016-12-06 22:59:59. Record interval: 0. Symbol: ESZ6 | 2016-12-06 23:36:35 HD Request # 2 | Decompressing data. | 2016-12-06 23:36:35 HD Request # 2 | Historical data for ESZ6 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-12-06 23:36:35 Socket (4) | Shutdown and closed. | 2016-12-06 23:36:35 The network socket for historical data has been closed. | 2016-12-06 23:36:35 HD Request # 2 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ6 | 2016-12-06 23:36:35 HD Request # 2 | Intraday download COMPLETE for ESZ6. Completion time: 0s. Unique request ID: 1 | 2016-12-06 23:36:35 Removed historical data download ID 1 | 2016-12-06 23:36:35 HD Request # 3 | Downloading Intraday chart data for ZCH7 to the file ZCH7.scid. Service: oec | 2016-12-06 23:36:35 HD Request # 3 | Download start date-time: 2016-12-06 20:19:59.000 | 2016-12-06 23:36:35 HD Request # 3 | Using server: ds3.sierracharts.com port 10149 | 2016-12-06 23:36:35 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-06 23:36:35 Socket (5) | Connected. | 2016-12-06 23:36:35 HD Request # 3 | Setting DTC encoding to Binary VLS | 2016-12-06 23:36:35 HD Request # 3 | Sending historical data logon request message. | 2016-12-06 23:36:35 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-12-06 23:36:35 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-12-06 23:36:35 GAIN Capital FIX Trading socket (6) | Connected. | 2016-12-06 23:36:35 GAIN Capital FIX Trading socket (6) | Starting TLS 1.2 connection. | 2016-12-06 23:36:35 HD Request # 3 | Requesting Intraday data. Start date-time: 2016-12-06 20:19:59. Record interval: 0. Symbol: ZCH7 | 2016-12-06 23:36:35 HD Request # 3 | Decompressing data. | 2016-12-06 23:36:35 HD Request # 3 | Historical data for ZCH7 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-12-06 23:36:35 Socket (5) | Shutdown and closed. | 2016-12-06 23:36:35 The network socket for historical data has been closed. | 2016-12-06 23:36:35 HD Request # 3 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZCH7 | 2016-12-06 23:36:35 HD Request # 3 | Intraday download COMPLETE for ZCH7. Completion time: 1s. Unique request ID: 2 | 2016-12-06 23:36:35 Removed historical data download ID 2 | 2016-12-06 23:36:35 HD Request # 4 | Downloading Intraday chart data for GCLF7 to the file GCLF7.scid. Service: oec | 2016-12-06 23:36:35 HD Request # 4 | Download start date-time: 2016-12-06 22:59:58.000 | 2016-12-06 23:36:35 HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2016-12-06 23:36:35 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-06 23:36:35 GAIN Capital FIX Trading socket (6) | SSL connection established. | 2016-12-06 23:36:35 Socket (7) | Connected. | 2016-12-06 23:36:35 HD Request # 4 | Setting DTC encoding to Binary VLS | 2016-12-06 23:36:35 HD Request # 4 | Sending historical data logon request message. | 2016-12-06 23:36:35 GAIN Capital FIX Trading: Sending the Logon message. | 2016-12-06 23:36:36 HD Request # 4 | Requesting Intraday data. Start date-time: 2016-12-06 22:59:58. Record interval: 0. Symbol: GCLF7 | 2016-12-06 23:36:36 GAIN Capital FIX Trading | Connected to trading server. | 2016-12-06 23:36:36 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2016-12-06 23:36:36 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-12-06 23:36:36 HD Request # 4 | Decompressing data. | 2016-12-06 23:36:36 HD Request # 4 | Historical data for GCLF7 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-12-06 23:36:36 Socket (7) | Shutdown and closed. | 2016-12-06 23:36:36 The network socket for historical data has been closed. | 2016-12-06 23:36:36 HD Request # 4 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCLF7 | 2016-12-06 23:36:36 HD Request # 4 | Intraday download COMPLETE for GCLF7. Completion time: 1s. Unique request ID: 3 | 2016-12-06 23:36:36 Removed historical data download ID 3 | 2016-12-06 23:36:36 GAIN Capital FAST Data socket (8) | Connected. | 2016-12-06 23:36:36 GAIN Capital FAST Data: Sending the Hello message. | 2016-12-06 23:36:36 GAIN Capital FAST Data: Sending the Logon message. | 2016-12-06 23:36:36 GAIN Capital/OEC | Connected to data and trading server. | 2016-12-06 23:36:37 GAIN Capital/OEC | Starting real-time market data updates for: ESZ6. ID: 1 | 2016-12-06 23:36:37 GAIN Capital/OEC | Requesting security definition data for: ESZ6. ID: 1 | 2016-12-06 23:36:37 Intraday data recording state for symbol ESZ6 is set to download 'Pending'. | 2016-12-06 23:36:37 Market data subscription status is not known while delaying historical data download for symbol: ESZ6 | 2016-12-06 23:36:37 Delaying start of download for ESZ6 | 2016-12-06 23:36:37 Requesting market depth updates for: ESZ6 if supported. | 2016-12-06 23:36:37 GAIN Capital/OEC | Starting real-time market data updates for: GCLF7. ID: 2 | 2016-12-06 23:36:37 GAIN Capital/OEC | Requesting security definition data for: GCLF7. ID: 2 | 2016-12-06 23:36:37 Intraday data recording state for symbol GCLF7 is set to download 'Pending'. | 2016-12-06 23:36:37 Market data subscription status is not known while delaying historical data download for symbol: ESZ6 | 2016-12-06 23:36:37 Requesting market depth updates for: GCLF7 if supported. | 2016-12-06 23:36:37 GAIN Capital/OEC | Starting real-time market data updates for: ZCH7. ID: 3 | 2016-12-06 23:36:37 GAIN Capital/OEC | Requesting security definition data for: ZCH7. ID: 3 | 2016-12-06 23:36:37 Requesting market depth updates for: ZCH7 if supported. | 2016-12-06 23:36:37 Intraday data recording state for symbol ZCH7 is set to download 'Pending'. | 2016-12-06 23:36:37 Delaying start of download for ESZ6 | 2016-12-06 23:36:37 GAIN Capital/OEC | Starting real-time market data updates for: NQZ6. ID: 4 | 2016-12-06 23:36:37 GAIN Capital/OEC | Requesting security definition data for: NQZ6. ID: 4 | 2016-12-06 23:36:37 GAIN Capital/OEC | Starting real-time market data updates for: YMZ6. ID: 5 | 2016-12-06 23:36:37 GAIN Capital/OEC | Requesting security definition data for: YMZ6. ID: 5 | 2016-12-06 23:36:37 HD Request # 5 | Downloading Intraday chart data for ESZ6 to the file ESZ6.scid. Service: oec | 2016-12-06 23:36:42 HD Request # 5 | Download start date-time: 2016-12-06 22:59:59.000 | 2016-12-06 23:36:42 HD Request # 5 | Using server: ds3.sierracharts.com port 10149 | 2016-12-06 23:36:42 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-06 23:36:42 Socket (9) | Connected. | 2016-12-06 23:36:43 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2016-12-06 23:36:43 HD Request # 5 | Setting DTC encoding to Binary VLS | 2016-12-06 23:36:43 HD Request # 5 | Sending historical data logon request message. | 2016-12-06 23:36:43 HD Request # 5 | Requesting Intraday data. Start date-time: 2016-12-06 22:59:59. Record interval: 0. Symbol: ESZ6 | 2016-12-06 23:36:43 HD Request # 5 | Decompressing data. | 2016-12-06 23:36:44 HD Request # 5 | Receiving Intraday data for ESZ6 starting at 2016-12-06 22:59:59 | 2016-12-06 23:36:44 Socket (9) | Shutdown and closed. | 2016-12-06 23:36:44 The network socket for historical data has been closed. | 2016-12-06 23:36:44 HD Request # 5 | Received 1 record from 2016-12-06 22:59:59 to 2016-12-06 22:59:59 (0.0 seconds) and wrote 0 records for ESZ6 | 2016-12-06 23:36:44 HD Request # 5 | Intraday download COMPLETE for ESZ6. Completion time: 0s. Unique request ID: 4 | 2016-12-06 23:36:44 Removed historical data download ID 4 | 2016-12-06 23:36:44 Real-time Intraday chart data file updates started for ESZ6 | 2016-12-06 23:36:44 Intraday chart data file opened for ESZ6 | 2016-12-06 23:36:44 HD Request # 6 | Downloading Intraday chart data for GCLF7 to the file GCLF7.scid. Service: oec | 2016-12-06 23:36:44 HD Request # 6 | Download start date-time: 2016-12-06 22:59:58.000 | 2016-12-06 23:36:44 HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2016-12-06 23:36:44 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-06 23:36:44 Socket (10) | Connected. | 2016-12-06 23:36:44 HD Request # 6 | Setting DTC encoding to Binary VLS | 2016-12-06 23:36:44 HD Request # 6 | Sending historical data logon request message. | 2016-12-06 23:36:44 HD Request # 6 | Requesting Intraday data. Start date-time: 2016-12-06 22:59:58. Record interval: 0. Symbol: GCLF7 | 2016-12-06 23:36:44 HD Request # 6 | Decompressing data. | 2016-12-06 23:36:44 HD Request # 6 | Receiving Intraday data for GCLF7 starting at 2016-12-06 22:59:58 | 2016-12-06 23:36:44 Socket (10) | Shutdown and closed. | 2016-12-06 23:36:44 The network socket for historical data has been closed. | 2016-12-06 23:36:44 HD Request # 6 | Received 1 record from 2016-12-06 22:59:58 to 2016-12-06 22:59:58 (0.0 seconds) and wrote 0 records for GCLF7 | 2016-12-06 23:36:44 HD Request # 6 | Intraday download COMPLETE for GCLF7. Completion time: 1s. Unique request ID: 5 | 2016-12-06 23:36:44 Removed historical data download ID 5 | 2016-12-06 23:36:44 Real-time Intraday chart data file updates started for GCLF7 | 2016-12-06 23:36:44 Intraday chart data file opened for GCLF7 | 2016-12-06 23:36:44 HD Request # 7 | Downloading Intraday chart data for ZCH7 to the file ZCH7.scid. Service: oec | 2016-12-06 23:36:44 HD Request # 7 | Download start date-time: 2016-12-06 20:19:59.000 | 2016-12-06 23:36:44 HD Request # 7 | Using server: ds3.sierracharts.com port 10149 | 2016-12-06 23:36:44 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-06 23:36:44 Socket (11) | Connected. | 2016-12-06 23:36:44 HD Request # 7 | Setting DTC encoding to Binary VLS | 2016-12-06 23:36:44 HD Request # 7 | Sending historical data logon request message. | 2016-12-06 23:36:44 HD Request # 7 | Requesting Intraday data. Start date-time: 2016-12-06 20:19:59. Record interval: 0. Symbol: ZCH7 | 2016-12-06 23:36:44 HD Request # 7 | Decompressing data. | 2016-12-06 23:36:45 HD Request # 7 | Receiving Intraday data for ZCH7 starting at 2016-12-06 20:19:59 | 2016-12-06 23:36:45 Socket (11) | Shutdown and closed. | 2016-12-06 23:36:45 The network socket for historical data has been closed. | 2016-12-06 23:36:45 HD Request # 7 | Received 19 records from 2016-12-06 20:19:59 to 2016-12-06 20:19:59 (0.0 seconds) and wrote 0 records for ZCH7 | 2016-12-06 23:36:45 HD Request # 7 | Intraday download COMPLETE for ZCH7. Completion time: 0s. Unique request ID: 6 | 2016-12-06 23:36:45 Removed historical data download ID 6 | 2016-12-06 23:36:45 Real-time Intraday chart data file updates started for ZCH7 | 2016-12-06 23:36:45 Intraday chart data file opened for ZCH7 | 2016-12-06 23:36:45 DTC Protocol server | Incoming connection from 127.0.0.1. | 2016-12-06 23:42:51 DTC client #1. 127.0.0.1 | Set DTC encoding to Binary VLS | 2016-12-06 23:42:51 DTC client #1. 127.0.0.1 | Enabled TCP_NODELAY | 2016-12-06 23:42:51 DTC client #1. 127.0.0.1 | Requested heartbeat interval: 20 | 2016-12-06 23:42:51 DTC client #1. Sierra Chart. 127.0.0.1 | Received logon request. | 2016-12-06 23:42:51 DTC client #1. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: User252419. Result text: Connected to SC DTC Protocol server. Service=oec | 2016-12-06 23:42:51 Remote instance connected: C:\SierraChart\SierraChartInstance_2\SierraChart.exe | 2016-12-06 23:42:51 HD Server | New server thread for client has been created for incoming connection. | 2016-12-06 23:42:53 HD Server | Unexpected DTC encoding request: 1 | 2016-12-06 23:42:53 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-06 23:42:53 HD Server | Login has been authorized. | Username: User252419. | 2016-12-06 23:42:53 HD Server | HD Request | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-06 21:59:59 | ClientRequestID: 2 | Username: User252419. | 2016-12-06 23:42:53 HD Server | HD Request # 2 | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 2 | Username: User252419. | 2016-12-06 23:42:53 Socket (0) | Closed. No error. | 2016-12-06 23:42:53 Socket (0) | Shutdown and closed. | 2016-12-06 23:42:53 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-06 23:42:53 HD Server | New server thread for client has been created for incoming connection. | 2016-12-06 23:42:56 HD Server | Unexpected DTC encoding request: 1 | 2016-12-06 23:42:56 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-06 23:42:56 HD Server | Login has been authorized. | Username: User252419. | 2016-12-06 23:42:56 HD Server | HD Request | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-06 21:59:59 | ClientRequestID: 3 | Username: User252419. | 2016-12-06 23:42:56 HD Server | HD Request # 3 | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 3 | Username: User252419. | 2016-12-06 23:42:56 Socket (0) | Closed. No error. | 2016-12-06 23:42:56 Socket (0) | Shutdown and closed. | 2016-12-06 23:42:56 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-06 23:42:56 HD Server | New server thread for client has been created for incoming connection. | 2016-12-06 23:42:57 HD Server | Unexpected DTC encoding request: 1 | 2016-12-06 23:42:57 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-06 23:42:57 HD Server | Login has been authorized. | Username: User252419. | 2016-12-06 23:42:57 HD Server | HD Request | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-06 19:19:59 | ClientRequestID: 4 | Username: User252419. | 2016-12-06 23:42:57 HD Server | HD Request # 4 | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 19 | ClientRequestID: 4 | Username: User252419. | 2016-12-06 23:42:57 Socket (0) | Closed. No error. | 2016-12-06 23:42:57 Socket (0) | Shutdown and closed. | 2016-12-06 23:42:57 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-06 23:42:57 HD Server | New server thread for client has been created for incoming connection. | 2016-12-06 23:42:57 HD Server | Unexpected DTC encoding request: 1 | 2016-12-06 23:42:57 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-06 23:42:57 HD Server | Login has been authorized. | Username: User252419. | 2016-12-06 23:42:57 HD Server | HD Request | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-06 21:59:58 | ClientRequestID: 5 | Username: User252419. | 2016-12-06 23:42:57 HD Server | HD Request # 5 | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 5 | Username: User252419. | 2016-12-06 23:42:57 Socket (0) | Closed. No error. | 2016-12-06 23:42:57 Socket (0) | Shutdown and closed. | 2016-12-06 23:42:57 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-06 23:42:57 HD Server | New server thread for client has been created for incoming connection. | 2016-12-06 23:43:16 HD Server | Unexpected DTC encoding request: 1 | 2016-12-06 23:43:16 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-06 23:43:16 HD Server | Login has been authorized. | Username: User252419. | 2016-12-06 23:43:16 HD Server | HD Request | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2016-12-05 00:00:00 | ClientRequestID: 2 | Username: User252419. | 2016-12-06 23:43:16 HD Request # 8 | Downloading Historical Daily chart data for ESZ6. Starting date: 2016-12-05. Service: oec | 2016-12-06 23:43:16 HD Request # 8 | Requesting historical Daily data for ESZ16 starting at 2016-12-04 | 2016-12-06 23:43:16 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-12-06 23:43:16 HTTP connection to ds01.ddfplus.com:80 (15) | Connected. | 2016-12-06 23:43:16 HD Request # 8 | Receiving historical Daily data for ESZ6 starting at 2016-12-05 | 2016-12-06 23:43:17 HD Request # 8 | Writing historical Daily data to the file ESZ6.dly | 2016-12-06 23:43:17 HD Request # 8 | Received 2 records from 2016-12-05 00:00:00 to 2016-12-06 00:00:00 (2.0 days) and wrote 2 records for ESZ6 | 2016-12-06 23:43:17 HD Request # 8 | Daily download COMPLETE for ESZ6. Completion time: 0s. Unique request ID: 7 | 2016-12-06 23:43:17 Removed historical data download ID 7 | 2016-12-06 23:43:17 HD Server | HD Request # 2 | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 2 | ClientRequestID: 2 | Username: User252419. | 2016-12-06 23:43:17 Socket (0) | Closed. No error. | 2016-12-06 23:43:17 Socket (0) | Shutdown and closed. | 2016-12-06 23:43:17 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-06 23:43:17 HD Server | New server thread for client has been created for incoming connection. | 2016-12-06 23:43:17 DTC Protocol server | Incoming connection from 127.0.0.1. | 2016-12-06 23:43:17 DTC client #2. 127.0.0.1 | Set DTC encoding to Binary VLS | 2016-12-06 23:43:17 DTC client #2. 127.0.0.1 | Enabled TCP_NODELAY | 2016-12-06 23:43:17 DTC client #2. 127.0.0.1 | Requested heartbeat interval: 20 | 2016-12-06 23:43:17 HD Server | Unexpected DTC encoding request: 1 | 2016-12-06 23:43:17 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-06 23:43:17 DTC client #2. Sierra Chart. 127.0.0.1 | Received logon request. | 2016-12-06 23:43:17 HD Server | Login has been authorized. | Username: User252419. | 2016-12-06 23:43:17 DTC client #2. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: User252419. Result text: Connected to SC DTC Protocol server. Service=oec | 2016-12-06 23:43:17 HD Server | HD Request | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-06 21:59:59 | ClientRequestID: 3 | Username: User252419. | 2016-12-06 23:43:17 HD Server | HD Request # 3 | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 3 | Username: User252419. | 2016-12-06 23:43:17 Socket (0) | Closed. No error. | 2016-12-06 23:43:17 Socket (0) | Shutdown and closed. | 2016-12-06 23:43:17 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-06 23:43:17 Remote instance connected: C:\SierraChart\SierraChartInstance_3\SierraChart.exe | 2016-12-06 23:43:17 HD Server | New server thread for client has been created for incoming connection. | 2016-12-06 23:43:27 HD Server | Unexpected DTC encoding request: 1 | 2016-12-06 23:43:27 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-06 23:43:27 HD Server | Login has been authorized. | Username: User252419. | 2016-12-06 23:43:27 HD Server | HD Request | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-06 21:59:59 | ClientRequestID: 4 | Username: User252419. | 2016-12-06 23:43:27 HD Server | HD Request # 4 | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 4 | Username: User252419. | 2016-12-06 23:43:27 Socket (0) | Closed. No error. | 2016-12-06 23:43:27 Socket (0) | Shutdown and closed. | 2016-12-06 23:43:27 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-06 23:43:27 HD Server | New server thread for client has been created for incoming connection. | 2016-12-06 23:43:27 HD Server | Unexpected DTC encoding request: 1 | 2016-12-06 23:43:27 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-06 23:43:27 HD Server | Login has been authorized. | Username: User252419. | 2016-12-06 23:43:27 HD Server | HD Request | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2016-12-05 00:00:00 | ClientRequestID: 5 | Username: User252419. | 2016-12-06 23:43:27 HD Request # 9 | Downloading Historical Daily chart data for ZCH7. Starting date: 2016-12-05. Service: oec | 2016-12-06 23:43:27 HD Request # 9 | Requesting historical Daily data for ZCH17 starting at 2016-12-04 | 2016-12-06 23:43:27 HD Request # 9 | Receiving historical Daily data for ZCH7 starting at 2016-12-05 | 2016-12-06 23:43:27 HD Request # 9 | Writing historical Daily data to the file ZCH7.dly | 2016-12-06 23:43:27 HD Request # 9 | Received 2 records from 2016-12-05 00:00:00 to 2016-12-06 00:00:00 (2.0 days) and wrote 2 records for ZCH7 | 2016-12-06 23:43:27 HD Request # 9 | Daily download COMPLETE for ZCH7. Completion time: 0s. Unique request ID: 8 | 2016-12-06 23:43:27 Removed historical data download ID 8 | 2016-12-06 23:43:27 HD Server | HD Request # 5 | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 2 | ClientRequestID: 5 | Username: User252419. | 2016-12-06 23:43:28 Socket (0) | Closed. No error. | 2016-12-06 23:43:28 Socket (0) | Shutdown and closed. | 2016-12-06 23:43:28 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-06 23:43:28 HD Server | New server thread for client has been created for incoming connection. | 2016-12-06 23:43:28 HD Server | Unexpected DTC encoding request: 1 | 2016-12-06 23:43:28 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-06 23:43:28 HD Server | Login has been authorized. | Username: User252419. | 2016-12-06 23:43:28 HD Server | HD Request | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-06 19:19:59 | ClientRequestID: 6 | Username: User252419. | 2016-12-06 23:43:28 HD Server | HD Request # 6 | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 19 | ClientRequestID: 6 | Username: User252419. | 2016-12-06 23:43:28 Socket (0) | Closed. No error. | 2016-12-06 23:43:28 Socket (0) | Shutdown and closed. | 2016-12-06 23:43:28 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-06 23:43:28 HD Server | New server thread for client has been created for incoming connection. | 2016-12-06 23:43:28 HD Server | Unexpected DTC encoding request: 1 | 2016-12-06 23:43:28 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-06 23:43:28 HD Server | Login has been authorized. | Username: User252419. | 2016-12-06 23:43:28 HD Server | HD Request | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2016-12-05 00:00:00 | ClientRequestID: 7 | Username: User252419. | 2016-12-06 23:43:28 HD Request # 10 | Downloading Historical Daily chart data for GCLF7. Starting date: 2016-12-05. Service: oec | 2016-12-06 23:43:28 HD Request # 10 | Requesting historical Daily data for CLF17 starting at 2016-12-04 | 2016-12-06 23:43:28 HD Request # 10 | Receiving historical Daily data for GCLF7 starting at 2016-12-05 | 2016-12-06 23:43:29 HD Request # 10 | Writing historical Daily data to the file GCLF7.dly | 2016-12-06 23:43:29 HD Request # 10 | Received 2 records from 2016-12-05 00:00:00 to 2016-12-06 00:00:00 (2.0 days) and wrote 2 records for GCLF7 | 2016-12-06 23:43:29 HD Request # 10 | Daily download COMPLETE for GCLF7. Completion time: 0s. Unique request ID: 9 | 2016-12-06 23:43:29 Removed historical data download ID 9 | 2016-12-06 23:43:29 HD Server | HD Request # 7 | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 2 | ClientRequestID: 7 | Username: User252419. | 2016-12-06 23:43:29 Socket (0) | Closed. No error. | 2016-12-06 23:43:29 Socket (0) | Shutdown and closed. | 2016-12-06 23:43:29 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-06 23:43:29 HD Server | New server thread for client has been created for incoming connection. | 2016-12-06 23:43:29 HD Server | Unexpected DTC encoding request: 1 | 2016-12-06 23:43:29 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-06 23:43:29 HD Server | Login has been authorized. | Username: User252419. | 2016-12-06 23:43:29 HD Server | HD Request | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-06 21:59:58 | ClientRequestID: 8 | Username: User252419. | 2016-12-06 23:43:29 HD Server | HD Request # 8 | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 1 | ClientRequestID: 8 | Username: User252419. | 2016-12-06 23:43:29 Socket (0) | Closed. No error. | 2016-12-06 23:43:29 Socket (0) | Shutdown and closed. | 2016-12-06 23:43:29 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-06 23:43:29 HTTP connection to ds01.ddfplus.com:80 (15) | Closed. No error. | 2016-12-06 23:44:33 HTTP connection to ds01.ddfplus.com:80 (15) | Shutdown and closed. | 2016-12-06 23:44:33 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ZCH7.2016-12-06.depth | 2016-12-06 23:45:01 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ6.2016-12-06.depth | 2016-12-06 23:45:01 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\GCLF7.2016-12-06.depth | 2016-12-06 23:45:07 ESZ6 Daily #2 | Reloading chart. | 2016-12-06 23:45:34 HD Request # 11 | Downloading Historical Daily chart data for ESZ6. Starting date: 2016-12-05. Service: oec | 2016-12-06 23:45:35 HD Request # 11 | Requesting historical Daily data for ESZ16 starting at 2016-12-04 | 2016-12-06 23:45:35 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-12-06 23:45:35 HTTP connection to ds01.ddfplus.com:80 (17) | Connected. | 2016-12-06 23:45:35 HD Request # 11 | Receiving historical Daily data for ESZ6 starting at 2016-12-05 | 2016-12-06 23:45:35 HD Request # 11 | Writing historical Daily data to the file ESZ6.dly | 2016-12-06 23:45:35 HD Request # 11 | Received 2 records from 2016-12-05 00:00:00 to 2016-12-06 00:00:00 (2.0 days) and wrote 2 records for ESZ6 | 2016-12-06 23:45:35 HD Request # 11 | Daily download COMPLETE for ESZ6. Completion time: 0s. Unique request ID: 10 | 2016-12-06 23:45:35 Removed historical data download ID 10 | 2016-12-06 23:45:35 ESZ6 Daily #2 | Reloading chart. | 2016-12-06 23:45:35 ESZ6 1 Min #2 | Reloading chart. | 2016-12-06 23:45:42 HTTP connection to ds01.ddfplus.com:80 (17) | Closed. No error. | 2016-12-06 23:46:40 HTTP connection to ds01.ddfplus.com:80 (17) | Shutdown and closed. | 2016-12-06 23:46:40 Opened cached Intraday file: C:\SierraChart\Data\ESZ6.scid | 2016-12-06 23:59:59 Opened cached Intraday file: C:\SierraChart\Data\GCLF7.scid | 2016-12-06 23:59:59 HD Server | New server thread for client has been created for incoming connection. | 2016-12-07 00:00:03 HD Server | Unexpected DTC encoding request: 1 | 2016-12-07 00:00:03 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-07 00:00:03 HD Server | Login has been authorized. | Username: User252419. | 2016-12-07 00:00:03 HD Server | HD Request | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2016-12-05 00:00:00 | ClientRequestID: 9 | Username: User252419. | 2016-12-07 00:00:03 HD Request # 12 | Downloading Historical Daily chart data for GCLF7. Starting date: 2016-12-05. Service: oec | 2016-12-07 00:00:03 HD Request # 12 | Requesting historical Daily data for CLF17 starting at 2016-12-04 | 2016-12-07 00:00:03 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-12-07 00:00:04 HTTP connection to ds01.ddfplus.com:80 (25) | Connected. | 2016-12-07 00:00:04 HD Request # 12 | Receiving historical Daily data for GCLF7 starting at 2016-12-05 | 2016-12-07 00:00:04 HD Request # 12 | Writing historical Daily data to the file GCLF7.dly | 2016-12-07 00:00:04 HD Request # 12 | Received 2 records from 2016-12-05 00:00:00 to 2016-12-06 00:00:00 (2.0 days) and wrote 2 records for GCLF7 | 2016-12-07 00:00:04 HD Request # 12 | Daily download COMPLETE for GCLF7. Completion time: 0s. Unique request ID: 11 | 2016-12-07 00:00:04 Removed historical data download ID 11 | 2016-12-07 00:00:04 HD Server | HD Request # 9 | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 2 | ClientRequestID: 9 | Username: User252419. | 2016-12-07 00:00:04 Socket (0) | Closed. No error. | 2016-12-07 00:00:04 Socket (0) | Shutdown and closed. | 2016-12-07 00:00:04 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-07 00:00:04 HD Server | New server thread for client has been created for incoming connection. | 2016-12-07 00:00:04 HD Server | Unexpected DTC encoding request: 1 | 2016-12-07 00:00:04 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-07 00:00:04 HD Server | Login has been authorized. | Username: User252419. | 2016-12-07 00:00:04 HD Server | HD Request | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2016-12-05 00:00:00 | ClientRequestID: 10 | Username: User252419. | 2016-12-07 00:00:04 HD Server | HD Request # 10 | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 2 | ClientRequestID: 10 | Username: User252419. | 2016-12-07 00:00:04 Socket (0) | Closed. No error. | 2016-12-07 00:00:04 Socket (0) | Shutdown and closed. | 2016-12-07 00:00:04 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-07 00:00:04 HTTP connection to ds01.ddfplus.com:80 (25) | Closed. No error. | 2016-12-07 00:01:09 HTTP connection to ds01.ddfplus.com:80 (25) | Shutdown and closed. | 2016-12-07 00:01:09 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ6.2016-12-07.depth | 2016-12-07 01:00:00 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\GCLF7.2016-12-07.depth | 2016-12-07 01:00:00 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ZCH7.2016-12-07.depth | 2016-12-07 01:00:00 HD Server | New server thread for client has been created for incoming connection. | 2016-12-07 02:00:00 HD Server | Unexpected DTC encoding request: 1 | 2016-12-07 02:00:00 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-07 02:00:00 HD Server | Login has been authorized. | Username: User252419. | 2016-12-07 02:00:00 HD Server | HD Request | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2016-12-05 00:00:00 | ClientRequestID: 11 | Username: User252419. | 2016-12-07 02:00:00 HD Request # 13 | Downloading Historical Daily chart data for ZCH7. Starting date: 2016-12-05. Service: oec | 2016-12-07 02:00:00 Historical data download counter reset. | 2016-12-07 02:00:00 HD Request # 13 | Requesting historical Daily data for ZCH17 starting at 2016-12-04 | 2016-12-07 02:00:00 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-12-07 02:00:00 HTTP connection to ds01.ddfplus.com:80 (87) | Connected. | 2016-12-07 02:00:04 HD Request # 13 | Receiving historical Daily data for ZCH7 starting at 2016-12-05 | 2016-12-07 02:00:05 HD Request # 13 | Writing historical Daily data to the file ZCH7.dly | 2016-12-07 02:00:05 HD Request # 13 | Received 2 records from 2016-12-05 00:00:00 to 2016-12-06 00:00:00 (2.0 days) and wrote 2 records for ZCH7 | 2016-12-07 02:00:05 HD Request # 13 | Daily download COMPLETE for ZCH7. Completion time: 1s. Unique request ID: 12 | 2016-12-07 02:00:05 Removed historical data download ID 12 | 2016-12-07 02:00:05 HD Server | HD Request # 11 | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 2 | ClientRequestID: 11 | Username: User252419. | 2016-12-07 02:00:05 Socket (0) | Closed. No error. | 2016-12-07 02:00:05 Socket (0) | Shutdown and closed. | 2016-12-07 02:00:05 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-07 02:00:05 Opened cached Intraday file: C:\SierraChart\Data\ZCH7.scid | 2016-12-07 02:00:07 HTTP connection to ds01.ddfplus.com:80 (87) | Closed. No error. | 2016-12-07 02:01:10 HTTP connection to ds01.ddfplus.com:80 (87) | Shutdown and closed. | 2016-12-07 02:01:10 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2016-12-07 03:36:26 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2016-12-07 07:36:27 HD Server | New server thread for client has been created for incoming connection. | 2016-12-07 09:02:10 HD Server | Unexpected DTC encoding request: 1 | 2016-12-07 09:02:10 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-07 09:02:10 HD Server | Login has been authorized. | Username: User252419. | 2016-12-07 09:02:10 HD Server | HD Request | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2016-12-05 00:00:00 | ClientRequestID: 12 | Username: User252419. | 2016-12-07 09:02:10 HD Request # 14 | Downloading Historical Daily chart data for GCLF7. Starting date: 2016-12-05. Service: oec | 2016-12-07 09:02:10 HD Request # 14 | Requesting historical Daily data for CLF17 starting at 2016-12-04 | 2016-12-07 09:02:10 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-12-07 09:02:10 HTTP connection to ds01.ddfplus.com:80 (304) | Connected. | 2016-12-07 09:02:10 HD Request # 14 | Receiving historical Daily data for GCLF7 starting at 2016-12-05 | 2016-12-07 09:02:10 HD Request # 14 | Writing historical Daily data to the file GCLF7.dly | 2016-12-07 09:02:10 HD Request # 14 | Received 3 records from 2016-12-05 00:00:00 to 2016-12-07 00:00:00 (3.0 days) and wrote 3 records for GCLF7 | 2016-12-07 09:02:10 HD Request # 14 | Daily download COMPLETE for GCLF7. Completion time: 0s. Unique request ID: 13 | 2016-12-07 09:02:10 Removed historical data download ID 13 | 2016-12-07 09:02:10 HD Server | HD Request # 12 | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientRequestID: 12 | Username: User252419. | 2016-12-07 09:02:11 Socket (0) | Closed. No error. | 2016-12-07 09:02:11 Socket (0) | Shutdown and closed. | 2016-12-07 09:02:11 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-07 09:02:11 HTTP connection to ds01.ddfplus.com:80 (304) | Closed. No error. | 2016-12-07 09:03:15 HTTP connection to ds01.ddfplus.com:80 (304) | Shutdown and closed. | 2016-12-07 09:03:15 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2016-12-07 11:36:24 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2016-12-07 15:36:25 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2016-12-07 16:05:03 GCLF7 300 Trades #2 | Reloading chart. | 2016-12-07 17:51:58 GCLF7 3 Sec #4 | Reloading chart. | 2016-12-07 17:55:32 GCLF7 1 Min #5 | Reloading chart. | 2016-12-07 17:56:10 GCLF7 30 Sec #7 | Reloading chart. | 2016-12-07 17:56:30 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2016-12-07 19:36:25 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2016-12-07 23:36:24 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 00:00:04 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 00:00:04 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 00:00:04 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 00:00:04 HD Server | HD Request | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2016-12-05 00:00:00 | ClientRequestID: 13 | Username: User252419. | 2016-12-08 00:00:04 HD Request # 15 | Downloading Historical Daily chart data for ESZ6. Starting date: 2016-12-05. Service: oec | 2016-12-08 00:00:04 HD Request # 15 | Requesting historical Daily data for ESZ16 starting at 2016-12-04 | 2016-12-08 00:00:04 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-12-08 00:00:04 HTTP connection to ds01.ddfplus.com:80 (764) | Connected. | 2016-12-08 00:00:04 HD Request # 15 | Receiving historical Daily data for ESZ6 starting at 2016-12-05 | 2016-12-08 00:00:04 HD Request # 15 | Writing historical Daily data to the file ESZ6.dly | 2016-12-08 00:00:04 HD Request # 15 | Received 3 records from 2016-12-05 00:00:00 to 2016-12-07 00:00:00 (3.0 days) and wrote 3 records for ESZ6 | 2016-12-08 00:00:04 HD Request # 15 | Daily download COMPLETE for ESZ6. Completion time: 0s. Unique request ID: 14 | 2016-12-08 00:00:04 Removed historical data download ID 14 | 2016-12-08 00:00:04 HD Server | HD Request # 13 | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientRequestID: 13 | Username: User252419. | 2016-12-08 00:00:05 Socket (0) | Closed. No error. | 2016-12-08 00:00:05 Socket (0) | Shutdown and closed. | 2016-12-08 00:00:05 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 00:00:05 GAIN Capital FAST Data: Disconnecting due to a loss of activity. No activity for at least 48 seconds. | 2016-12-08 00:00:52 * GAIN Capital FAST Data: Sending a Logout message. Text = Disconnecting due to loss of activity. | 2016-12-08 00:00:52 GAIN Capital FAST Data socket (8) | Shutdown and closed. | 2016-12-08 00:00:52 GAIN Capital FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2016-12-08 00:00:52 Connection to the external service has been lost. | 2016-12-08 00:00:52 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-12-08 00:00:52 GAIN Capital FIX Trading: DisconnectFIX called. | 2016-12-08 00:00:52 GAIN Capital FIX Trading: Sending a Logout message. | 2016-12-08 00:00:52 GAIN Capital/OEC | Disconnected. | 2016-12-08 00:00:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-12-08 00:00:52 GAIN Capital FIX Trading: Received a Logout message. | 2016-12-08 00:00:52 GAIN Capital FIX Trading socket (6) | SSL shutdown indicates not able to send 'close notify'. | 2016-12-08 00:00:52 GAIN Capital FIX Trading socket (6) | SSL has been shut down. | 2016-12-08 00:00:52 GAIN Capital FIX Trading socket (6) | SSL object has been freed. SSL state is now disconnected. | 2016-12-08 00:00:52 GAIN Capital FIX Trading socket (6) | Shutdown and closed. | 2016-12-08 00:00:52 GAIN Capital/OEC | Disconnected from the trading server. | 2016-12-08 00:00:52 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-12-08 00:00:55 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-12-08 00:00:55 GAIN Capital FIX Trading socket (766) | Connected. | 2016-12-08 00:00:55 GAIN Capital FIX Trading socket (766) | Starting TLS 1.2 connection. | 2016-12-08 00:00:55 GAIN Capital FIX Trading socket (766) | SSL connection established. | 2016-12-08 00:00:56 GAIN Capital FIX Trading: Sending the Logon message. | 2016-12-08 00:00:56 GAIN Capital FIX Trading | Connected to trading server. | 2016-12-08 00:00:56 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2016-12-08 00:00:56 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-12-08 00:00:56 GAIN Capital FAST Data socket (767) | Connected. | 2016-12-08 00:00:56 GAIN Capital FAST Data: Sending the Hello message. | 2016-12-08 00:00:56 GAIN Capital FAST Data: Sending the Logon message. | 2016-12-08 00:00:56 GAIN Capital/OEC | Connected to data and trading server. | 2016-12-08 00:00:56 GAIN Capital/OEC | Starting real-time market data updates for: ESZ6. ID: 1 | 2016-12-08 00:00:56 GAIN Capital/OEC | Requesting security definition data for: ESZ6. ID: 1 | 2016-12-08 00:00:56 Intraday data recording state for symbol ESZ6 is set to download 'Pending'. | 2016-12-08 00:00:56 Market data subscription status is not known while delaying historical data download for symbol: ESZ6 | 2016-12-08 00:00:56 Delaying start of download for ESZ6 | 2016-12-08 00:00:56 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 00:00:56 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 00:00:56 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 00:00:56 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 00:00:56 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 00:00:56 HD Server | HD Request | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-07 21:59:59 | ClientRequestID: 6 | Username: User252419. | 2016-12-08 00:00:56 GAIN Capital/OEC | Starting real-time market data updates for: GCLF7. ID: 2 | 2016-12-08 00:00:56 GAIN Capital/OEC | Requesting security definition data for: GCLF7. ID: 2 | 2016-12-08 00:00:56 Requesting market depth updates for: GCLF7 if supported. | 2016-12-08 00:00:56 Intraday data recording state for symbol GCLF7 is set to download 'Pending'. | 2016-12-08 00:00:56 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 00:00:56 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 00:00:56 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 00:00:56 HD Server | HD Request | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-07 21:59:59 | ClientRequestID: 14 | Username: User252419. | 2016-12-08 00:00:56 Market data subscription status is not known while delaying historical data download for symbol: ESZ6 | 2016-12-08 00:00:56 Requesting market depth updates for: ESZ6 if supported. | 2016-12-08 00:00:57 GAIN Capital/OEC | Starting real-time market data updates for: ZCH7. ID: 3 | 2016-12-08 00:00:57 GAIN Capital/OEC | Requesting security definition data for: ZCH7. ID: 3 | 2016-12-08 00:00:57 Requesting market depth updates for: ZCH7 if supported. | 2016-12-08 00:00:57 Intraday data recording state for symbol ZCH7 is set to download 'Pending'. | 2016-12-08 00:00:57 Market data subscription status is not known while delaying historical data download for symbol: ESZ6 | 2016-12-08 00:00:57 GAIN Capital/OEC | Starting real-time market data updates for: NQZ6. ID: 4 | 2016-12-08 00:00:57 GAIN Capital/OEC | Requesting security definition data for: NQZ6. ID: 4 | 2016-12-08 00:00:57 GAIN Capital/OEC | Starting real-time market data updates for: YMZ6. ID: 5 | 2016-12-08 00:00:57 GAIN Capital/OEC | Requesting security definition data for: YMZ6. ID: 5 | 2016-12-08 00:00:57 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\GCLF7.2016-12-07.depth | 2016-12-08 00:00:57 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ6.2016-12-07.depth | 2016-12-08 00:00:57 Delaying start of download for ESZ6 | 2016-12-08 00:00:58 HD Request # 16 | Downloading Intraday chart data for ESZ6 to the file ESZ6.scid. Service: oec | 2016-12-08 00:01:02 HD Request # 16 | Download start date-time: 2016-12-07 22:59:59.000 | 2016-12-08 00:01:02 HD Request # 16 | Using server: ds4.sierracharts.com port 10149 | 2016-12-08 00:01:02 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-08 00:01:03 Socket (768) | Connected. | 2016-12-08 00:01:03 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2016-12-08 00:01:03 HD Request # 16 | Setting DTC encoding to Binary VLS | 2016-12-08 00:01:03 HD Request # 16 | Sending historical data logon request message. | 2016-12-08 00:01:03 HD Request # 16 | Requesting Intraday data. Start date-time: 2016-12-07 22:59:59. Record interval: 0. Symbol: ESZ6 | 2016-12-08 00:01:03 HD Request # 16 | Decompressing data. | 2016-12-08 00:01:03 HD Request # 16 | Receiving Intraday data for ESZ6 starting at 2016-12-07 22:59:59 | 2016-12-08 00:01:03 HD Request # 16 | Timestamp of first Intraday data file record written: 2016-12-08 00:00:00 | 2016-12-08 00:01:03 Socket (768) | Shutdown and closed. | 2016-12-08 00:01:03 The network socket for historical data has been closed. | 2016-12-08 00:01:03 HD Request # 16 | Received 395 records from 2016-12-07 22:59:59 to 2016-12-08 00:01:02 (61.1 minutes) and wrote 384 records for ESZ6 | 2016-12-08 00:01:03 Added 7 Time and Sales records to Intraday data file for ESZ6 after download. | 2016-12-08 00:01:03 HD Request # 16 | Intraday download COMPLETE for ESZ6. Completion time: 0s. Unique request ID: 15 | 2016-12-08 00:01:03 Removed historical data download ID 15 | 2016-12-08 00:01:03 Real-time Intraday chart data file updates started for ESZ6 | 2016-12-08 00:01:03 Intraday chart data file opened for ESZ6 | 2016-12-08 00:01:03 HD Request # 17 | Downloading Intraday chart data for GCLF7 to the file GCLF7.scid. Service: oec | 2016-12-08 00:01:03 HD Request # 17 | Download start date-time: 2016-12-07 22:59:58.000 | 2016-12-08 00:01:03 HD Request # 17 | Using server: ds3.sierracharts.com port 10149 | 2016-12-08 00:01:03 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-08 00:01:03 Socket (769) | Connected. | 2016-12-08 00:01:04 HD Request # 17 | Setting DTC encoding to Binary VLS | 2016-12-08 00:01:04 HD Request # 17 | Sending historical data logon request message. | 2016-12-08 00:01:04 HD Request # 17 | Requesting Intraday data. Start date-time: 2016-12-07 22:59:58. Record interval: 0. Symbol: GCLF7 | 2016-12-08 00:01:04 HD Request # 17 | Decompressing data. | 2016-12-08 00:01:04 HD Request # 17 | Receiving Intraday data for GCLF7 starting at 2016-12-07 22:59:58 | 2016-12-08 00:01:04 HD Request # 17 | Timestamp of first Intraday data file record written: 2016-12-08 00:00:00 | 2016-12-08 00:01:04 Socket (769) | Shutdown and closed. | 2016-12-08 00:01:04 The network socket for historical data has been closed. | 2016-12-08 00:01:04 HD Request # 17 | Received 394 records from 2016-12-07 22:59:58 to 2016-12-08 00:01:02 (61.1 minutes) and wrote 393 records for GCLF7 | 2016-12-08 00:01:04 Added 3 Time and Sales records to Intraday data file for GCLF7 after download. | 2016-12-08 00:01:04 HD Request # 17 | Intraday download COMPLETE for GCLF7. Completion time: 1s. Unique request ID: 16 | 2016-12-08 00:01:04 Removed historical data download ID 16 | 2016-12-08 00:01:04 Real-time Intraday chart data file updates started for GCLF7 | 2016-12-08 00:01:04 Intraday chart data file opened for GCLF7 | 2016-12-08 00:01:04 HD Request # 18 | Downloading Intraday chart data for ZCH7 to the file ZCH7.scid. Service: oec | 2016-12-08 00:01:04 HD Request # 18 | Download start date-time: 2016-12-07 20:19:59.000 | 2016-12-08 00:01:04 HD Request # 18 | Using server: ds4.sierracharts.com port 10149 | 2016-12-08 00:01:04 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-08 00:01:04 HD Server | HD Request # 6 | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 402 | ClientRequestID: 6 | Username: User252419. | 2016-12-08 00:01:04 HD Server | HD Request # 14 | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 402 | ClientRequestID: 14 | Username: User252419. | 2016-12-08 00:01:04 Socket (0) | Closed. No error. | 2016-12-08 00:01:04 Socket (0) | Shutdown and closed. | 2016-12-08 00:01:04 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 00:01:04 Socket (0) | Closed. No error. | 2016-12-08 00:01:04 Socket (0) | Shutdown and closed. | 2016-12-08 00:01:04 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 00:01:04 Socket (770) | Connected. | 2016-12-08 00:01:04 Opened cached Intraday file: C:\SierraChart\Data\ESZ6.scid | 2016-12-08 00:01:04 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 00:01:04 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 00:01:04 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 00:01:04 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 00:01:04 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 00:01:04 HD Server | HD Request | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-07 19:19:59 | ClientRequestID: 7 | Username: User252419. | 2016-12-08 00:01:04 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 00:01:04 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 00:01:04 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 00:01:04 HD Server | HD Request | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-07 21:59:58 | ClientRequestID: 15 | Username: User252419. | 2016-12-08 00:01:05 HD Server | HD Request # 15 | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 397 | ClientRequestID: 15 | Username: User252419. | 2016-12-08 00:01:05 HD Request # 18 | Setting DTC encoding to Binary VLS | 2016-12-08 00:01:05 HD Request # 18 | Sending historical data logon request message. | 2016-12-08 00:01:05 Socket (0) | Closed. No error. | 2016-12-08 00:01:05 Socket (0) | Shutdown and closed. | 2016-12-08 00:01:05 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 00:01:05 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 00:01:05 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 00:01:05 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 00:01:05 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 00:01:05 HD Server | HD Request | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-07 19:19:59 | ClientRequestID: 16 | Username: User252419. | 2016-12-08 00:01:05 HD Request # 18 | Requesting Intraday data. Start date-time: 2016-12-07 20:19:59. Record interval: 0. Symbol: ZCH7 | 2016-12-08 00:01:05 HD Request # 18 | Decompressing data. | 2016-12-08 00:01:05 HD Request # 18 | Receiving Intraday data for ZCH7 starting at 2016-12-07 20:19:59 | 2016-12-08 00:01:05 Socket (770) | Shutdown and closed. | 2016-12-08 00:01:05 The network socket for historical data has been closed. | 2016-12-08 00:01:05 HD Request # 18 | Received 6 records from 2016-12-07 20:19:59 to 2016-12-07 20:19:59 (0.0 seconds) and wrote 0 records for ZCH7 | 2016-12-08 00:01:05 HD Request # 18 | Intraday download COMPLETE for ZCH7. Completion time: 0s. Unique request ID: 17 | 2016-12-08 00:01:05 Removed historical data download ID 17 | 2016-12-08 00:01:05 Real-time Intraday chart data file updates started for ZCH7 | 2016-12-08 00:01:05 Intraday chart data file opened for ZCH7 | 2016-12-08 00:01:05 HD Server | HD Request # 7 | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 6 | ClientRequestID: 7 | Username: User252419. | 2016-12-08 00:01:05 Socket (0) | Closed. No error. | 2016-12-08 00:01:05 Socket (0) | Shutdown and closed. | 2016-12-08 00:01:05 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 00:01:05 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 00:01:06 HD Server | HD Request # 16 | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 6 | ClientRequestID: 16 | Username: User252419. | 2016-12-08 00:01:06 Socket (0) | Closed. No error. | 2016-12-08 00:01:06 Socket (0) | Shutdown and closed. | 2016-12-08 00:01:06 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 00:01:06 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 00:01:06 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 00:01:06 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 00:01:06 HD Server | HD Request | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-07 21:59:58 | ClientRequestID: 8 | Username: User252419. | 2016-12-08 00:01:06 HD Server | HD Request # 8 | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 397 | ClientRequestID: 8 | Username: User252419. | 2016-12-08 00:01:06 Socket (0) | Closed. No error. | 2016-12-08 00:01:06 Socket (0) | Shutdown and closed. | 2016-12-08 00:01:06 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 00:01:06 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 00:01:06 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 00:01:06 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 00:01:06 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 00:01:06 HD Server | HD Request | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2016-12-06 00:00:00 | ClientRequestID: 17 | Username: User252419. | 2016-12-08 00:01:06 HD Request # 19 | Downloading Historical Daily chart data for GCLF7. Starting date: 2016-12-06. Service: oec | 2016-12-08 00:01:06 HD Request # 19 | Requesting historical Daily data for CLF17 starting at 2016-12-05 | 2016-12-08 00:01:06 HD Request # 19 | Receiving historical Daily data for GCLF7 starting at 2016-12-06 | 2016-12-08 00:01:06 HD Request # 19 | Writing historical Daily data to the file GCLF7.dly | 2016-12-08 00:01:06 HD Request # 19 | Received 3 records from 2016-12-06 00:00:00 to 2016-12-07 00:00:00 (2.0 days) and wrote 2 records for GCLF7 | 2016-12-08 00:01:06 HD Request # 19 | Daily download COMPLETE for GCLF7. Completion time: 0s. Unique request ID: 18 | 2016-12-08 00:01:06 Removed historical data download ID 18 | 2016-12-08 00:01:06 HD Server | HD Request # 17 | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 2 | ClientRequestID: 17 | Username: User252419. | 2016-12-08 00:01:07 Socket (0) | Closed. No error. | 2016-12-08 00:01:07 Socket (0) | Shutdown and closed. | 2016-12-08 00:01:07 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 00:01:07 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 00:01:07 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 00:01:07 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 00:01:07 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 00:01:07 HD Server | HD Request | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2016-12-06 00:00:00 | ClientRequestID: 18 | Username: User252419. | 2016-12-08 00:01:07 HD Request # 20 | Downloading Historical Daily chart data for ESZ6. Starting date: 2016-12-06. Service: oec | 2016-12-08 00:01:07 HD Request # 20 | Requesting historical Daily data for ESZ16 starting at 2016-12-05 | 2016-12-08 00:01:07 HD Request # 20 | Receiving historical Daily data for ESZ6 starting at 2016-12-06 | 2016-12-08 00:01:08 HD Request # 20 | Writing historical Daily data to the file ESZ6.dly | 2016-12-08 00:01:08 HD Request # 20 | Received 3 records from 2016-12-06 00:00:00 to 2016-12-07 00:00:00 (2.0 days) and wrote 2 records for ESZ6 | 2016-12-08 00:01:08 HD Request # 20 | Daily download COMPLETE for ESZ6. Completion time: 0s. Unique request ID: 19 | 2016-12-08 00:01:08 Removed historical data download ID 19 | 2016-12-08 00:01:08 HD Server | HD Request # 18 | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 2 | ClientRequestID: 18 | Username: User252419. | 2016-12-08 00:01:08 Socket (0) | Closed. No error. | 2016-12-08 00:01:08 Socket (0) | Shutdown and closed. | 2016-12-08 00:01:08 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 00:01:08 Opened cached Intraday file: C:\SierraChart\Data\GCLF7.scid | 2016-12-08 00:01:15 HTTP connection to ds01.ddfplus.com:80 (764) | Closed. No error. | 2016-12-08 00:02:13 HTTP connection to ds01.ddfplus.com:80 (764) | Shutdown and closed. | 2016-12-08 00:02:13 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ZCH7.2016-12-07.depth | 2016-12-08 00:04:37 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\GCLF7.2016-12-08.depth | 2016-12-08 01:00:00 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ6.2016-12-08.depth | 2016-12-08 01:00:00 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ZCH7.2016-12-08.depth | 2016-12-08 01:00:09 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 02:00:01 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 02:00:01 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 02:00:01 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 02:00:01 HD Server | HD Request | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2016-12-05 00:00:00 | ClientRequestID: 19 | Username: User252419. | 2016-12-08 02:00:01 HD Request # 21 | Downloading Historical Daily chart data for ZCH7. Starting date: 2016-12-05. Service: oec | 2016-12-08 02:00:01 Historical data download counter reset. | 2016-12-08 02:00:01 HD Request # 21 | Requesting historical Daily data for ZCH17 starting at 2016-12-04 | 2016-12-08 02:00:01 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-12-08 02:00:01 HTTP connection to ds01.ddfplus.com:80 (831) | Connected. | 2016-12-08 02:00:01 Opened cached Intraday file: C:\SierraChart\Data\ZCH7.scid | 2016-12-08 02:00:01 HD Request # 21 | Receiving historical Daily data for ZCH7 starting at 2016-12-05 | 2016-12-08 02:00:01 HD Request # 21 | Writing historical Daily data to the file ZCH7.dly | 2016-12-08 02:00:01 HD Request # 21 | Received 3 records from 2016-12-05 00:00:00 to 2016-12-07 00:00:00 (3.0 days) and wrote 3 records for ZCH7 | 2016-12-08 02:00:01 HD Request # 21 | Daily download COMPLETE for ZCH7. Completion time: 1s. Unique request ID: 20 | 2016-12-08 02:00:01 Removed historical data download ID 20 | 2016-12-08 02:00:01 HD Server | HD Request # 19 | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientRequestID: 19 | Username: User252419. | 2016-12-08 02:00:02 Socket (0) | Closed. No error. | 2016-12-08 02:00:02 Socket (0) | Shutdown and closed. | 2016-12-08 02:00:02 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 02:00:02 HTTP connection to ds01.ddfplus.com:80 (831) | Closed. No error. | 2016-12-08 02:01:06 HTTP connection to ds01.ddfplus.com:80 (831) | Shutdown and closed. | 2016-12-08 02:01:06 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2016-12-08 03:36:23 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2016-12-08 07:36:23 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2016-12-08 11:36:24 GAIN Capital FIX Trading socket (766) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-12-08 14:20:37 GAIN Capital FIX Trading socket (766) | SSL shutdown indicates not able to send 'close notify'. | 2016-12-08 14:20:37 GAIN Capital FIX Trading socket (766) | SSL has been shut down. | 2016-12-08 14:20:37 GAIN Capital FIX Trading socket (766) | SSL object has been freed. SSL state is now disconnected. | 2016-12-08 14:20:37 GAIN Capital FIX Trading socket (766) | Shutdown and closed. | 2016-12-08 14:20:37 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-12-08 14:20:37 Connection to the external service has been lost. | 2016-12-08 14:20:37 GAIN Capital/OEC | Disconnected from the trading server. | 2016-12-08 14:20:37 GAIN Capital FAST Data: Sending a Logout message. | 2016-12-08 14:20:37 GAIN Capital/OEC | Disconnected. | 2016-12-08 14:20:37 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-12-08 14:20:37 GAIN Capital FAST Data socket (767) | Closed. No error. | 2016-12-08 14:20:37 GAIN Capital FAST Data socket (767) | Shutdown and closed. | 2016-12-08 14:20:37 GAIN Capital FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2016-12-08 14:20:37 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-12-08 14:20:37 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-12-08 14:20:40 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-12-08 14:20:40 GAIN Capital FIX Trading socket (1211) | Connected. | 2016-12-08 14:20:46 GAIN Capital FIX Trading socket (1211) | Starting TLS 1.2 connection. | 2016-12-08 14:20:46 GAIN Capital FIX Trading socket (1211) | SSL connection established. | 2016-12-08 14:20:46 GAIN Capital FIX Trading: Sending the Logon message. | 2016-12-08 14:20:46 GAIN Capital FIX Trading | Connected to trading server. | 2016-12-08 14:20:47 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2016-12-08 14:20:47 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-12-08 14:20:47 GAIN Capital FAST Data socket (1212) | Connected. | 2016-12-08 14:20:47 GAIN Capital FAST Data: Sending the Hello message. | 2016-12-08 14:20:47 GAIN Capital FAST Data: Sending the Logon message. | 2016-12-08 14:20:47 GAIN Capital/OEC | Connected to data and trading server. | 2016-12-08 14:20:47 GAIN Capital/OEC | Starting real-time market data updates for: ESZ6. ID: 1 | 2016-12-08 14:20:47 GAIN Capital/OEC | Requesting security definition data for: ESZ6. ID: 1 | 2016-12-08 14:20:47 Intraday data recording state for symbol ESZ6 is set to download 'Pending'. | 2016-12-08 14:20:47 Market data subscription status is not known while delaying historical data download for symbol: ESZ6 | 2016-12-08 14:20:47 Delaying start of download for ESZ6 | 2016-12-08 14:20:47 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 14:20:47 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 14:20:47 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 14:20:47 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 14:20:47 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 14:20:47 HD Server | HD Request | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-08 13:20:34 | ClientRequestID: 20 | Username: User252419. | 2016-12-08 14:20:47 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 14:20:47 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 14:20:47 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 14:20:47 GAIN Capital/OEC | Starting real-time market data updates for: ZCH7. ID: 2 | 2016-12-08 14:20:47 HD Server | HD Request | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-08 13:20:34 | ClientRequestID: 9 | Username: User252419. | 2016-12-08 14:20:47 GAIN Capital/OEC | Requesting security definition data for: ZCH7. ID: 2 | 2016-12-08 14:20:47 Intraday data recording state for symbol ZCH7 is set to download 'Pending'. | 2016-12-08 14:20:47 Market data subscription status is not known while delaying historical data download for symbol: ESZ6 | 2016-12-08 14:20:47 GAIN Capital/OEC | Starting real-time market data updates for: GCLF7. ID: 3 | 2016-12-08 14:20:47 GAIN Capital/OEC | Requesting security definition data for: GCLF7. ID: 3 | 2016-12-08 14:20:47 Intraday data recording state for symbol GCLF7 is set to download 'Pending'. | 2016-12-08 14:20:47 Market data subscription status is not known while delaying historical data download for symbol: ESZ6 | 2016-12-08 14:20:47 Requesting market depth updates for: ESZ6 if supported. | 2016-12-08 14:20:47 Requesting market depth updates for: GCLF7 if supported. | 2016-12-08 14:20:47 Requesting market depth updates for: ZCH7 if supported. | 2016-12-08 14:20:47 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\GCLF7.2016-12-08.depth | 2016-12-08 14:20:47 GAIN Capital/OEC | Starting real-time market data updates for: NQZ6. ID: 4 | 2016-12-08 14:20:48 GAIN Capital/OEC | Requesting security definition data for: NQZ6. ID: 4 | 2016-12-08 14:20:48 GAIN Capital/OEC | Starting real-time market data updates for: YMZ6. ID: 5 | 2016-12-08 14:20:48 GAIN Capital/OEC | Requesting security definition data for: YMZ6. ID: 5 | 2016-12-08 14:20:48 Delaying start of download for ESZ6 | 2016-12-08 14:20:48 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ6.2016-12-08.depth | 2016-12-08 14:20:48 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ZCH7.2016-12-08.depth | 2016-12-08 14:20:51 HD Request # 22 | Downloading Intraday chart data for ESZ6 to the file ESZ6.scid. Service: oec | 2016-12-08 14:20:55 HD Request # 22 | Download start date-time: 2016-12-08 14:20:34.000 | 2016-12-08 14:20:55 HD Request # 22 | Using server: ds3.sierracharts.com port 10149 | 2016-12-08 14:20:55 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-08 14:20:55 Socket (1213) | Connected. | 2016-12-08 14:20:55 HD Request # 22 | Setting DTC encoding to Binary VLS | 2016-12-08 14:20:56 HD Request # 22 | Sending historical data logon request message. | 2016-12-08 14:20:56 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2016-12-08 14:20:56 HD Request # 22 | Requesting Intraday data. Start date-time: 2016-12-08 14:20:34. Record interval: 0. Symbol: ESZ6 | 2016-12-08 14:20:56 HD Request # 22 | Decompressing data. | 2016-12-08 14:20:57 HD Request # 22 | Receiving Intraday data for ESZ6 starting at 2016-12-08 14:20:34 | 2016-12-08 14:20:57 HD Request # 22 | Timestamp of first Intraday data file record written: 2016-12-08 14:20:40 | 2016-12-08 14:20:57 Socket (1213) | Shutdown and closed. | 2016-12-08 14:20:57 The network socket for historical data has been closed. | 2016-12-08 14:20:57 HD Request # 22 | Received 47 records from 2016-12-08 14:20:34 to 2016-12-08 14:20:50 (16.0 seconds) and wrote 46 records for ESZ6 | 2016-12-08 14:20:57 HD Request # 22 | Intraday download COMPLETE for ESZ6. Completion time: 0s. Unique request ID: 21 | 2016-12-08 14:20:57 Removed historical data download ID 21 | 2016-12-08 14:20:57 Real-time Intraday chart data file updates started for ESZ6 | 2016-12-08 14:20:57 Intraday chart data file opened for ESZ6 | 2016-12-08 14:20:57 HD Request # 23 | Downloading Intraday chart data for ZCH7 to the file ZCH7.scid. Service: oec | 2016-12-08 14:20:57 HD Request # 23 | Download start date-time: 2016-12-08 14:20:21.000 | 2016-12-08 14:20:57 HD Request # 23 | Using server: ds4.sierracharts.com port 10149 | 2016-12-08 14:20:57 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-08 14:20:57 Socket (1214) | Connected. | 2016-12-08 14:20:57 HD Request # 23 | Setting DTC encoding to Binary VLS | 2016-12-08 14:20:57 HD Request # 23 | Sending historical data logon request message. | 2016-12-08 14:20:57 HD Request # 23 | Requesting Intraday data. Start date-time: 2016-12-08 14:20:21. Record interval: 0. Symbol: ZCH7 | 2016-12-08 14:20:57 HD Request # 23 | Decompressing data. | 2016-12-08 14:20:58 HD Request # 23 | Receiving Intraday data for ZCH7 starting at 2016-12-08 14:20:21 | 2016-12-08 14:20:58 HD Request # 23 | Timestamp of first Intraday data file record written: 2016-12-08 14:20:52 | 2016-12-08 14:20:58 Socket (1214) | Shutdown and closed. | 2016-12-08 14:20:58 The network socket for historical data has been closed. | 2016-12-08 14:20:58 HD Request # 23 | Received 2 records from 2016-12-08 14:20:21 to 2016-12-08 14:20:52 (31.0 seconds) and wrote 1 record for ZCH7 | 2016-12-08 14:20:58 HD Request # 23 | Intraday download COMPLETE for ZCH7. Completion time: 1s. Unique request ID: 22 | 2016-12-08 14:20:58 Removed historical data download ID 22 | 2016-12-08 14:20:58 Real-time Intraday chart data file updates started for ZCH7 | 2016-12-08 14:20:58 Intraday chart data file opened for ZCH7 | 2016-12-08 14:20:58 HD Request # 24 | Downloading Intraday chart data for GCLF7 to the file GCLF7.scid. Service: oec | 2016-12-08 14:20:58 HD Request # 24 | Download start date-time: 2016-12-08 14:20:34.000 | 2016-12-08 14:20:58 HD Request # 24 | Using server: ds3.sierracharts.com port 10149 | 2016-12-08 14:20:58 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-08 14:20:58 HD Server | HD Request # 20 | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 47 | ClientRequestID: 20 | Username: User252419. | 2016-12-08 14:20:58 HD Server | HD Request # 9 | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 47 | ClientRequestID: 9 | Username: User252419. | 2016-12-08 14:20:58 Socket (0) | Closed. No error. | 2016-12-08 14:20:58 Socket (0) | Closed. No error. | 2016-12-08 14:20:58 Socket (0) | Shutdown and closed. | 2016-12-08 14:20:58 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 14:20:58 Socket (0) | Shutdown and closed. | 2016-12-08 14:20:58 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 14:20:58 Socket (1215) | Connected. | 2016-12-08 14:20:58 HD Request # 24 | Setting DTC encoding to Binary VLS | 2016-12-08 14:20:58 HD Request # 24 | Sending historical data logon request message. | 2016-12-08 14:20:58 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 14:20:58 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 14:20:58 HD Request # 24 | Requesting Intraday data. Start date-time: 2016-12-08 14:20:34. Record interval: 0. Symbol: GCLF7 | 2016-12-08 14:20:58 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 14:20:58 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 14:20:58 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 14:20:58 HD Server | HD Request | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-08 13:20:21 | ClientRequestID: 10 | Username: User252419. | 2016-12-08 14:20:58 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 14:20:58 HD Server | HD Request # 10 | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 2 | ClientRequestID: 10 | Username: User252419. | 2016-12-08 14:20:58 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 14:20:58 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 14:20:58 HD Server | HD Request | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-08 13:20:34 | ClientRequestID: 21 | Username: User252419. | 2016-12-08 14:20:58 Socket (0) | Closed. No error. | 2016-12-08 14:20:58 Socket (0) | Shutdown and closed. | 2016-12-08 14:20:58 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 14:20:58 HD Request # 24 | Decompressing data. | 2016-12-08 14:20:58 HD Request # 24 | Receiving Intraday data for GCLF7 starting at 2016-12-08 14:20:34 | 2016-12-08 14:20:58 HD Request # 24 | Timestamp of first Intraday data file record written: 2016-12-08 14:20:37 | 2016-12-08 14:20:58 Socket (1215) | Shutdown and closed. | 2016-12-08 14:20:58 The network socket for historical data has been closed. | 2016-12-08 14:20:58 HD Request # 24 | Received 49 records from 2016-12-08 14:20:34 to 2016-12-08 14:20:55 (21.0 seconds) and wrote 47 records for GCLF7 | 2016-12-08 14:20:58 HD Request # 24 | Intraday download COMPLETE for GCLF7. Completion time: 1s. Unique request ID: 23 | 2016-12-08 14:20:58 Removed historical data download ID 23 | 2016-12-08 14:20:58 Real-time Intraday chart data file updates started for GCLF7 | 2016-12-08 14:20:58 Intraday chart data file opened for GCLF7 | 2016-12-08 14:20:58 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 14:20:58 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 14:20:58 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 14:20:58 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 14:20:58 HD Server | HD Request | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-08 13:20:34 | ClientRequestID: 11 | Username: User252419. | 2016-12-08 14:20:58 HD Server | HD Request # 11 | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 49 | ClientRequestID: 11 | Username: User252419. | 2016-12-08 14:20:58 Socket (0) | Closed. No error. | 2016-12-08 14:20:58 Socket (0) | Shutdown and closed. | 2016-12-08 14:20:58 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 14:20:58 HD Server | HD Request # 21 | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 49 | ClientRequestID: 21 | Username: User252419. | 2016-12-08 14:20:58 Socket (0) | Closed. No error. | 2016-12-08 14:20:58 Socket (0) | Shutdown and closed. | 2016-12-08 14:20:58 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 14:20:58 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 14:20:58 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 14:20:58 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 14:20:58 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 14:20:58 HD Server | HD Request | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-08 13:20:21 | ClientRequestID: 22 | Username: User252419. | 2016-12-08 14:20:58 HD Server | HD Request # 22 | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 2 | ClientRequestID: 22 | Username: User252419. | 2016-12-08 14:20:58 Socket (0) | Closed. No error. | 2016-12-08 14:20:58 Socket (0) | Shutdown and closed. | 2016-12-08 14:20:58 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 14:20:58 Opened cached Intraday file: C:\SierraChart\Data\ESZ6.scid | 2016-12-08 14:21:01 Opened cached Intraday file: C:\SierraChart\Data\GCLF7.scid | 2016-12-08 14:21:01 Opened cached Intraday file: C:\SierraChart\Data\ZCH7.scid | 2016-12-08 14:21:12 ESH7 30 Sec #14 | Reloading chart. | 2016-12-08 14:49:31 ESH7 30 Sec #14 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH7.scid | 2016-12-08 14:49:31 GAIN Capital/OEC | Starting real-time market data updates for: ESH7. ID: 6 | 2016-12-08 14:49:32 GAIN Capital/OEC | Requesting security definition data for: ESH7. ID: 6 | 2016-12-08 14:49:32 Requesting market depth updates for: ESH7 if supported. | 2016-12-08 14:49:32 Intraday data recording state for symbol ESH7 is set to download 'Pending'. | 2016-12-08 14:49:32 Market data subscription status is not known while delaying historical data download for symbol: ESH7 | 2016-12-08 14:49:32 Delaying start of download for ESH7 | 2016-12-08 14:49:32 Symbol Error - ESH7 is unknown, unavailable, or improperly formatted. FIX reject reason: Your subscription limit of 5 has been reached | 2016-12-08 14:49:32 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESH7.2016-12-08.depth | 2016-12-08 14:49:32 Delaying start of download for ESH7 | 2016-12-08 14:49:33 HD Request # 25 | Downloading Intraday chart data for ESH7 to the file ESH7.scid. Service: oec | 2016-12-08 14:49:38 Compressing file: C:\SierraChart\Data\ESH7.scid. This may take a while. | 2016-12-08 14:49:38 HD Request # 25 | Download start date-time: 2016-06-05 15:49:37.000 | 2016-12-08 14:49:38 HD Request # 25 | Using server: ds4.sierracharts.com port 10149 | 2016-12-08 14:49:38 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-08 14:49:38 Socket (1231) | Connected. | 2016-12-08 14:49:38 HD Request # 25 | Setting DTC encoding to Binary VLS | 2016-12-08 14:49:38 HD Request # 25 | Sending historical data logon request message. | 2016-12-08 14:49:38 HD Request # 25 | Requesting Intraday data. Start date-time: 2016-06-05 15:49:37. Record interval: 0. Symbol: ESH7 | 2016-12-08 14:49:39 HD Request # 25 | Decompressing data. | 2016-12-08 14:49:39 HD Request # 25 | Receiving Intraday data for ESH7 starting at 2016-06-06 16:00:34 | 2016-12-08 14:49:39 HD Request # 25 | Timestamp of first Intraday data file record written: 2016-06-06 16:00:34 | 2016-12-08 14:49:39 Socket (1231) | Shutdown and closed. | 2016-12-08 14:49:40 The network socket for historical data has been closed. | 2016-12-08 14:49:40 HD Request # 25 | Received 163406 records from 2016-06-06 16:00:34 to 2016-12-08 14:49:37 (185.0 days) and wrote 163406 records for ESH7 | 2016-12-08 14:49:40 HD Request # 25 | Intraday download COMPLETE for ESH7. Completion time: 3s. Unique request ID: 24 | 2016-12-08 14:49:40 Removed historical data download ID 24 | 2016-12-08 14:49:40 Real-time Intraday chart data file updates started for ESH7 | 2016-12-08 14:49:40 Intraday chart data file opened for ESH7 | 2016-12-08 14:49:40 ESH7 1 Min #3 | Reloading chart. | 2016-12-08 14:50:13 ESH7 300 Trades #4 | Reloading chart. | 2016-12-08 14:50:45 ESH7 3 Sec #6 | Reloading chart. | 2016-12-08 14:51:02 ESH7 #1 | Reloading chart. | 2016-12-08 14:51:17 ESH7 300 Trades #2 | Reloading chart. | 2016-12-08 15:33:58 Intraday data recording state for symbol ESH7 is set to download 'Pending'. | 2016-12-08 15:35:25 HD Request # 26 | Downloading Intraday chart data for ESH7 to the file ESH7.scid. Service: oec | 2016-12-08 15:35:25 HD Request # 26 | Download start date-time: 2016-12-08 11:39:59.000 | 2016-12-08 15:35:25 HD Request # 26 | Disabling Intraday chart updating for symbol during historical data download. | 2016-12-08 15:35:25 HD Request # 26 | Using server: ds3.sierracharts.com port 10149 | 2016-12-08 15:35:25 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-08 15:35:25 Socket (1255) | Connected. | 2016-12-08 15:35:25 HD Request # 26 | Setting DTC encoding to Binary VLS | 2016-12-08 15:35:26 HD Request # 26 | Sending historical data logon request message. | 2016-12-08 15:35:26 HD Request # 26 | Requesting Intraday data. Start date-time: 2016-12-08 11:39:59. Record interval: 0. Symbol: ESH7 | 2016-12-08 15:35:26 HD Request # 26 | Decompressing data. | 2016-12-08 15:35:26 HD Request # 26 | Receiving Intraday data for ESH7 starting at 2016-12-08 11:40:03 | 2016-12-08 15:35:26 HD Request # 26 | Truncating file to starting date-time of 2016-12-08 11:40:03 | 2016-12-08 15:35:26 HD Request # 26 | Timestamp of first Intraday data file record written: 2016-12-08 11:40:03 | 2016-12-08 15:35:26 Socket (1255) | Shutdown and closed. | 2016-12-08 15:35:26 The network socket for historical data has been closed. | 2016-12-08 15:35:26 HD Request # 26 | Received 16671 records from 2016-12-08 11:40:03 to 2016-12-08 15:35:25 (3.9 hours) and wrote 16671 records for ESH7 | 2016-12-08 15:35:26 HD Request # 26 | Intraday download COMPLETE for ESH7. Completion time: 1s. Unique request ID: 25 | 2016-12-08 15:35:26 Removed historical data download ID 25 | 2016-12-08 15:35:26 Real-time Intraday chart data file updates started for ESH7 | 2016-12-08 15:35:26 Intraday chart data file opened for ESH7 | 2016-12-08 15:35:26 HD Request # 26 | Enabling Intraday chart updating for symbol. | 2016-12-08 15:35:26 HD Request # 26 | Reloading Intraday charts for ESH7 | 2016-12-08 15:35:26 Reloading all charts with filename: ESH7.scid | 2016-12-08 15:35:26 ESH7 300 Trades #4 | Reloading chart. | 2016-12-08 15:35:27 ESH7 1 Min #3 | Reloading chart. | 2016-12-08 15:35:27 ESH7 3 Sec #6 | Reloading chart. | 2016-12-08 15:35:27 ESH7 #1 | Reloading chart. | 2016-12-08 15:35:27 ESH7 30 Sec #14 | Reloading chart. | 2016-12-08 15:35:27 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2016-12-08 15:36:24 Intraday data recording state for symbol ESH7 is set to download 'Pending'. | 2016-12-08 16:15:04 HD Request # 27 | Downloading Intraday chart data for ESH7 to the file ESH7.scid. Service: oec | 2016-12-08 16:15:04 HD Request # 27 | Download start date-time: 2016-12-08 15:16:59.000 | 2016-12-08 16:15:04 HD Request # 27 | Disabling Intraday chart updating for symbol during historical data download. | 2016-12-08 16:15:04 HD Request # 27 | Using server: ds4.sierracharts.com port 10149 | 2016-12-08 16:15:04 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-08 16:15:04 Socket (1277) | Connected. | 2016-12-08 16:15:04 HD Request # 27 | Setting DTC encoding to Binary VLS | 2016-12-08 16:15:05 HD Request # 27 | Sending historical data logon request message. | 2016-12-08 16:15:05 HD Request # 27 | Requesting Intraday data. Start date-time: 2016-12-08 15:16:59. Record interval: 0. Symbol: ESH7 | 2016-12-08 16:15:05 HD Request # 27 | Decompressing data. | 2016-12-08 16:15:05 HD Request # 27 | Receiving Intraday data for ESH7 starting at 2016-12-08 15:17:01 | 2016-12-08 16:15:05 HD Request # 27 | Truncating file to starting date-time of 2016-12-08 15:17:01 | 2016-12-08 16:15:05 HD Request # 27 | Timestamp of first Intraday data file record written: 2016-12-08 15:17:01 | 2016-12-08 16:15:05 Socket (1277) | Shutdown and closed. | 2016-12-08 16:15:06 The network socket for historical data has been closed. | 2016-12-08 16:15:06 HD Request # 27 | Received 26600 records from 2016-12-08 15:17:01 to 2016-12-08 16:15:02 (58.0 minutes) and wrote 26600 records for ESH7 | 2016-12-08 16:15:06 HD Request # 27 | Intraday download COMPLETE for ESH7. Completion time: 2s. Unique request ID: 26 | 2016-12-08 16:15:06 Removed historical data download ID 26 | 2016-12-08 16:15:06 Real-time Intraday chart data file updates started for ESH7 | 2016-12-08 16:15:06 Intraday chart data file opened for ESH7 | 2016-12-08 16:15:06 HD Request # 27 | Enabling Intraday chart updating for symbol. | 2016-12-08 16:15:06 HD Request # 27 | Reloading Intraday charts for ESH7 | 2016-12-08 16:15:06 Reloading all charts with filename: ESH7.scid | 2016-12-08 16:15:06 ESH7 30 Sec #14 | Reloading chart. | 2016-12-08 16:15:06 ESH7 3 Sec #6 | Reloading chart. | 2016-12-08 16:15:06 ESH7 300 Trades #4 | Reloading chart. | 2016-12-08 16:15:06 ESH7 1 Min #3 | Reloading chart. | 2016-12-08 16:15:07 ESH7 #1 | Reloading chart. | 2016-12-08 16:15:07 Intraday data recording state for symbol ESH7 is set to download 'Pending'. | 2016-12-08 17:31:14 HD Request # 28 | Downloading Intraday chart data for ESH7 to the file ESH7.scid. Service: oec | 2016-12-08 17:31:14 HD Request # 28 | Download start date-time: 2016-12-08 16:05:59.000 | 2016-12-08 17:31:14 HD Request # 28 | Disabling Intraday chart updating for symbol during historical data download. | 2016-12-08 17:31:14 HD Request # 28 | Using server: ds3.sierracharts.com port 10149 | 2016-12-08 17:31:14 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-08 17:31:14 Socket (1316) | Connected. | 2016-12-08 17:31:14 HD Request # 28 | Setting DTC encoding to Binary VLS | 2016-12-08 17:31:14 HD Request # 28 | Sending historical data logon request message. | 2016-12-08 17:31:14 HD Request # 28 | Requesting Intraday data. Start date-time: 2016-12-08 16:05:59. Record interval: 0. Symbol: ESH7 | 2016-12-08 17:31:16 HD Request # 28 | Decompressing data. | 2016-12-08 17:31:16 HD Request # 28 | Receiving Intraday data for ESH7 starting at 2016-12-08 16:05:59 | 2016-12-08 17:31:16 HD Request # 28 | Truncating file to starting date-time of 2016-12-08 16:05:59 | 2016-12-08 17:31:16 HD Request # 28 | Timestamp of first Intraday data file record written: 2016-12-08 16:05:59 | 2016-12-08 17:31:16 Socket (1316) | Shutdown and closed. | 2016-12-08 17:31:16 The network socket for historical data has been closed. | 2016-12-08 17:31:16 HD Request # 28 | Received 22272 records from 2016-12-08 16:05:59 to 2016-12-08 17:31:09 (85.2 minutes) and wrote 22272 records for ESH7 | 2016-12-08 17:31:16 HD Request # 28 | Intraday download COMPLETE for ESH7. Completion time: 2s. Unique request ID: 27 | 2016-12-08 17:31:16 Removed historical data download ID 27 | 2016-12-08 17:31:16 Real-time Intraday chart data file updates started for ESH7 | 2016-12-08 17:31:16 Intraday chart data file opened for ESH7 | 2016-12-08 17:31:16 HD Request # 28 | Enabling Intraday chart updating for symbol. | 2016-12-08 17:31:16 HD Request # 28 | Reloading Intraday charts for ESH7 | 2016-12-08 17:31:16 Reloading all charts with filename: ESH7.scid | 2016-12-08 17:31:16 ESH7 3 Sec #6 | Reloading chart. | 2016-12-08 17:31:16 ESH7 300 Trades #4 | Reloading chart. | 2016-12-08 17:31:16 ESH7 1 Min #3 | Reloading chart. | 2016-12-08 17:31:16 ESH7 #1 | Reloading chart. | 2016-12-08 17:31:17 ESH7 30 Sec #14 | Reloading chart. | 2016-12-08 17:31:17 Intraday data recording state for symbol ESH7 is set to download 'Pending'. | 2016-12-08 18:36:34 Reloading all charts with filename: ESH7.scid | 2016-12-08 18:36:34 HD Request # 29 | Downloading Intraday chart data for ESH7 to the file ESH7.scid. Service: oec | 2016-12-08 18:36:34 HD Request # 29 | Download start date-time: 2016-12-08 15:29:59.000 | 2016-12-08 18:36:34 HD Request # 29 | Using server: ds4.sierracharts.com port 10149 | 2016-12-08 18:36:34 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-08 18:36:34 Socket (1350) | Connected. | 2016-12-08 18:36:34 ESH7 3 Sec #6 | Reloading chart. | 2016-12-08 18:36:34 HD Request # 29 | Setting DTC encoding to Binary VLS | 2016-12-08 18:36:34 HD Request # 29 | Sending historical data logon request message. | 2016-12-08 18:36:34 ESH7 300 Trades #4 | Reloading chart. | 2016-12-08 18:36:34 ESH7 30 Sec #14 | Reloading chart. | 2016-12-08 18:36:35 HD Request # 29 | Requesting Intraday data. Start date-time: 2016-12-08 15:29:59. Record interval: 0. Symbol: ESH7 | 2016-12-08 18:36:35 ESH7 #1 | Reloading chart. | 2016-12-08 18:36:35 HD Request # 29 | Decompressing data. | 2016-12-08 18:36:35 HD Request # 29 | Receiving Intraday data for ESH7 starting at 2016-12-08 15:29:59 | 2016-12-08 18:36:35 HD Request # 29 | Timestamp of first Intraday data file record written: 2016-12-08 15:30:00 | 2016-12-08 18:36:35 ESH7 1 Min #3 | Reloading chart. | 2016-12-08 18:36:35 Socket (1350) | Shutdown and closed. | 2016-12-08 18:36:35 The network socket for historical data has been closed. | 2016-12-08 18:36:35 HD Request # 29 | Received 57330 records from 2016-12-08 15:29:59 to 2016-12-08 18:36:27 (3.1 hours) and wrote 57329 records for ESH7 | 2016-12-08 18:36:35 HD Request # 29 | Intraday download COMPLETE for ESH7. Completion time: 0s. Unique request ID: 28 | 2016-12-08 18:36:35 Removed historical data download ID 28 | 2016-12-08 18:36:35 Real-time Intraday chart data file updates started for ESH7 | 2016-12-08 18:36:35 Intraday chart data file opened for ESH7 | 2016-12-08 18:36:35 Intraday data recording state for symbol ESH7 is set to download 'Pending'. | 2016-12-08 18:37:00 Reloading all charts with filename: ESH7.scid | 2016-12-08 18:37:00 HD Request # 30 | Downloading Intraday chart data for ESH7 to the file ESH7.scid. Service: oec | 2016-12-08 18:37:00 HD Request # 30 | Download start date-time: 2016-12-08 15:17:47.000 | 2016-12-08 18:37:00 HD Request # 30 | Using server: ds3.sierracharts.com port 10149 | 2016-12-08 18:37:00 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-08 18:37:00 Socket (1352) | Connected. | 2016-12-08 18:37:00 ESH7 30 Sec #14 | Reloading chart. | 2016-12-08 18:37:00 HD Request # 30 | Setting DTC encoding to Binary VLS | 2016-12-08 18:37:00 HD Request # 30 | Sending historical data logon request message. | 2016-12-08 18:37:00 ESH7 3 Sec #6 | Reloading chart. | 2016-12-08 18:37:00 ESH7 #1 | Reloading chart. | 2016-12-08 18:37:00 HD Request # 30 | Requesting Intraday data. Start date-time: 2016-12-08 15:17:47. Record interval: 0. Symbol: ESH7 | 2016-12-08 18:37:00 ESH7 1 Min #3 | Reloading chart. | 2016-12-08 18:37:00 HD Request # 30 | Decompressing data. | 2016-12-08 18:37:00 HD Request # 30 | Receiving Intraday data for ESH7 starting at 2016-12-08 15:17:47 | 2016-12-08 18:37:00 HD Request # 30 | Timestamp of first Intraday data file record written: 2016-12-08 15:18:02 | 2016-12-08 18:37:00 ESH7 300 Trades #4 | Reloading chart. | 2016-12-08 18:37:00 Socket (1352) | Shutdown and closed. | 2016-12-08 18:37:01 The network socket for historical data has been closed. | 2016-12-08 18:37:01 HD Request # 30 | Received 58142 records from 2016-12-08 15:17:47 to 2016-12-08 18:36:58 (3.3 hours) and wrote 58140 records for ESH7 | 2016-12-08 18:37:01 HD Request # 30 | Intraday download COMPLETE for ESH7. Completion time: 2s. Unique request ID: 29 | 2016-12-08 18:37:01 Removed historical data download ID 29 | 2016-12-08 18:37:01 Real-time Intraday chart data file updates started for ESH7 | 2016-12-08 18:37:01 Intraday chart data file opened for ESH7 | 2016-12-08 18:37:01 Reloading all charts with filename: ESH7.scid | 2016-12-08 18:37:11 ESH7 1 Min #3 | Reloading chart. | 2016-12-08 18:37:11 ESH7 3 Sec #6 | Reloading chart. | 2016-12-08 18:37:11 ESH7 300 Trades #4 | Reloading chart. | 2016-12-08 18:37:11 ESH7 #1 | Reloading chart. | 2016-12-08 18:37:11 ESH7 30 Sec #14 | Reloading chart. | 2016-12-08 18:37:11 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2016-12-08 19:36:24 Requesting symbol settings for oec. Overwrite = on. | 2016-12-08 20:18:59 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-12-08 20:18:59 HTTPS connection to www.sierrachart.com:443 (1405) | Connected. | 2016-12-08 20:18:59 HTTPS connection to www.sierrachart.com:443 (1405) | Starting TLS 1.2 connection. | 2016-12-08 20:18:59 HTTPS connection to www.sierrachart.com:443 (1405) | SSL connection established. | 2016-12-08 20:19:00 Symbol settings received. | 2016-12-08 20:19:00 Processed 835 symbol settings. | 2016-12-08 20:19:00 It is recommended to reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed' | 2016-12-08 20:19:00 HTTPS connection to www.sierrachart.com:443 (1405) | SSL connection closed by remote side. | 2016-12-08 20:19:05 HTTPS connection to www.sierrachart.com:443 (1405) | Connection gracefully closed by remote side. | 2016-12-08 20:19:05 HTTPS connection to www.sierrachart.com:443 (1405) | SSL object has been freed. SSL state is now disconnected. | 2016-12-08 20:19:05 HTTPS connection to www.sierrachart.com:443 (1405) | Shutdown and closed. | 2016-12-08 20:19:05 File >> Disconnect selected. | 2016-12-08 20:20:16 GAIN Capital FIX Trading: DisconnectFIX called. | 2016-12-08 20:20:16 GAIN Capital FIX Trading: Sending a Logout message. | 2016-12-08 20:20:16 GAIN Capital FAST Data: Sending a Logout message. | 2016-12-08 20:20:16 GAIN Capital/OEC | Disconnected. | 2016-12-08 20:20:16 GAIN Capital FAST Data socket (1212) | Closed. No error. | 2016-12-08 20:20:16 GAIN Capital FAST Data socket (1212) | Shutdown and closed. | 2016-12-08 20:20:16 GAIN Capital FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2016-12-08 20:20:16 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-12-08 20:20:16 GAIN Capital FIX Trading: Received a Logout message. | 2016-12-08 20:20:16 GAIN Capital FIX Trading socket (1211) | SSL shutdown indicates not able to send 'close notify'. | 2016-12-08 20:20:16 GAIN Capital FIX Trading socket (1211) | SSL has been shut down. | 2016-12-08 20:20:16 GAIN Capital FIX Trading socket (1211) | SSL object has been freed. SSL state is now disconnected. | 2016-12-08 20:20:16 GAIN Capital FIX Trading socket (1211) | Shutdown and closed. | 2016-12-08 20:20:16 GAIN Capital/OEC | Disconnected from the trading server. | 2016-12-08 20:20:16 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-12-08 20:20:18 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-12-08 20:20:18 GAIN Capital FIX Trading socket (1406) | Connected. | 2016-12-08 20:20:19 GAIN Capital FIX Trading socket (1406) | Starting TLS 1.2 connection. | 2016-12-08 20:20:19 GAIN Capital FIX Trading socket (1406) | SSL connection established. | 2016-12-08 20:20:19 GAIN Capital FIX Trading: Sending the Logon message. | 2016-12-08 20:20:19 GAIN Capital FIX Trading | Connected to trading server. | 2016-12-08 20:20:19 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2016-12-08 20:20:19 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-12-08 20:20:19 GAIN Capital FAST Data socket (1407) | Connected. | 2016-12-08 20:20:19 GAIN Capital FAST Data: Sending the Hello message. | 2016-12-08 20:20:19 GAIN Capital FAST Data: Sending the Logon message. | 2016-12-08 20:20:19 GAIN Capital/OEC | Connected to data and trading server. | 2016-12-08 20:20:20 GAIN Capital/OEC | Starting real-time market data updates for: ESZ6. ID: 1 | 2016-12-08 20:20:20 GAIN Capital/OEC | Requesting security definition data for: ESZ6. ID: 1 | 2016-12-08 20:20:20 GAIN Capital/OEC | Using primary service for historical data for ESZ6 | 2016-12-08 20:20:20 Intraday data recording state for symbol ESZ6 is set to download 'Pending'. | 2016-12-08 20:20:20 Market data subscription status is not known while delaying historical data download for symbol: ESZ6 | 2016-12-08 20:20:20 Delaying start of download for ESZ6 | 2016-12-08 20:20:20 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 20:20:20 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 20:20:20 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 20:20:20 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 20:20:20 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 20:20:20 HD Server | HD Request | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-08 19:20:15 | ClientRequestID: 12 | Username: User252419. | 2016-12-08 20:20:20 GAIN Capital/OEC | Starting real-time market data updates for: GCLF7. ID: 2 | 2016-12-08 20:20:20 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 20:20:20 GAIN Capital/OEC | Requesting security definition data for: GCLF7. ID: 2 | 2016-12-08 20:20:20 Intraday data recording state for symbol GCLF7 is set to download 'Pending'. | 2016-12-08 20:20:20 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 20:20:20 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 20:20:20 HD Server | HD Request | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-08 19:20:15 | ClientRequestID: 23 | Username: User252419. | 2016-12-08 20:20:20 Market data subscription status is not known while delaying historical data download for symbol: GCLF7 | 2016-12-08 20:20:20 Delaying start of download for GCLF7 | 2016-12-08 20:20:20 GAIN Capital/OEC | Starting real-time market data updates for: ESH7. ID: 3 | 2016-12-08 20:20:20 GAIN Capital/OEC | Requesting security definition data for: ESH7. ID: 3 | 2016-12-08 20:20:20 Intraday data recording state for symbol ESH7 is set to download 'Pending'. | 2016-12-08 20:20:20 Market data subscription status is not known while delaying historical data download for symbol: GCLF7 | 2016-12-08 20:20:20 GAIN Capital/OEC | Starting real-time market data updates for: ZCH7. ID: 4 | 2016-12-08 20:20:20 GAIN Capital/OEC | Requesting security definition data for: ZCH7. ID: 4 | 2016-12-08 20:20:20 Intraday data recording state for symbol ZCH7 is set to download 'Pending'. | 2016-12-08 20:20:20 Market data subscription status is not known while delaying historical data download for symbol: GCLF7 | 2016-12-08 20:20:20 Requesting market depth updates for: ESZ6 if supported. | 2016-12-08 20:20:20 Requesting market depth updates for: GCLF7 if supported. | 2016-12-08 20:20:20 Requesting market depth updates for: ZCH7 if supported. | 2016-12-08 20:20:20 Requesting market depth updates for: ESH7 if supported. | 2016-12-08 20:20:20 GAIN Capital/OEC | Starting real-time market data updates for: NQZ6. ID: 5 | 2016-12-08 20:20:20 GAIN Capital/OEC | Requesting security definition data for: NQZ6. ID: 5 | 2016-12-08 20:20:20 GAIN Capital/OEC | Starting real-time market data updates for: YMZ6. ID: 6 | 2016-12-08 20:20:20 GAIN Capital/OEC | Requesting security definition data for: YMZ6. ID: 6 | 2016-12-08 20:20:20 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESH7.2016-12-08.depth | 2016-12-08 20:20:20 Symbol Error - YMZ6 is unknown, unavailable, or improperly formatted. FIX reject reason: Your subscription limit of 5 has been reached | 2016-12-08 20:20:21 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\GCLF7.2016-12-08.depth | 2016-12-08 20:20:21 Delaying start of download for ESZ6 | 2016-12-08 20:20:21 Delaying start of download for GCLF7 | 2016-12-08 20:20:21 HD Request # 31 | Downloading Intraday chart data for ESZ6 to the file ESZ6.scid. Service: oec | 2016-12-08 20:20:25 HD Request # 31 | Download start date-time: 2016-12-08 20:20:15.000 | 2016-12-08 20:20:25 HD Request # 32 | Downloading Intraday chart data for GCLF7 to the file GCLF7.scid. Service: oec | 2016-12-08 20:20:25 HD Request # 32 | Download start date-time: 2016-12-08 20:20:14.000 | 2016-12-08 20:20:25 HD Request # 32 | Using server: ds4.sierracharts.com port 10149 | 2016-12-08 20:20:25 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-08 20:20:25 Socket (1408) | Connected. | 2016-12-08 20:20:25 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2016-12-08 20:20:25 HD Request # 31 | Receiving Intraday data for ESZ6 starting at 2016-12-08 20:20:15 | 2016-12-08 20:20:25 HD Request # 31 | Timestamp of first Intraday data file record written: 2016-12-08 20:20:15 | 2016-12-08 20:20:25 HD Request # 31 | Received 135 records from 2016-12-08 20:20:15 to 2016-12-08 20:20:23 (8.0 seconds) and wrote 107 records for ESZ6 | 2016-12-08 20:20:25 HD Request # 31 | Intraday download COMPLETE for ESZ6. Completion time: 1s. Unique request ID: 30 | 2016-12-08 20:20:25 Removed historical data download ID 30 | 2016-12-08 20:20:25 Real-time Intraday chart data file updates started for ESZ6 | 2016-12-08 20:20:25 Intraday chart data file opened for ESZ6 | 2016-12-08 20:20:25 HD Request # 32 | Setting DTC encoding to Binary VLS | 2016-12-08 20:20:25 HD Request # 32 | Sending historical data logon request message. | 2016-12-08 20:20:25 HD Request # 32 | Requesting Intraday data. Start date-time: 2016-12-08 20:20:14. Record interval: 0. Symbol: GCLF7 | 2016-12-08 20:20:26 HD Server | HD Request # 12 | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 135 | ClientRequestID: 12 | Username: User252419. | 2016-12-08 20:20:26 HD Server | HD Request # 23 | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 135 | ClientRequestID: 23 | Username: User252419. | 2016-12-08 20:20:26 Socket (0) | Closed. No error. | 2016-12-08 20:20:26 Socket (0) | Shutdown and closed. | 2016-12-08 20:20:26 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 20:20:26 Socket (0) | Closed. No error. | 2016-12-08 20:20:26 Socket (0) | Shutdown and closed. | 2016-12-08 20:20:26 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 20:20:26 HD Request # 32 | Decompressing data. | 2016-12-08 20:20:26 HD Request # 32 | Receiving Intraday data for GCLF7 starting at 2016-12-08 20:20:14 | 2016-12-08 20:20:26 HD Request # 32 | Timestamp of first Intraday data file record written: 2016-12-08 20:20:15 | 2016-12-08 20:20:26 Socket (1408) | Shutdown and closed. | 2016-12-08 20:20:26 The network socket for historical data has been closed. | 2016-12-08 20:20:26 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ZCH7.2016-12-08.depth | 2016-12-08 20:20:26 HD Request # 32 | Received 116 records from 2016-12-08 20:20:14 to 2016-12-08 20:20:23 (9.0 seconds) and wrote 95 records for GCLF7 | 2016-12-08 20:20:26 Added 30 Time and Sales records to Intraday data file for GCLF7 after download. | 2016-12-08 20:20:26 HD Request # 32 | Intraday download COMPLETE for GCLF7. Completion time: 0s. Unique request ID: 31 | 2016-12-08 20:20:26 Removed historical data download ID 31 | 2016-12-08 20:20:26 Real-time Intraday chart data file updates started for GCLF7 | 2016-12-08 20:20:26 Intraday chart data file opened for GCLF7 | 2016-12-08 20:20:26 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 20:20:26 HD Request # 33 | Downloading Intraday chart data for ESH7 to the file ESH7.scid. Service: oec | 2016-12-08 20:20:26 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 20:20:26 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 20:20:26 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 20:20:26 HD Request # 33 | Download start date-time: 2016-12-08 18:36:58.000 | 2016-12-08 20:20:26 HD Server | HD Request | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-08 19:20:14 | ClientRequestID: 24 | Username: User252419. | 2016-12-08 20:20:26 HD Request # 33 | Using server: ds3.sierracharts.com port 10149 | 2016-12-08 20:20:26 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-08 20:20:26 HD Server | HD Request # 24 | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 146 | ClientRequestID: 24 | Username: User252419. | 2016-12-08 20:20:26 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 20:20:26 Socket (0) | Closed. No error. | 2016-12-08 20:20:26 Socket (0) | Shutdown and closed. | 2016-12-08 20:20:26 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 20:20:26 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 20:20:26 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 20:20:26 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 20:20:26 HD Server | HD Request | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-08 19:19:59 | ClientRequestID: 13 | Username: User252419. | 2016-12-08 20:20:26 Socket (1409) | Connected. | 2016-12-08 20:20:26 HD Request # 33 | Setting DTC encoding to Binary VLS | 2016-12-08 20:20:26 HD Request # 33 | Sending historical data logon request message. | 2016-12-08 20:20:26 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 20:20:26 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 20:20:26 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 20:20:26 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 20:20:26 HD Server | HD Request | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-08 19:19:59 | ClientRequestID: 25 | Username: User252419. | 2016-12-08 20:20:26 HD Request # 33 | Requesting Intraday data. Start date-time: 2016-12-08 18:36:58. Record interval: 0. Symbol: ESH7 | 2016-12-08 20:20:27 HD Request # 33 | Decompressing data. | 2016-12-08 20:20:27 HD Request # 33 | Receiving Intraday data for ESH7 starting at 2016-12-08 18:36:58 | 2016-12-08 20:20:27 HD Request # 33 | Timestamp of first Intraday data file record written: 2016-12-08 18:37:00 | 2016-12-08 20:20:27 Socket (1409) | Shutdown and closed. | 2016-12-08 20:20:27 The network socket for historical data has been closed. | 2016-12-08 20:20:27 HD Request # 33 | Received 22019 records from 2016-12-08 18:36:58 to 2016-12-08 20:20:21 (103.4 minutes) and wrote 22016 records for ESH7 | 2016-12-08 20:20:27 HD Request # 33 | Intraday download COMPLETE for ESH7. Completion time: 1s. Unique request ID: 32 | 2016-12-08 20:20:27 Removed historical data download ID 32 | 2016-12-08 20:20:27 Real-time Intraday chart data file updates started for ESH7 | 2016-12-08 20:20:27 Intraday chart data file opened for ESH7 | 2016-12-08 20:20:27 HD Request # 34 | Downloading Intraday chart data for ZCH7 to the file ZCH7.scid. Service: oec | 2016-12-08 20:20:27 HD Request # 34 | Download start date-time: 2016-12-08 20:19:59.000 | 2016-12-08 20:20:27 HD Request # 34 | Using server: ds4.sierracharts.com port 10149 | 2016-12-08 20:20:27 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-08 20:20:27 Socket (1410) | Connected. | 2016-12-08 20:20:27 HD Request # 34 | Setting DTC encoding to Binary VLS | 2016-12-08 20:20:27 HD Request # 34 | Sending historical data logon request message. | 2016-12-08 20:20:27 HD Request # 34 | Requesting Intraday data. Start date-time: 2016-12-08 20:19:59. Record interval: 0. Symbol: ZCH7 | 2016-12-08 20:20:28 HD Request # 34 | Decompressing data. | 2016-12-08 20:20:28 HD Request # 34 | Receiving Intraday data for ZCH7 starting at 2016-12-08 20:19:59 | 2016-12-08 20:20:28 Socket (1410) | Shutdown and closed. | 2016-12-08 20:20:28 The network socket for historical data has been closed. | 2016-12-08 20:20:28 HD Request # 34 | Received 11 records from 2016-12-08 20:19:59 to 2016-12-08 20:19:59 (0.0 seconds) and wrote 0 records for ZCH7 | 2016-12-08 20:20:28 HD Request # 34 | Intraday download COMPLETE for ZCH7. Completion time: 1s. Unique request ID: 33 | 2016-12-08 20:20:28 Removed historical data download ID 33 | 2016-12-08 20:20:28 Real-time Intraday chart data file updates started for ZCH7 | 2016-12-08 20:20:28 Intraday chart data file opened for ZCH7 | 2016-12-08 20:20:28 HD Server | HD Request # 13 | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 11 | ClientRequestID: 13 | Username: User252419. | 2016-12-08 20:20:28 Socket (0) | Closed. No error. | 2016-12-08 20:20:28 Socket (0) | Shutdown and closed. | 2016-12-08 20:20:28 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 20:20:28 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 20:20:28 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 20:20:28 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 20:20:28 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 20:20:28 HD Server | HD Request | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-08 19:20:14 | ClientRequestID: 14 | Username: User252419. | 2016-12-08 20:20:28 HD Server | HD Request # 14 | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 146 | ClientRequestID: 14 | Username: User252419. | 2016-12-08 20:20:28 Socket (0) | Closed. No error. | 2016-12-08 20:20:28 Socket (0) | Shutdown and closed. | 2016-12-08 20:20:28 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 20:20:28 HD Server | HD Request # 25 | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 11 | ClientRequestID: 25 | Username: User252419. | 2016-12-08 20:20:28 Socket (0) | Closed. No error. | 2016-12-08 20:20:28 Socket (0) | Shutdown and closed. | 2016-12-08 20:20:28 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 20:20:28 Opened cached Intraday file: C:\SierraChart\Data\ESZ6.scid | 2016-12-08 20:20:36 Opened cached Intraday file: C:\SierraChart\Data\GCLF7.scid | 2016-12-08 20:20:36 Opened cached Intraday file: C:\SierraChart\Data\ESH7.scid | 2016-12-08 20:20:36 ZCH7 300 Trades #2 | Reloading chart. | 2016-12-08 20:27:52 HD Server | New server thread for client has been created for incoming connection. | 2016-12-08 20:56:13 HD Server | Unexpected DTC encoding request: 1 | 2016-12-08 20:56:13 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-08 20:56:13 HD Server | Login has been authorized. | Username: User252419. | 2016-12-08 20:56:13 HD Server | HD Request | Symbol: ESH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-06-05 19:56:13 | ClientRequestID: 15 | Username: User252419. | 2016-12-08 20:56:13 HD Server | HD Request # 15 | Symbol: ESH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 258310 | ClientRequestID: 15 | Username: User252419. | 2016-12-08 20:56:15 Socket (0) | Closed. No error. | 2016-12-08 20:56:15 Socket (0) | Shutdown and closed. | 2016-12-08 20:56:15 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-08 20:56:15 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2016-12-08 23:36:23 HD Server | New server thread for client has been created for incoming connection. | 2016-12-09 00:00:01 HD Server | Unexpected DTC encoding request: 1 | 2016-12-09 00:00:01 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-09 00:00:01 HD Server | Login has been authorized. | Username: User252419. | 2016-12-09 00:00:01 HD Server | HD Request | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2016-12-06 00:00:00 | ClientRequestID: 26 | Username: User252419. | 2016-12-09 00:00:01 HD Request # 35 | Downloading Historical Daily chart data for ESZ6. Starting date: 2016-12-06. Service: oec | 2016-12-09 00:00:01 HD Request # 35 | Error downloading historical Daily data for ESZ6. The futures symbol format is invalid. The year must be 2 digits. | 2016-12-09 00:00:01 HD Request # 35 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ6 | 2016-12-09 00:00:01 HD Request # 35 | Daily download COMPLETE for ESZ6. Completion time: 0s. Unique request ID: 34 | 2016-12-09 00:00:01 Removed historical data download ID 34 | 2016-12-09 00:00:01 HD Server | HD Request # 26 | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 2 | ClientRequestID: 26 | Username: User252419. | 2016-12-09 00:00:02 Socket (0) | Closed. No error. | 2016-12-09 00:00:02 Socket (0) | Shutdown and closed. | 2016-12-09 00:00:02 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-09 00:00:02 HD Server | New server thread for client has been created for incoming connection. | 2016-12-09 00:00:02 HD Server | Unexpected DTC encoding request: 1 | 2016-12-09 00:00:02 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-09 00:00:02 HD Server | Login has been authorized. | Username: User252419. | 2016-12-09 00:00:02 HD Server | HD Request | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2016-12-06 00:00:00 | ClientRequestID: 27 | Username: User252419. | 2016-12-09 00:00:02 HD Request # 36 | Downloading Historical Daily chart data for GCLF7. Starting date: 2016-12-06. Service: oec | 2016-12-09 00:00:02 HD Request # 36 | Requesting historical Daily data for CLF17 starting at 2016-12-05 | 2016-12-09 00:00:02 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-12-09 00:00:02 HTTP connection to ds01.ddfplus.com:80 (1524) | Connected. | 2016-12-09 00:00:02 HD Request # 36 | Receiving historical Daily data for GCLF7 starting at 2016-12-06 | 2016-12-09 00:00:02 HD Request # 36 | Writing historical Daily data to the file GCLF7.dly | 2016-12-09 00:00:02 HD Request # 36 | Received 4 records from 2016-12-06 00:00:00 to 2016-12-08 00:00:00 (3.0 days) and wrote 3 records for GCLF7 | 2016-12-09 00:00:02 HD Request # 36 | Daily download COMPLETE for GCLF7. Completion time: 1s. Unique request ID: 35 | 2016-12-09 00:00:02 Removed historical data download ID 35 | 2016-12-09 00:00:02 HD Server | HD Request # 27 | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientRequestID: 27 | Username: User252419. | 2016-12-09 00:00:03 Socket (0) | Closed. No error. | 2016-12-09 00:00:03 Socket (0) | Shutdown and closed. | 2016-12-09 00:00:03 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-09 00:00:03 HTTP connection to ds01.ddfplus.com:80 (1524) | Closed. No error. | 2016-12-09 00:01:07 HTTP connection to ds01.ddfplus.com:80 (1524) | Shutdown and closed. | 2016-12-09 00:01:07 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESH7.2016-12-09.depth | 2016-12-09 01:00:00 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\GCLF7.2016-12-09.depth | 2016-12-09 01:00:00 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ZCH7.2016-12-09.depth | 2016-12-09 01:03:28 HD Server | New server thread for client has been created for incoming connection. | 2016-12-09 02:00:01 HD Server | Unexpected DTC encoding request: 1 | 2016-12-09 02:00:01 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-09 02:00:01 HD Server | Login has been authorized. | Username: User252419. | 2016-12-09 02:00:01 HD Server | HD Request | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2016-12-06 00:00:00 | ClientRequestID: 28 | Username: User252419. | 2016-12-09 02:00:01 HD Request # 37 | Downloading Historical Daily chart data for ZCH7. Starting date: 2016-12-06. Service: oec | 2016-12-09 02:00:01 Historical data download counter reset. | 2016-12-09 02:00:01 HD Request # 37 | Requesting historical Daily data for ZCH17 starting at 2016-12-05 | 2016-12-09 02:00:01 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-12-09 02:00:01 HTTP connection to ds01.ddfplus.com:80 (1586) | Connected. | 2016-12-09 02:00:01 HD Request # 37 | Receiving historical Daily data for ZCH7 starting at 2016-12-06 | 2016-12-09 02:00:02 HD Request # 37 | Writing historical Daily data to the file ZCH7.dly | 2016-12-09 02:00:02 HD Request # 37 | Received 4 records from 2016-12-06 00:00:00 to 2016-12-08 00:00:00 (3.0 days) and wrote 3 records for ZCH7 | 2016-12-09 02:00:02 HD Request # 37 | Daily download COMPLETE for ZCH7. Completion time: 0s. Unique request ID: 36 | 2016-12-09 02:00:02 Removed historical data download ID 36 | 2016-12-09 02:00:02 HD Server | HD Request # 28 | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientRequestID: 28 | Username: User252419. | 2016-12-09 02:00:02 Socket (0) | Closed. No error. | 2016-12-09 02:00:02 Socket (0) | Shutdown and closed. | 2016-12-09 02:00:02 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-09 02:00:02 Opened cached Intraday file: C:\SierraChart\Data\ZCH7.scid | 2016-12-09 02:00:08 HTTP connection to ds01.ddfplus.com:80 (1586) | Closed. No error. | 2016-12-09 02:01:06 HTTP connection to ds01.ddfplus.com:80 (1586) | Shutdown and closed. | 2016-12-09 02:01:06 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2016-12-09 03:36:23 GAIN Capital FIX Trading socket (1406) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-12-09 06:44:53 GAIN Capital FIX Trading socket (1406) | SSL shutdown indicates not able to send 'close notify'. | 2016-12-09 06:44:53 GAIN Capital FIX Trading socket (1406) | SSL has been shut down. | 2016-12-09 06:44:53 GAIN Capital FIX Trading socket (1406) | SSL object has been freed. SSL state is now disconnected. | 2016-12-09 06:44:53 GAIN Capital FIX Trading socket (1406) | Shutdown and closed. | 2016-12-09 06:44:53 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-12-09 06:44:53 Connection to the external service has been lost. | 2016-12-09 06:44:53 GAIN Capital/OEC | Disconnected from the trading server. | 2016-12-09 06:44:53 GAIN Capital FAST Data: Sending a Logout message. | 2016-12-09 06:44:53 GAIN Capital/OEC | Disconnected. | 2016-12-09 06:44:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-12-09 06:44:53 GAIN Capital FAST Data socket (1407) | Closed. No error. | 2016-12-09 06:44:53 GAIN Capital FAST Data socket (1407) | Shutdown and closed. | 2016-12-09 06:44:53 GAIN Capital FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2016-12-09 06:44:53 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-12-09 06:44:53 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-12-09 06:44:58 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-12-09 06:44:58 GAIN Capital FIX Trading socket (1733) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2016-12-09 06:45:16 GAIN Capital FIX Trading socket (1733) | Shutdown and closed. | 2016-12-09 06:45:16 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-12-09 06:45:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-12-09 06:45:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-12-09 06:45:16 GAIN Capital/OEC | Disconnected from the trading server. | 2016-12-09 06:45:16 GAIN Capital/OEC | Disconnected. | 2016-12-09 06:45:20 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-12-09 06:45:20 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-12-09 06:45:23 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-12-09 06:45:23 GAIN Capital FIX Trading socket (1734) | Connected. | 2016-12-09 06:45:23 GAIN Capital FIX Trading socket (1734) | Starting TLS 1.2 connection. | 2016-12-09 06:45:23 GAIN Capital FIX Trading socket (1734) | SSL connection established. | 2016-12-09 06:45:23 GAIN Capital FIX Trading: Sending the Logon message. | 2016-12-09 06:45:24 GAIN Capital FIX Trading | Connected to trading server. | 2016-12-09 06:45:24 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2016-12-09 06:45:24 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-12-09 06:45:24 GAIN Capital FAST Data socket (1735) | Connected. | 2016-12-09 06:45:24 GAIN Capital FAST Data: Sending the Hello message. | 2016-12-09 06:45:24 GAIN Capital FAST Data: Sending the Logon message. | 2016-12-09 06:45:24 GAIN Capital/OEC | Connected to data and trading server. | 2016-12-09 06:45:24 GAIN Capital/OEC | Starting real-time market data updates for: ESZ6. ID: 1 | 2016-12-09 06:45:24 GAIN Capital/OEC | Requesting security definition data for: ESZ6. ID: 1 | 2016-12-09 06:45:24 GAIN Capital/OEC | Using primary service for historical data for ESZ6 | 2016-12-09 06:45:24 Intraday data recording state for symbol ESZ6 is set to download 'Pending'. | 2016-12-09 06:45:24 Market data subscription status is not known while delaying historical data download for symbol: ESZ6 | 2016-12-09 06:45:24 Delaying start of download for ESZ6 | 2016-12-09 06:45:24 HD Server | New server thread for client has been created for incoming connection. | 2016-12-09 06:45:24 HD Server | New server thread for client has been created for incoming connection. | 2016-12-09 06:45:24 HD Server | Unexpected DTC encoding request: 1 | 2016-12-09 06:45:24 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-09 06:45:24 HD Server | Login has been authorized. | Username: User252419. | 2016-12-09 06:45:24 HD Server | HD Request | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-09 05:44:45 | ClientRequestID: 29 | Username: User252419. | 2016-12-09 06:45:24 HD Server | Unexpected DTC encoding request: 1 | 2016-12-09 06:45:24 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-09 06:45:24 HD Server | Login has been authorized. | Username: User252419. | 2016-12-09 06:45:24 HD Server | HD Request | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-09 05:44:45 | ClientRequestID: 16 | Username: User252419. | 2016-12-09 06:45:24 GAIN Capital/OEC | Starting real-time market data updates for: ZCH7. ID: 2 | 2016-12-09 06:45:24 GAIN Capital/OEC | Requesting security definition data for: ZCH7. ID: 2 | 2016-12-09 06:45:24 GAIN Capital/OEC | Starting real-time market data updates for: GCLF7. ID: 3 | 2016-12-09 06:45:24 GAIN Capital/OEC | Requesting security definition data for: GCLF7. ID: 3 | 2016-12-09 06:45:24 GAIN Capital/OEC | Starting real-time market data updates for: ESH7. ID: 4 | 2016-12-09 06:45:24 GAIN Capital/OEC | Requesting security definition data for: ESH7. ID: 4 | 2016-12-09 06:45:24 Requesting market depth updates for: ESZ6 if supported. | 2016-12-09 06:45:24 Requesting market depth updates for: GCLF7 if supported. | 2016-12-09 06:45:24 Requesting market depth updates for: ZCH7 if supported. | 2016-12-09 06:45:24 Intraday data recording state for symbol ESH7 is set to download 'Pending'. | 2016-12-09 06:45:24 Market data subscription status is not known while delaying historical data download for symbol: ESH7 | 2016-12-09 06:45:24 Delaying start of download for ESH7 | 2016-12-09 06:45:24 Intraday data recording state for symbol ZCH7 is set to download 'Pending'. | 2016-12-09 06:45:24 Market data subscription status is not known while delaying historical data download for symbol: ESH7 | 2016-12-09 06:45:24 Intraday data recording state for symbol GCLF7 is set to download 'Pending'. | 2016-12-09 06:45:24 Market data subscription status is not known while delaying historical data download for symbol: ESH7 | 2016-12-09 06:45:24 Requesting market depth updates for: ESH7 if supported. | 2016-12-09 06:45:24 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\GCLF7.2016-12-09.depth | 2016-12-09 06:45:25 GAIN Capital/OEC | Starting real-time market data updates for: NQZ6. ID: 5 | 2016-12-09 06:45:25 GAIN Capital/OEC | Requesting security definition data for: NQZ6. ID: 5 | 2016-12-09 06:45:25 GAIN Capital/OEC | Starting real-time market data updates for: YMZ6. ID: 6 | 2016-12-09 06:45:25 GAIN Capital/OEC | Requesting security definition data for: YMZ6. ID: 6 | 2016-12-09 06:45:25 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESH7.2016-12-09.depth | 2016-12-09 06:45:25 Delaying start of download for ESZ6 | 2016-12-09 06:45:25 Symbol Error - YMZ6 is unknown, unavailable, or improperly formatted. FIX reject reason: Your subscription limit of 5 has been reached | 2016-12-09 06:45:25 Delaying start of download for ESH7 | 2016-12-09 06:45:25 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ZCH7.2016-12-09.depth | 2016-12-09 06:45:27 HD Request # 38 | Downloading Intraday chart data for ESZ6 to the file ESZ6.scid. Service: oec | 2016-12-09 06:45:31 HD Request # 38 | Download start date-time: 2016-12-09 06:44:45.000 | 2016-12-09 06:45:31 HD Request # 39 | Downloading Intraday chart data for ESH7 to the file ESH7.scid. Service: oec | 2016-12-09 06:45:31 HD Request # 39 | Download start date-time: 2016-12-09 06:44:50.000 | 2016-12-09 06:45:31 HD Request # 39 | Using server: ds3.sierracharts.com port 10149 | 2016-12-09 06:45:31 HD Request # 38 | Receiving Intraday data for ESZ6 starting at 2016-12-09 06:44:45 | 2016-12-09 06:45:31 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-09 06:45:31 HD Request # 38 | Timestamp of first Intraday data file record written: 2016-12-09 06:45:07 | 2016-12-09 06:45:31 GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2016-12-09 06:45:31 Socket (1736) | Connected. | 2016-12-09 06:45:31 HD Request # 38 | Received 4 records from 2016-12-09 06:44:45 to 2016-12-09 06:45:23 (38.0 seconds) and wrote 3 records for ESZ6 | 2016-12-09 06:45:31 HD Request # 38 | Intraday download COMPLETE for ESZ6. Completion time: 0s. Unique request ID: 37 | 2016-12-09 06:45:31 Removed historical data download ID 37 | 2016-12-09 06:45:31 Real-time Intraday chart data file updates started for ESZ6 | 2016-12-09 06:45:31 Intraday chart data file opened for ESZ6 | 2016-12-09 06:45:31 HD Request # 39 | Setting DTC encoding to Binary VLS | 2016-12-09 06:45:31 HD Request # 39 | Sending historical data logon request message. | 2016-12-09 06:45:31 HD Server | HD Request # 29 | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientRequestID: 29 | Username: User252419. | 2016-12-09 06:45:32 HD Server | HD Request # 16 | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 4 | ClientRequestID: 16 | Username: User252419. | 2016-12-09 06:45:32 Socket (0) | Closed. No error. | 2016-12-09 06:45:32 Socket (0) | Shutdown and closed. | 2016-12-09 06:45:32 Socket (0) | Closed. No error. | 2016-12-09 06:45:32 Socket (0) | Shutdown and closed. | 2016-12-09 06:45:32 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-09 06:45:32 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-09 06:45:32 HD Server | New server thread for client has been created for incoming connection. | 2016-12-09 06:45:32 HD Server | New server thread for client has been created for incoming connection. | 2016-12-09 06:45:32 HD Server | Unexpected DTC encoding request: 1 | 2016-12-09 06:45:32 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-09 06:45:32 HD Server | Login has been authorized. | Username: User252419. | 2016-12-09 06:45:32 HD Server | HD Request | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-09 05:44:50 | ClientRequestID: 30 | Username: User252419. | 2016-12-09 06:45:32 HD Server | Unexpected DTC encoding request: 1 | 2016-12-09 06:45:32 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-09 06:45:32 HD Server | Login has been authorized. | Username: User252419. | 2016-12-09 06:45:32 HD Server | HD Request | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-09 05:44:52 | ClientRequestID: 17 | Username: User252419. | 2016-12-09 06:45:32 HD Request # 39 | Requesting Intraday data. Start date-time: 2016-12-09 06:44:50. Record interval: 0. Symbol: ESH7 | 2016-12-09 06:45:32 HD Request # 39 | Decompressing data. | 2016-12-09 06:45:32 HD Request # 39 | Receiving Intraday data for ESH7 starting at 2016-12-09 06:44:50 | 2016-12-09 06:45:32 HD Request # 39 | Timestamp of first Intraday data file record written: 2016-12-09 06:45:00 | 2016-12-09 06:45:32 Socket (1736) | Shutdown and closed. | 2016-12-09 06:45:32 The network socket for historical data has been closed. | 2016-12-09 06:45:32 HD Request # 39 | Received 10 records from 2016-12-09 06:44:50 to 2016-12-09 06:45:12 (22.0 seconds) and wrote 7 records for ESH7 | 2016-12-09 06:45:32 HD Request # 39 | Intraday download COMPLETE for ESH7. Completion time: 1s. Unique request ID: 38 | 2016-12-09 06:45:32 Removed historical data download ID 38 | 2016-12-09 06:45:32 Real-time Intraday chart data file updates started for ESH7 | 2016-12-09 06:45:32 Intraday chart data file opened for ESH7 | 2016-12-09 06:45:32 HD Request # 40 | Downloading Intraday chart data for ZCH7 to the file ZCH7.scid. Service: oec | 2016-12-09 06:45:32 HD Request # 40 | Download start date-time: 2016-12-09 06:44:52.000 | 2016-12-09 06:45:32 HD Request # 40 | Using server: ds4.sierracharts.com port 10149 | 2016-12-09 06:45:32 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-12-09 06:45:32 Socket (1737) | Connected. | 2016-12-09 06:45:33 HD Request # 40 | Setting DTC encoding to Binary VLS | 2016-12-09 06:45:33 HD Request # 40 | Sending historical data logon request message. | 2016-12-09 06:45:33 HD Request # 40 | Requesting Intraday data. Start date-time: 2016-12-09 06:44:52. Record interval: 0. Symbol: ZCH7 | 2016-12-09 06:45:33 HD Request # 40 | Decompressing data. | 2016-12-09 06:45:33 HD Request # 40 | Receiving Intraday data for ZCH7 starting at 2016-12-09 06:44:52 | 2016-12-09 06:45:33 HD Request # 40 | Timestamp of first Intraday data file record written: 2016-12-09 06:45:07 | 2016-12-09 06:45:33 Socket (1737) | Shutdown and closed. | 2016-12-09 06:45:33 The network socket for historical data has been closed. | 2016-12-09 06:45:33 HD Request # 40 | Received 5 records from 2016-12-09 06:44:52 to 2016-12-09 06:45:26 (34.0 seconds) and wrote 4 records for ZCH7 | 2016-12-09 06:45:33 HD Request # 40 | Intraday download COMPLETE for ZCH7. Completion time: 0s. Unique request ID: 39 | 2016-12-09 06:45:33 Removed historical data download ID 39 | 2016-12-09 06:45:33 Real-time Intraday chart data file updates started for ZCH7 | 2016-12-09 06:45:33 Intraday chart data file opened for ZCH7 | 2016-12-09 06:45:33 HD Request # 41 | Downloading Intraday chart data for GCLF7 to the file GCLF7.scid. Service: oec | 2016-12-09 06:45:33 HD Request # 41 | Download start date-time: 2016-12-09 06:44:50.000 | 2016-12-09 06:45:33 HD Request # 41 | Using server: ds3.sierracharts.com port 10149 | 2016-12-09 06:45:33 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.42. | 2016-12-09 06:45:33 Socket (1738) | Connected. | 2016-12-09 06:45:33 HD Request # 41 | Setting DTC encoding to Binary VLS | 2016-12-09 06:45:34 HD Request # 41 | Sending historical data logon request message. | 2016-12-09 06:45:34 HD Request # 41 | Requesting Intraday data. Start date-time: 2016-12-09 06:44:50. Record interval: 0. Symbol: GCLF7 | 2016-12-09 06:45:34 HD Request # 41 | Decompressing data. | 2016-12-09 06:45:34 HD Request # 41 | Receiving Intraday data for GCLF7 starting at 2016-12-09 06:44:50 | 2016-12-09 06:45:34 HD Request # 41 | Timestamp of first Intraday data file record written: 2016-12-09 06:44:54 | 2016-12-09 06:45:34 Socket (1738) | Shutdown and closed. | 2016-12-09 06:45:34 The network socket for historical data has been closed. | 2016-12-09 06:45:34 HD Request # 41 | Received 105 records from 2016-12-09 06:44:50 to 2016-12-09 06:45:30 (40.0 seconds) and wrote 104 records for GCLF7 | 2016-12-09 06:45:34 HD Request # 41 | Intraday download COMPLETE for GCLF7. Completion time: 0s. Unique request ID: 40 | 2016-12-09 06:45:34 Removed historical data download ID 40 | 2016-12-09 06:45:34 Real-time Intraday chart data file updates started for GCLF7 | 2016-12-09 06:45:34 Intraday chart data file opened for GCLF7 | 2016-12-09 06:45:34 HD Server | HD Request # 30 | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 105 | ClientRequestID: 30 | Username: User252419. | 2016-12-09 06:45:34 Socket (0) | Closed. No error. | 2016-12-09 06:45:34 Socket (0) | Shutdown and closed. | 2016-12-09 06:45:34 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-09 06:45:34 HD Server | HD Request # 17 | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 5 | ClientRequestID: 17 | Username: User252419. | 2016-12-09 06:45:34 Socket (0) | Closed. No error. | 2016-12-09 06:45:34 Socket (0) | Shutdown and closed. | 2016-12-09 06:45:34 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-09 06:45:34 HD Server | New server thread for client has been created for incoming connection. | 2016-12-09 06:45:34 HD Server | New server thread for client has been created for incoming connection. | 2016-12-09 06:45:34 HD Server | Unexpected DTC encoding request: 1 | 2016-12-09 06:45:34 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-09 06:45:34 HD Server | Login has been authorized. | Username: User252419. | 2016-12-09 06:45:34 HD Server | HD Request | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-09 05:44:52 | ClientRequestID: 31 | Username: User252419. | 2016-12-09 06:45:34 HD Server | HD Request # 31 | Symbol: ZCH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 5 | ClientRequestID: 31 | Username: User252419. | 2016-12-09 06:45:34 Socket (0) | Closed. No error. | 2016-12-09 06:45:34 Socket (0) | Shutdown and closed. | 2016-12-09 06:45:34 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-09 06:45:34 HD Server | Unexpected DTC encoding request: 1 | 2016-12-09 06:45:34 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-09 06:45:34 HD Server | Login has been authorized. | Username: User252419. | 2016-12-09 06:45:34 HD Server | HD Request | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-09 05:44:50 | ClientRequestID: 18 | Username: User252419. | 2016-12-09 06:45:34 HD Server | HD Request # 18 | Symbol: GCLF7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 105 | ClientRequestID: 18 | Username: User252419. | 2016-12-09 06:45:34 Socket (0) | Closed. No error. | 2016-12-09 06:45:34 Socket (0) | Shutdown and closed. | 2016-12-09 06:45:34 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-09 06:45:34 HD Server | New server thread for client has been created for incoming connection. | 2016-12-09 06:45:35 HD Server | Unexpected DTC encoding request: 1 | 2016-12-09 06:45:35 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-09 06:45:35 HD Server | Login has been authorized. | Username: User252419. | 2016-12-09 06:45:35 HD Server | HD Request | Symbol: ESH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-09 05:44:50 | ClientRequestID: 19 | Username: User252419. | 2016-12-09 06:45:35 HD Server | HD Request # 19 | Symbol: ESH7 | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 10 | ClientRequestID: 19 | Username: User252419. | 2016-12-09 06:45:35 Socket (0) | Closed. No error. | 2016-12-09 06:45:35 Socket (0) | Shutdown and closed. | 2016-12-09 06:45:35 HD Server | Server thread ending. Socket closed. | Username: User252419. | 2016-12-09 06:45:35 Opened cached Intraday file: C:\SierraChart\Data\ESZ6.scid | 2016-12-09 06:45:42 Opened cached Intraday file: C:\SierraChart\Data\ZCH7.scid | 2016-12-09 06:45:42 Opened cached Intraday file: C:\SierraChart\Data\GCLF7.scid | 2016-12-09 06:45:42 Opened cached Intraday file: C:\SierraChart\Data\ESH7.scid | 2016-12-09 06:45:42 GAIN Capital FIX Trading socket (1734) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-12-09 07:32:37 GAIN Capital FIX Trading socket (1734) | SSL shutdown indicates not able to send 'close notify'. | 2016-12-09 07:32:37 GAIN Capital FIX Trading socket (1734) | SSL has been shut down. | 2016-12-09 07:32:37 GAIN Capital FIX Trading socket (1734) | SSL object has been freed. SSL state is now disconnected. | 2016-12-09 07:32:37 GAIN Capital FIX Trading socket (1734) | Shutdown and closed. | 2016-12-09 07:32:37 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-12-09 07:32:37 Connection to the external service has been lost. | 2016-12-09 07:32:37 GAIN Capital/OEC | Disconnected from the trading server. | 2016-12-09 07:32:37 GAIN Capital FAST Data: Sending a Logout message. | 2016-12-09 07:32:37 GAIN Capital/OEC | Disconnected. | 2016-12-09 07:32:37 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-12-09 07:32:37 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-12-09 07:32:40 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-12-09 07:32:40 GAIN Capital FAST Data socket (1735) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-12-09 07:32:40 GAIN Capital FAST Data socket (1735) | Shutdown and closed. | 2016-12-09 07:32:40 GAIN Capital FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2016-12-09 07:32:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-12-09 07:32:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-12-09 07:32:40 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-12-09 07:32:40 GAIN Capital FIX Trading: DisconnectFIX called. | 2016-12-09 07:32:40 GAIN Capital FIX Trading socket (1764) | Shutdown and closed. | 2016-12-09 07:32:40 GAIN Capital/OEC | Disconnected from the trading server. | 2016-12-09 07:32:40 GAIN Capital/OEC | Disconnected. | 2016-12-09 07:32:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-12-09 07:32:40 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-12-09 07:32:43 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-12-09 07:32:43 GAIN Capital FIX Trading socket (1765) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2016-12-09 07:33:04 GAIN Capital FIX Trading socket (1765) | Shutdown and closed. | 2016-12-09 07:33:04 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-12-09 07:33:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-12-09 07:33:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-12-09 07:33:04 GAIN Capital/OEC | Disconnected from the trading server. | 2016-12-09 07:33:04 GAIN Capital/OEC | Disconnected. | 2016-12-09 07:33:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-12-09 07:33:04 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-12-09 07:33:08 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-12-09 07:33:08 GAIN Capital FIX Trading socket (1766) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2016-12-09 07:33:27 GAIN Capital FIX Trading socket (1766) | Shutdown and closed. | 2016-12-09 07:33:27 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-12-09 07:33:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-12-09 07:33:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-12-09 07:33:27 GAIN Capital/OEC | Disconnected from the trading server. | 2016-12-09 07:33:27 GAIN Capital/OEC | Disconnected. | 2016-12-09 07:33:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-12-09 07:33:30 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-12-09 07:33:33 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-12-09 07:33:33 GAIN Capital FIX Trading socket (1767) | Connected. | 2016-12-09 07:33:33 GAIN Capital FIX Trading socket (1767) | Starting TLS 1.2 connection. | 2016-12-09 07:33:33 GAIN Capital FIX Trading socket (1767) | SSL connection established. | 2016-12-09 07:33:33 GAIN Capital FIX Trading: Sending the Logon message. | 2016-12-09 07:33:34 GAIN Capital FIX Trading | Connected to trading server. | 2016-12-09 07:33:34 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2016-12-09 07:33:34 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-12-09 07:33:34 GAIN Capital FAST Data socket (1768) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2016-12-09 07:33:55 GAIN Capital FAST Data socket (1768) | Shutdown and closed. | 2016-12-09 07:33:55 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2016-12-09 07:33:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-12-09 07:33:55 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-12-09 07:33:55 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-12-09 07:33:55 GAIN Capital FIX Trading: DisconnectFIX called. | 2016-12-09 07:33:55 GAIN Capital FIX Trading: Sending a Logout message. | 2016-12-09 07:33:55 GAIN Capital/OEC | Disconnected. | 2016-12-09 07:33:55 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-12-09 07:33:55 GAIN Capital FIX Trading: Received a Logout message. | 2016-12-09 07:33:55 GAIN Capital FIX Trading socket (1767) | SSL shutdown indicates not able to send 'close notify'. | 2016-12-09 07:33:55 GAIN Capital FIX Trading socket (1767) | SSL has been shut down. | 2016-12-09 07:33:55 GAIN Capital FIX Trading socket (1767) | SSL object has been freed. SSL state is now disconnected. | 2016-12-09 07:33:55 GAIN Capital FIX Trading socket (1767) | Shutdown and closed. | 2016-12-09 07:33:55 GAIN Capital/OEC | Disconnected from the trading server. | 2016-12-09 07:33:55 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-12-09 07:33:58 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-12-09 07:33:58 GAIN Capital FIX Trading socket (1769) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2016-12-09 07:34:19 GAIN Capital FIX Trading socket (1769) | Shutdown and closed. | 2016-12-09 07:34:19 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-12-09 07:34:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-12-09 07:34:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-12-09 07:34:19 GAIN Capital/OEC | Disconnected from the trading server. | 2016-12-09 07:34:19 GAIN Capital/OEC | Disconnected. | 2016-12-09 07:34:19 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-12-09 07:34:19 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-12-09 07:34:22 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-12-09 07:34:22 GAIN Capital FIX Trading socket (1770) | Connected. | 2016-12-09 07:34:24 GAIN Capital FIX Trading socket (1770) | Starting TLS 1.2 connection. | 2016-12-09 07:34:24 GAIN Capital FIX Trading socket (1770) | SSL connection established. | 2016-12-09 07:34:24 GAIN Capital FIX Trading: Sending the Logon message. | 2016-12-09 07:34:24 GAIN Capital FIX Trading | Connected to trading server. | 2016-12-09 07:34:25 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2016-12-09 07:34:25 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-12-09 07:34:25 GAIN Capital FAST Data socket (1771) | Connected. | 2016-12-09 07:34:25 GAIN Capital FAST Data: Sending the Hello message. | 2016-12-09 07:34:25 GAIN Capital FAST Data: Sending the Logon message. | 2016-12-09 07:34:25 GAIN Capital/OEC | Connected to data and trading server. | 2016-12-09 07:34:25 GAIN Capital/OEC | Starting real-time market data updates for: ESZ6. ID: 1 | 2016-12-09 07:34:25 GAIN Capital/OEC | Requesting security definition data for: ESZ6. ID: 1 | 2016-12-09 07:34:25 GAIN Capital/OEC | Using primary service for historical data for ESZ6 | 2016-12-09 07:34:25 Intraday data recording state for symbol ESZ6 is set to download 'Pending'. | 2016-12-09 07:34:25 Market data subscription status is not known while delaying historical data download for symbol: ESZ6 | 2016-12-09 07:34:25 Delaying start of download for ESZ6 | 2016-12-09 07:34:25 HD Server | New server thread for client has been created for incoming connection. | 2016-12-09 07:34:25 HD Server | New server thread for client has been created for incoming connection. | 2016-12-09 07:34:25 HD Server | Unexpected DTC encoding request: 1 | 2016-12-09 07:34:25 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-09 07:34:25 HD Server | Login has been authorized. | Username: User252419. | 2016-12-09 07:34:25 HD Server | HD Request | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-09 06:31:49 | ClientRequestID: 32 | Username: User252419. | 2016-12-09 07:34:25 HD Server | Unexpected DTC encoding request: 1 | 2016-12-09 07:34:25 HD Server | Received login. Requesting authorization. | Username: User252419. | 2016-12-09 07:34:25 HD Server | Login has been authorized. | Username: User252419. | 2016-12-09 07:34:25 HD Server | HD Request | Symbol: ESZ6 | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2016-12-09 06:31:49 | ClientRequestID: 20 | Username: User252419. | 2016-12-09 07:34:25 GAIN Capital/OEC | Starting real-time market data updates for: ESH7. ID: 2 | 2016-12-09 07:34:25 GAIN Capital/OEC | Requesting security definition data for: ESH7. ID: 2 | 2016-12-09 07:34:25 Intraday data recording state for symbol ESH7 is set to download 'Pending'. | 2016-12-09 07:34:25 Market data subscription status is not known while delaying historical data download for symbol: ESH7 | 2016-12-09 07:34:25 Delaying start of download for ESH7 | 2016-12-09 07:34:25 GAIN Capital/OEC | Starting real-time market data updates for: ZCH7. ID: 3 | 2016-12-09 07:34:25 GAIN Capital/OEC | Requesting security definition data for: ZCH7. ID: 3 | 2016-12-09 07:34:25 Intraday data recording state for symbol ZCH7 is set to download 'Pending'. | 2016-12-09 07:34:25 Market data subscription status is not known while delaying historical data download for symbol: ESH7 | 2016-12-09 07:34:25 GAIN Capital/OEC | Starting real-time market data updates for: GCLF7. ID: 4 | 2016-12-09 07:34:25 GAIN Capital/OEC | Requesting security definition data for: GCLF7. ID: 4 | 2016-12-09 07:34:25 Intraday data recording state for symbol GCLF7 is set to download 'Pending'. | 2016-12-09 07:34:25 Market data subscription status is not known while delaying historical data download for symbol: ESH7 | 2016-12-09 07:34:25 Requesting market depth updates for: ESZ6 if supported. | 2016-12-09 07:34:25 Requesting market depth updates for: GCLF7 if supported. | 2016-12-09 07:34:25 Requesting market depth updates for: ZCH7 if supported. | 2016-12-09 07:34:25 Requesting market depth updates for: ESH7 if supported. | 2016-12-09 07:34:25 GAIN Capital/OEC | Starting real-time market data updates for: NQZ6. ID: 5 | 2016-12-09 07:34:26 GAIN Capital/OEC | Requesting security definition data for: NQZ6. ID: 5 | 2016-12-09 07:34:26 GAIN Capital/OEC | Starting real-time market data updates for: YMZ6. ID: 6 | 2016-12-09 07:34:26 GAIN Capital/OEC | Requesting security definition data for: YMZ6. ID: 6 | 2016-12-09 07:34:26 Symbol Error - YMZ6 is unknown, unavailable, or improperly formatted. FIX reject reason: Your subscription limit of 5 has been reached | 2016-12-09 07:34:26 Date Time Of Last Edit: 2016-12-12 15:43:03
[2016-12-12 15:44:03] |
This is the general reason for the problem: Symbol Error - YMZ6 is unknown, unavailable, or improperly formatted. FIX reject reason: Your subscription limit of 5 has been reached | 2016-12-09 07:34:26
Refer to: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#SymbolLimit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
