Date/Time: Sat, 11 Jan 2025 12:06:00 +0000
Chart with no text on the chart window border
View Count: 841
[2016-12-08 04:15:59]
buylosellhi - Posts: 60
Hi, is it possible to have a chart with no text (or at least period type omitted). I'm not talking about the Chart Header Text but above on the chart window border (typically white text with blue background). Basically I want a chart window with period type hidden. Its easy to take it off the Chart Header but I cant find a way to take it off the window top border.
thx
[2016-12-08 04:24:08]
No. It is possible to add additional text but not remove the default text there.
[2016-12-08 11:51:15]
In that case is it possible to change the font color (making it blue against blue background) ?
Thx
[2016-12-08 17:56:27]
Yes but you have to do that through the operating system color settings and obviously you will affect all windows on your system.
