Date/Time: Sat, 11 Jan 2025 13:08:36 +0000
Market depth historical Graph not showing anything
View Count: 626
[2016-12-07 16:48:49] |
User252419 - Posts: 235 |
The configuration I have for Crude Oil is: Graph Only Quantities Greater or Equal to 20. I've tried many other different numbers and configurations. But is not plotting anyithing in CL. It only plots information in ES. Thank you |
[2016-12-07 16:56:30] |
Go to the chart and select File >> Open Market Depth Window. Do you see more than one level of market depth there?
[2016-12-07 16:58:37] |
Yes, I've finally solved it duplicating the charts. I don't know why is not working in the previous charts. Thank you |
