Date/Time: Sat, 11 Jan 2025 12:39:02 +0000
Using multiple sc.GraphRegion() in a single study
View Count: 696
[2016-12-06 22:43:34] |
bala - Posts: 74 |
I am trying to using ACSIL in a single study to chart a linear regression indicator (in region 0) and a Linear regression slope in (region 1). If I understand the documentation correctly, I cannot use two chart regions in the same study, am I correct? If I am correct is there a workaround where I can use multiple chart regions within a study. |
[2016-12-06 22:46:33] |
This is not supported. You need to use 2 chart studies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
