Date/Time: Sat, 11 Jan 2025 13:04:06 +0000
Numbers Bars Compare Threshold
View Count: 1584
[2016-12-06 17:00:29] |
User104854 - Posts: 456 |
I can't seem to figure this out but I'm using the numbers bar chart. I'm comparing diagonally and I only want the bars to color at 3 times difference and above. If the difference is less, then I do not want them to be colored. I tried entering 300, 300, 300 for the compare thresholds and that didn't work. I also went to an extreme and entered 800,900,1000 and there all still lit up like a Christmas Tree. Can you help please?
[2016-12-06 18:20:01] |
Refer to the documentation here for how the coloring is done: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#DominantSideColoring Make sure you set the Column # Range 0 Up/Down Colors to a neutral color. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
