Date/Time: Sat, 11 Jan 2025 12:39:19 +0000
BUY STOP NOT EXECUTING 10 YEAR TREASURY -- F.US.TYAH17
View Count: 624
[2016-12-06 16:13:24] |
User702072 - Posts: 4 |
Placed buy stop order to enter a trade and received a message that MIT orders are not accepted. I can see that technically a buy stop is MIT but AMP tells me it should be accepted. Is it because it's the BOARD of TRADE? BTW I"M permissioned on the entire bundle from the CME which includes the BoT Thanks in advance, Tommy |
[2016-12-06 17:51:48] |
If you are getting an error indicating a Market if Touched order is not supported, then those are not supported. And you cannot use them. Check to be sure you are not using this order type either through the Chart DOM or with the Target Attached Orders. Refer to step 6 here: http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ChartDOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-06 17:52:42
