Date/Time: Sat, 11 Jan 2025 13:00:01 +0000
System logged off
View Count: 744
[2016-12-06 14:25:19]
User989487 - Posts: 5
Good morning,
I logged in all night however at 617am PST system logged me of for incorrect username and password. Please assist.
Thank you,
Rebecca Corpuz
Reading Internal Order ID file. | 2016-12-06 06:17:26
Reading Trade Orders file. | 2016-12-06 06:17:26
Reading Trade Positions file. | 2016-12-06 06:17:26
Software version: 1490 | 2016-12-06 06:17:26
Uses New Spreadsheets | 2016-12-06 06:17:26
Usage end date: 2016-12-31 | 2016-12-06 06:17:26
Enabled for: Advanced Features. | 2016-12-06 06:17:26
Enabled for: Advanced Features 2. | 2016-12-06 06:17:26
Enabled for: Sierra Chart Historical Data Service. | 2016-12-06 06:17:26
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-12-06 06:17:26
Current selected Data/Trading service: CTS T4 FIX | 2016-12-06 06:17:26
Chart Update Interval: 500 | 2016-12-06 06:17:26
Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-12-06 06:17:26
2016-12-06 06:17:30 Local computer time | 2016-12-06 06:17:26
2016-12-06 14:17:30 Local computer time in UTC | 2016-12-06 06:17:26
2016-12-06 06:17:30 Local computer time in SC Time Zone | 2016-12-06 06:17:26
2016-12-06 14:17:29 Server time in UTC | 2016-12-06 06:17:26
Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-12-06 06:17:26
Program path: C:\SierraChart\ | 2016-12-06 06:17:26
Data Files path: C:\SierraChart\Data\ | 2016-12-06 06:17:26
OS Version Number: 6.2 | 2016-12-06 06:17:26
Locale Setting: C | 2016-12-06 06:17:26
Checking for new symbol settings for cts | 2016-12-06 06:17:26
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-12-06 06:17:26
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-12-06 06:17:26
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-12-06 06:17:26
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-12-06 06:17:31
Symbol settings are up-to-date for cts | 2016-12-06 06:17:31
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-12-06 06:17:32
HTTP connection to www.sierrachart.com:80 (4) | Connected. | 2016-12-06 06:17:32
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-12-06 06:17:36
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-12-06 06:17:36
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-12-06 06:17:36
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-12-06 06:17:36
CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2016-12-06 06:17:40
CTS T4 FIX | Firm: PTP | 2016-12-06 06:17:40
CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102. | 2016-12-06 06:17:40
CTS FIX socket (5) | Connected. | 2016-12-06 06:17:40
CTS FIX socket (5) | Starting TLS 1.0 connection. | 2016-12-06 06:17:40
CTS FIX socket (5) | SSL connection established. | 2016-12-06 06:17:40
CTS FIX: Sending the Logon message. | 2016-12-06 06:17:41
CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2016-12-06 06:17:41
CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2016-12-06 06:17:41 *
CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2016-12-06 06:17:41 *
CTS FIX: Sending a Logout message. Text = Received Logout message. | 2016-12-06 06:17:41
CTS FIX socket (5) | SSL shutdown indicates not able to send 'close notify'. | 2016-12-06 06:17:41
CTS FIX socket (5) | SSL has been shut down. | 2016-12-06 06:17:41
CTS FIX socket (5) | SSL object has been freed. SSL state is now disconnected. | 2016-12-06 06:17:41
CTS FIX socket (5) | Shutdown and closed. | 2016-12-06 06:17:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-12-06 06:17:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-12-06 06:17:41
CTS T4 FIX | Disconnected. | 2016-12-06 06:17:41
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-12-06 06:17:41
HTTP connection to www.sierrachart.com:80 (4) | Closed. No error. | 2016-12-06 06:17:42
HTTP connection to www.sierrachart.com:80 (4) | Shutdown and closed. | 2016-12-06 06:17:42
CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2016-12-06 06:17:44
CTS T4 FIX | Firm: PTP | 2016-12-06 06:17:44
CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102. | 2016-12-06 06:17:44
CTS FIX socket (6) | Connected. | 2016-12-06 06:17:44
CTS FIX socket (6) | Starting TLS 1.0 connection. | 2016-12-06 06:17:44
CTS FIX socket (6) | SSL connection established. | 2016-12-06 06:17:44
CTS FIX: Sending the Logon message. | 2016-12-06 06:17:45
CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2016-12-06 06:17:45
CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2016-12-06 06:17:45 *
CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2016-12-06 06:17:45 *
CTS FIX: Sending a Logout message. Text = Received Logout message. | 2016-12-06 06:17:45
CTS FIX socket (6) | SSL shutdown indicates not able to send 'close notify'. | 2016-12-06 06:17:45
CTS FIX socket (6) | SSL has been shut down. | 2016-12-06 06:17:45
CTS FIX socket (6) | SSL object has been freed. SSL state is now disconnected. | 2016-12-06 06:17:45
CTS FIX socket (6) | Shutdown and closed. | 2016-12-06 06:17:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-12-06 06:17:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-12-06 06:17:45
CTS T4 FIX | Disconnected. | 2016-12-06 06:17:45
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-12-06 06:17:45
CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2016-12-06 06:17:48
CTS T4 FIX | Firm: PTP | 2016-12-06 06:17:48
CTS FIX socket (0) | Resolved address fix.t4login.com to IP 208.116.215.102. | 2016-12-06 06:17:48
CTS FIX socket (7) | Connected. | 2016-12-06 06:17:48
CTS FIX socket (7) | Starting TLS 1.0 connection. | 2016-12-06 06:17:48
CTS FIX socket (7) | SSL connection established. | 2016-12-06 06:17:48
CTS FIX: Sending the Logon message. | 2016-12-06 06:17:48
CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2016-12-06 06:17:49
CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2016-12-06 06:17:49 *
CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2016-12-06 06:17:49 *
CTS FIX: Sending a Logout message. Text = Received Logout message. | 2016-12-06 06:17:49
CTS FIX socket (7) | SSL shutdown indicates not able to send 'close notify'. | 2016-12-06 06:17:49
CTS FIX socket (7) | SSL has been shut down. | 2016-12-06 06:17:49
CTS FIX socket (7) | SSL object has been freed. SSL state is now disconnected. | 2016-12-06 06:17:49
CTS FIX socket (7) | Shutdown and closed. | 2016-12-06 06:17:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-12-06 06:17:49
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-12-06 06:17:49
CTS T4 FIX | Disconnected. | 2016-12-06 06:17:49
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-12-06 06:17:49
File >> Disconnect selected. | 2016-12-06 06:17:49
[2016-12-06 17:44:21]
This is the relevant message:
Refer to the instructions at step 15 here:
http://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructions
You will need to need to contact your broker for help with this.
