Date/Time: Sat, 11 Jan 2025 13:00:25 +0000
TradeDOM - using stop-Limit entries
View Count: 588
[2016-12-06 13:17:30]
User553714 - Posts: 184
I have chart trading enabled, trade windows attached and have saved a number of custom twconfig files, I also have the TradeDOM for the same chart displayed.
I can enter the market when I right click the chart and choose sell stop-limit, the target & stop of the Trade windows are used and I enter the market with a SELL stop-limit at my desired price.
When I try to do the same thing using the TradeDOM it uses a stop order instead of the stop-limit order I have selected from the Trade Window, the Target & Stop order from the Trade Window transmit ok with the stop entry from the TradeDOM; is there a way I can set the TradeDOM to use stop-limit orders instead (or any other order) instead?
[2016-12-06 13:32:35]
I tried making the changes documented here;
http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#SettingsNotApplying
including resetting the child windows but this didn't work.
[2016-12-06 17:36:05]
Refer to step 6 here:
http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ChartDOM
