Date/Time: Sat, 11 Jan 2025 12:48:52 +0000
Initial Balance Study fix
View Count: 641
[2016-12-06 10:02:15] |
User514370 - Posts: 62 |
Hello, is possible to fix IB study to working with non-time related chart types? That means the start and end of IB shouldn´t be strictly connected with new bar. Hope it´s clear, thank you! |
[2016-12-06 10:11:43] |
No. This is not possible at all.
