Date/Time: Sat, 11 Jan 2025 12:58:46 +0000
[User Discussion] - Instructions for sending an Order to Tallinex (MetaTrader 4)
View Count: 1073
[2016-12-05 20:20:03] |
User213308 - Posts: 3 |
I'd like to send the trades from my spreadsheet trade study to my Broker (Tallinex) I spoke to their live chat people and they stated that their only platform is MetaTrader 4. What is the best practice methodology for sending data to them. Like is there a hook or some server settings I can set to make that connection? If not, I was thinking of creating a .dll and exporting the trade in a json file that could then be consumed by a robot created in MetaTrader 4. Before I go to that trouble, I thought I'd ask you if you had a solution already developed that I could simply "plug in" Thanks! Aaron |
[2016-12-05 23:15:07] |
There is no help we can provide for this other than to recommend you use whatever method you find appropriate. We have no other solution. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-07 06:11:17] |
bjohnson777 (Brett Johnson) - Posts: 284 |
User213308: I've been slowly working towards using SC to automate external trading. It's not quite as easy as you'd think. I just released my first step in SC towards that in the link below. I also address the issues I've run into so far. Offering To The Community: Trade Status Report (starting point for external trade program ctrl) Also note that MetaQuotes has recently dropped support for MT4. You'll want to start learning MQL5. Your broker will probably be forced to upgrade sometime next year. If you get something working in MT, ping me on one of these forum threads. I'd be curious to see it. |
