Date/Time: Sat, 11 Jan 2025 12:53:42 +0000
Access custom studies from other custom studies
View Count: 611
[2016-12-05 16:17:53] |
User514837 - Posts: 47 |
I want to access custom studies that I have written from within another custom study. I tried to do this with inputs, as in selecting a study from the chart, like this: sc.GetStudyArrayUsingID(studyRef.GetStudyID()) Is there a better way to achieve this? I need some specific data from within the other studies, but I'm not sure whether I'm going in the correct way. |
[2016-12-05 18:33:20] |
Yes this is correct. Refer to the documentation here: http://www.sierrachart.com/index.php?page=doc/ACSILProgrammingConcepts.html#UsingStudyData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
