Date/Time: Sat, 11 Jan 2025 12:40:47 +0000
Numbers Bars Compare Threshold
View Count: 680
[2016-12-04 23:39:43] |
User104854 - Posts: 456 |
Hi. I currently use the numbers bars and color them based on diagonal dominance. I know the default settings are .25, .5, and .75 but I would like to color the bars at a threshold of 300% or 3 times the diagonal volume. I guess if I put a number greater then 1 it goes by volume difference? Please help. Thanks. |
[2016-12-05 09:46:31] |
Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/NumbersBars.php#ColumnCompareThresholds You will need to use a value of 300 for 300 percent for diagonal comparisons. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-05 16:04:44] |
Got it. Thank you.
[2016-12-05 17:36:40] |
Please there is no need to say thank you. This is extra burden on us.
