Date/Time: Sat, 11 Jan 2025 12:47:28 +0000
Rate of Change Points study question
View Count: 1078
[2016-12-03 13:37:40] |
User348701 - Posts: 23 |
Is there a way to reflect this study in ticks instead of by points? I like to display the value in a draw style that prints the values and I would like to do so in ticks instead of by points in order to save space. Thanks.
[2016-12-04 16:00:07] |
jackw - Posts: 57 |
Add the ROC in Points study, and hide it. Then add the Multiply Subgraphs study, set 'Based On' to the ROC study, and set the multiplier to the number of ticks per point. In my example, ES has a tick size of 0.25, so I set the multipler to 4. I added the Mmultipler study twice. Once to draw the line, and a 2nd time to show values. I have attached a study collection. Just apply it to a clean chart to see how I set it up. Date Time Of Last Edit: 2016-12-04 16:09:19
Chart1.png / V - Attached On 2016-12-04 15:57:23 UTC - Size: 69.13 KB - 302 views MomentumInTicks.StdyCollct - Attached On 2016-12-04 15:57:47 UTC - Size: 28 KB - 252 views |
[2016-12-04 21:11:20] |
Yes you can use this study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s281 And divide by the symbol's tick size. Make sure you also set the Value Format setting with the study to 1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-04 21:18:08] |
Thanks for your time jackw. This looks great. How do you keep the decimal point and zeros from appearing? I also have not been able to get the study collection to run. I am running the most recent version, so I am not sure what the problem is.
[2016-12-04 21:19:49] |
Thanks again Jack. I figured out the decimal issue. Still stuck on the study collection.
[2016-12-04 21:22:27] |
How do you keep the decimal point and zeros from appearing? Set the Value Format to 1 for the particular study which is displaying the result.Here are the instructions to use a Study Collection: How to Use an Advanced Custom Study or a Study Collection: How to Use a Study Collection Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-04 21:22:39
[2016-12-05 03:08:41] |
Thanks again for all of the help. I have got it working.
