Date/Time: Sat, 11 Jan 2025 12:41:38 +0000
NOT CONNECTING
View Count: 930
[2016-12-03 02:34:16] |
User702072 - Posts: 4 |
My internet connection went down and came back up for everything but Sierra Charts after I rebooted my modem. SC flashes between Waiting to reconnect and Connecting. I posted earlier but forgot to title the post.
[2016-12-03 02:41:52] |
We see you are using CQG and currently the CQG system is down. So this is expected.
[2016-12-03 04:11:36] |
Does CQG go down on weekends or is it simply don for a technical reason?
[2016-12-03 09:11:43] |
We are not sure the reason it is down now but it does go down part of the time on weekends from what we can remember.
[2016-12-03 22:28:30] |
nickwynn - Posts: 2 |
Is CTS Data also down? I haven't been able to get a data connection all day. It says the target machine is refusing my connection request.
[2016-12-03 22:43:26] |
Yes CTS is also down. However, if you use the new connection model we have to CTS, the connection is always available: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructionsForAdvancedLowCostConnectionModel This is what we recommend. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-03 22:49:56] |
I use TopStepTrader and the data through CTS was provided for me. Will I still be able to set up this new connection model?
[2016-12-04 21:24:46] |
The lower-cost connection model to CTS only supports live trading at this time.
