Date/Time: Sat, 11 Jan 2025 12:56:21 +0000
request example of sc.CalculateTimeSpanAcrossChartBars
View Count: 680
[2016-12-02 22:20:29] |
@sstfrederik - Posts: 404 |
I am testing sc.CalculateTimeSpanAcrossChartBars, but I am not getting any other output than 0. Do you have a working code example? Thanks. |
[2016-12-02 22:48:42] |
We have tested this and found there is a problem with how this was implemented and it will be resolved in the next release.
[2016-12-03 16:05:04] |
Which release will that be?
[2016-12-03 21:48:40] |
This will be out in a couple of days.
