Date/Time: Sat, 11 Jan 2025 12:45:32 +0000
How to add a pane #2 to chart with custom data
View Count: 665
[2016-12-02 17:07:25] |
TraderTen - Posts: 80 |
I have previously built a chart by importing custom data. However, I would like to have a standard chart in pane #1, but add a pane #2 with custom data. Can that be done? If so, how.
[2016-12-02 18:07:00] |
This could be done by using ACSIL: Advanced Custom Study Interface and Language (ACSIL) Or with the Spreadsheet Study page: https://www.sierrachart.com/index.php?page=doc/SpreadsheetStudy.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
