Date/Time: Sat, 11 Jan 2025 12:50:06 +0000
Volume Profile
View Count: 712
[2016-12-02 15:28:32] |
User104854 - Posts: 456 |
Hi. If I have a volume profile that I've drawn on my chart and it takes up the whole chart I notice that when I click on it with the crosshair it highlights the volume profile to edit it. Is there a way to over ride it so that the profile is on there but doesn't automatically highlight it when I click on the chart? Hope this makes sense. Thanks.
[2016-12-02 17:48:25] |
You need to enable Global Settings >> Tool Settings >> Select Drawn Volume Profile by Outline Only. Refer to: https://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#DrawVolumeProfileToolRelatedSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-02 18:29:53] |
Perfect. Thank you!
