Date/Time: Sat, 11 Jan 2025 12:45:08 +0000
Time management function, release candidate: feedback suggestion
View Count: 686
[2016-12-02 06:45:05]
jackbravo - Posts: 69
Thank you for putting the time management function to close out trades in the release candidate. I downloaded it and have been using it.
However, there is one quirk which does not allow its use as I had envisioned. When turned on (set at 310 PM, with global settings using Chicago time), it does in fact close out any trades that are open at 310pm. However, it also closes out any new trades that I attempt at 5pm, after the set time, and at the when the new day for the futures market. I would like to suggest that the function only checks if trades are open once a day, at the specified time. Such that, if trades are newly opened after the set time, they will not automatically close.
Thanks.
[2016-12-02 08:00:41]
Yes we understand and it should work as you want it to.
So we have to check on this.
[2016-12-02 10:15:22]
We cannot reproduce what you are describing. The version you are running, is a version where this feature was not fully complete.
Update to the latest release following these instructions:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
[2016-12-02 17:46:09]
Ok, thank you; I updated to the latest release of SC.
