Date/Time: Sat, 11 Jan 2025 11:39:55 +0000
Please correct Volume/NumberTrades study which gives wrong output!
View Count: 777
[2016-12-02 06:26:53] |
User857142 - Posts: 82 |
Hi The Volume/NumberTrades study is wrongly calculating the values. Instead of dividing, its multiplying! See the screenshot i.e. the output should have been 1.23 (74/60). But its showing 4440 (74*60) It messed up my trading. Please rectify asap in next released version. Hardly a matter of a minute to change the code. Thanks |
sierra.png / V - Attached On 2016-12-02 06:23:59 UTC - Size: 102.35 KB - 236 views |
[2016-12-02 06:43:48] |
We will fix this. Clearly a significant mistake. Most likely this was done very quickly by us and we did not pay attention closely and test it which sometimes is the case when we have such a high volume of work.
