Date/Time: Sat, 11 Jan 2025 11:57:33 +0000
Period Trade Stats Daily Reset Time
View Count: 747
[2016-12-02 03:25:38] |
User948528 - Posts: 108 |
Is it possible to make the Period Trade Stats Daily Reset Time use the same time used in Daily P&L calculations, ie 18:00 instead of 00:00?
[2016-12-02 05:29:06] |
Yes it is possible, but it is not something we can do anytime soon.
[2016-12-08 16:48:46] |
Thank you for whenever you can get to this. Also the Weekly Period stats seem to include Sunday as the end of a previous week, while it is the beginning of the week/combined with Monday for official futures marking of positions, please allow changing this also. |
[2016-12-08 19:10:22] |
We will change the beginning of the week to Sunday for the Period Trade Statistics. It should have been that way.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-08 19:10:54
