Date/Time: Sat, 11 Jan 2025 11:44:57 +0000
Multiple Scales in region
View Count: 854
[2016-12-01 19:45:56] |
User53601 - Posts: 105 |
I have two studies in a region. Volume and ATR. The scale displays the values of the Volume. Is there a way to switch the scale, to display the values of the other/ATR study? |
[2016-12-01 19:47:08] |
Yes this can be done by using the Left Side Scale: Chart Settings: Use Left Side Scale (Chart >> Chart Settings >> Scale menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
